I am looking for a lisp routine that can change the setting for Simplex. I would like to have the width setting to be at .7
Thank you,
Brad
or you can change width factor with this here
; wf is stand for making edit to width factor
; Design by Ade Suharna <mteybid@yuasabattery.co.id>
; 1 September 2004
; program no. 60/09/2004
; edit by Ade Suharna 05/10/2004 1).
(defun c:wf (/ ent info41 opt ed)
(while ; 1).
(setq ent (entget (car (entsel)))
info41 (rtos (cdr (assoc 41 ent)))
opt
(getreal
(strcat "\nENTER NEW FACTOR" "<" info41 ">" ":"))
ed (subst (cons 41 opt)(assoc 41 ent) ent))
(entmod ed)
Ade,
I should have asked this before I requested for alteration of your code. My this code be changed to meet the needs for other users could use it for.
Thank you,
Brad
Yes ,please if you want to alter for this code,in this code I prepare special line for edit by,as like this
--------------<snip>-------------------------
; One Shot 18/03/2005 2).
--------------<snip>--------------------------
