Lee, would using the setcfg/getcfg necessitate sharing the acad.cfg file?
I guess if the application is to be used across a network there would need to be a single
acad.cfg file residing in a network support path; for such a simple task as the OP has described, (i.e. with minimal data), the
setcfg/
getcfg seemed a good solution without requiring extensive programming knowledge.
