That's definitely did the trick. I'm not totally sure how, but it did.
I understand that the COPY command copies the selection set from 0,0,0 to 0,0,0.
And, I understand that the MOVE command is moving the original entities and leaving the new entities where they are.
What I don't understand is using "\\". What is that? Is it the same and hitting ENTER or using ""?
As a side note, it amazes me how your mind works. The solutions you come up with are brilliant.
Rabbit
