Author Topic: changing text style of selected text  (Read 5621 times)
andrew_nao
« on: January 14, 2013, 03:59:08 PM »
im a bit lazy and in a bit of a hurry
does anyone have a quick and simple lisp to change the text style of selected text from simplex to arial black?
fixo
Re: changing text style of selected text
« Reply #1 on: January 14, 2013, 06:00:20 PM »
Something like this not sure abou:
(vla-setfont
  (vla-item
    (vla-get-textstyles
      (setq adoc (vla-get-activedocument
(vlax-get-acad-object))))
    "Standard" ;style
"ARIAL" ;font
:vlax-false ;bold
:vlax-true ;italic
0 ;charset
(+ 2 64) ;font family
(vla-regen adoc acallviewports)
« Reply #2 on: January 14, 2013, 06:17:32 PM »
Text Style or font assigned to a Text Style? (since the two items you mention are font names)
If they are indeed the names of Text Styles:
(defun c:foo ( / e i s )
    (if (setq s (ssget "_:L" '((0 . "TEXT,MTEXT") (7 . "SIMPLEX"))))
        (repeat (setq i (sslength s))
            (setq e (entget (ssname s (setq i (1- i)))))
            (entmod (subst '(7 . "Arial Black") (assoc 7 e) e))
andrew_nao
« Reply #3 on: January 15, 2013, 11:08:56 AM »
thanks for the reply, however neither worked
the style is still simplex
ill just change it over to mtext and do it manually
thanks for the offers :)
btw. i meant font, not style.. sorry for the confusion. i was in a hurry :)
cheers
« Reply #4 on: January 15, 2013, 11:42:27 AM »
Andrew you should know that the font in plain text can only be changed by changing the STYLE.
You can create a new Style for your desired font or use an existing style.
« Reply #5 on: January 15, 2013, 11:51:55 AM »
 :-o
Just change the font applied to the Text Style and this change will be reflected across all Text objects referencing the style.
fixo
« Reply #6 on: January 15, 2013, 12:42:27 PM »
Try this code for your style:
(setq txtstyle (vla-item (vla-get-textstyles adoc) "Standard"));<-- set your style name here
  (if (not
(equal (strcase (vla-get-fontfile txtstyle)) "TIMES.TTF"))
    (vl-catch-all-apply
      '(lambda ()
   (setq fontfile (findfile (strcat (getenv "WINDIR") "\\fonts\\times.ttf")))
   (vla-put-fontfile txtstyle fontfile)
andrew_nao
« Reply #7 on: January 16, 2013, 08:54:33 AM »
 :-o
thank Lee, however im after just changing the font on selected text not all the text.
andrew_nao
« Reply #8 on: January 16, 2013, 08:55:51 AM »
i was trying to get around that, i guess its not possible.
andrew_nao
« Reply #9 on: January 16, 2013, 08:56:53 AM »
  (if (not
    (vl-catch-all-apply
      '(lambda ()
thanks fixo ill try this out
