Author Topic: (Challenge) Closest integer to n  (Read 12321 times)
VovKa
  • Ukraine
Re: (Challenge) Closest integer to n
« Reply #45 on: February 03, 2010, 04:06:24 PM »
Ok  :-)
(defun test3 (n l / a b)
 (if (vl-position n l)
  n
  (cond ((not (setq l (vl-sort (cons n l) (function <))
                    a (cadr (member n l))
              ) ;_  setq
         ) ;_  not
         (cadr (member n (reverse l)))
        ((not (setq b (cadr (member n (reverse l)))))a)
        ((if(< (abs (- n a)) (abs (- n b))) a b))
  ) ;_  cond
 ) ;_  if
Evgeniy, i tested your code and got the same results as Lee did
i just can't see how member can outrun vl-position
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #46 on: February 03, 2010, 04:47:03 PM »
Indeed, now I got the results that are similar to yours.
Perhaps I was wrong.
I'm sorry, I'm sorry.
I have a new idea :
(defun test4 (n l / a b i)
 (cond ((not (setq l (vl-sort (cons (float n) l) (function <))
                   i (vl-position (float n) l)
                   a (nth (1- i) l)
             ) ;_  setq
        ) ;_  not
        (nth (1+ i) l)
       ((not (setq b (nth (1+ i) l))) a)
       ((if (< (abs (- n a)) (abs (- n b)))
         a
         b
        ) ;_  if
 ) ;_  cond
VovKa
  • Ukraine
« Reply #47 on: February 03, 2010, 05:04:54 PM »
Evgeniy, excelent move with float :)
now it's faster than mine
but bad news for (test4 1 '(1 2 3))
wizman
« Reply #48 on: February 03, 2010, 05:29:57 PM »
(defun wiz-near4 (n lst / a d e f g)
    (if (vl-position n lst)
        n
        (setq lst (vl-sort (cons n lst) (function >))
              lst (cons -1e6 (reverse (cons 1e6 lst)))
              a   (vl-position n lst)
              d   (nth (1+ a) lst)
              e   (nth (1- a) lst)
              f   (- d n)
              g   (if (equal e n f)
                      e
                      d
..be back tom..
cmwade77
« Reply #49 on: February 03, 2010, 06:38:15 PM »
I am sure that there are far faster and better on here, but I thought I would try my hand at it before reading the entier thread, so here is my entry:
(defun c:inttst (/ a lst ct b c d e)
(setq a (getint "\nEnter integer: ")
      lst '(45 23 63 5 8 56 74 32 96 144 95)
  ct 0
  ct2 (- (length lst) 1)
  lst (vl-sort lst '<)
  pos (vl-position a lst)
  b (nth 0 lst)
  d (- b a)
  c (nth ct2 lst)
  e (- a c))
((/= pos nil)
(princ (strcat "\nThere was an exact match: " (itoa (nth pos lst))))
(T
(while (< ct (length lst))
((> (nth ct lst) a)
(setq b (nth ct lst)
      d (- b a))
(setq ct (+ ct 1))
(while (> ct2 -1)
((< (nth ct2 lst) a)
(setq c (nth ct2 lst)
      e (- a c))
(setq ct2 (- ct2 1))
(if (< d e)
(princ (strcat "\nThe closest number to " (itoa a) " is: " (itoa (nth (- ct 1) lst))))
(princ (strcat "\nThe closest number to " (itoa a) " is: " (itoa (nth (+ ct2 1) lst))))
It works, but now I am going to go through the thread and see if there is one that looks like it will run faster. This is actually something that can be helpful in some routines that I am working on.
« Reply #50 on: February 03, 2010, 07:19:09 PM »
Chris,
It'd be better if your function took two arguments (the number and lst), and didn't have user input/print out - then it can be tested in a benchmarking function  :-)
SomeCallMeDave
« Reply #51 on: February 03, 2010, 08:31:01 PM »
Any room for some Ruby?
class Array
  def nearest(input)
    self.sort_by{|x| (x-input).abs}.first
  end
end
numbers = [45, 23, 63, 5, 8, 56, 74, 32, 96, 144, 95]
input = 10
puts numbers.nearest input   # returns 8
puts [1,2,3].nearest 5 #returns 3
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #52 on: February 04, 2010, 12:39:45 AM »
 (cond ((zerop (setq l (vl-sort (cons (float n) l) (function <))
        (cadr l)
       ((not (setq a (nth (1- i) l)
                   b (nth (1+ i) l)
        a
         a
         b
« Reply #53 on: February 04, 2010, 03:05:11 AM »
and who said dead threads shouldn't be resurrected  :?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #54 on: February 04, 2010, 03:07:46 AM »
I love all threads *Challenge*  :-)
VovKa
  • Ukraine
« Reply #55 on: February 04, 2010, 04:50:18 AM »
i've changed cond to ifs and stolen wizman's equal
(defun test413 (n l / a b i)
  (if (zerop (setq l (vl-sort (cons (float n) l) (function <))
    (cadr l)
    (if (or (not (setq a (nth (1- i) l)
       b (nth (1+ i) l)
    (equal n a (- b n))
      a
      b
« Last Edit: February 04, 2010, 04:55:20 AM by VovKa »
wizman
« Reply #56 on: February 04, 2010, 04:56:03 AM »
i think that would be it Vovka, i like also EE's float: (vl-position 1.0 '(1 1 1 1.0)) ;3
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #57 on: February 04, 2010, 05:48:42 AM »
ever useful to you:
(vl-sort '(0 1 2 0 1 2)'<)       ;; =>> '(1 2 3)
but
(vl-sort '(0. 1. 2. 0. 1. 2.)'<) ;; =>> '(0.0 1.0 1.0 2.0 2.0)
« Reply #58 on: February 04, 2010, 05:53:40 AM »
ever useful to you:
uhmmm ...  that's (0 1 2) , yes ?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #59 on: February 04, 2010, 06:25:45 AM »
I was not sufficiently attentive.
Thank you!
