Author Topic: Add arc at polyline vertex  (Read 15807 times)
krkec
« on: December 23, 2012, 08:00:54 AM »
Hi
is there  a way to add arc to every polyline vertex ( I am editing existing polyline). I tried with bulge but I don't understand relation between radius and angle in bulge concept?
Please help me with some hints.
fixo
Re: Add arc at polyline vertex
« Reply #1 on: December 23, 2012, 10:41:50 AM »
You may want this one to create arcs on every segment,
in case you need to create the bulged segments instead,
then use SetBulge method
                public static Point3d PolarPoint(Point3d basepoint, double angle, double distance)
                    // credits to Tony Tanzillo
                    return new Point3d(
                    basepoint.X + (distance * Math.Cos(angle)),
                    basepoint.Y + (distance * Math.Sin(angle)),
                    basepoint.Z);
                [CommandMethod("PARC")]
                public void addArcs()
                    Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                    Editor ed = doc.Editor;
                    Database db = doc.Database;
                    Transaction tr = doc.TransactionManager.StartTransaction();
                    using (tr)
                        BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                        // prompt for selecting polyline
                        PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline: >>");
                        peo.SetRejectMessage("\nSelect a polyline only >>");
                        peo.AddAllowedClass(typeof(Polyline), false);
                        peo.AllowObjectOnLockedLayer = true;
                        PromptEntityResult res;
                        res = ed.GetEntity(peo);
                        if (res.Status != PromptStatus.OK) return;
                        Entity ent = (Entity)tr.GetObject(res.ObjectId, OpenMode.ForRead);
                        if (ent == null) return;
                        Polyline pline = (Polyline)ent as Polyline;
                        if (pline == null) return;
                        // get the number of segments
                        int segments = pline.NumberOfVertices - 1;
                        for (int i = 0; i < segments; i++)
                            if (pline.GetSegmentType(i) == SegmentType.Arc)
                                continue;
                            // get arc segment on polyline
                            LineSegment2d lseg = pline.GetLineSegment2dAt(i);
                            // get center
                            Point2d center = lseg.EvaluatePoint(0.5);
                            // create an Arc
                          Point2d   p1 = lseg.StartPoint;
                          Point2d p2 = lseg.EndPoint;
                          double ang = lseg.Direction.Angle;
                            Point3d mp = new Point3d((p1.X + p2.X) / 2, (p1.Y + p2.Y) / 2,pline.Elevation).TransformBy(Matrix3d.Identity);
                            // get half of hord
                            double cat = lseg.Length / 2.0;
                            // you have soecify radius of an arc here:
                            double rad = lseg.Length * 1.25;// <--    dummy radius for test
                            // get next catet
                            double bcat = Math.Sqrt(rad * rad - cat * cat);
                            Point3d cp = PolarPoint(mp, ang + Math.PI / 2, bcat);
                            Plane plan = new Plane(Point3d.Origin, Vector3d.ZAxis);
                            Point3d sp=new Point3d(p1.X,p1.Y,pline.Elevation);
                            Point3d ep = new Point3d(p2.X, p2.Y, pline.Elevation);
                            // create arc using center radius and both angles, count clockwise from start line to end
                            Arc arc = new Arc(cp, rad, cp.GetVectorTo(sp).AngleOnPlane(plan), cp.GetVectorTo(ep).AngleOnPlane(plan));
                            // add to current space and transaction
                            btr.AppendEntity(arc);
                            tr.AddNewlyCreatedDBObject(arc, true);
                        tr.Commit();
krkec
« Reply #2 on: December 23, 2012, 12:36:20 PM »
Thanks for quick respond.
But it isn't  what I'm looking for. I want to edit existing polyline by inserting arcs of specific radius into vertex point (vertex point is intersection of arc tangents). Something like filleting polylines.
Any idea?
fixo
« Reply #3 on: December 23, 2012, 01:35:23 PM »
So you can try this way
it will should you methods you need,
code create a simple polyline then add
bulge in to one segment,
then you can expand it to your current polyline I hope
              [CommandMethod("FPL")]
                public void filletPline()
                    try
                            Point3dCollection pts = new Point3dCollection();
                            Point3d pt = new Point3d(0, 0, 0);
                            pts.Add(pt);
                            pt = new Point3d(100, 0, 0);
                            pts.Add(pt);
                            pt = new Point3d(100, 50, 0);
                            pts.Add(pt);
                            pt = new Point3d(0, 50, 0);
                            pts.Add(pt);
                            Polyline pol = new Polyline(pts.Count);
                            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
                            Point3d origin = new Point3d(0, 0, 0);
                            Vector3d normal = new Vector3d(0, 0, 1);
                            normal = normal.TransformBy(ucs);
                            Plane plane = new Plane(origin, normal);
                            int j = 0;
                            foreach (Point3d pnt in pts)
                                Point3d transformedPt = pnt.TransformBy(ucs);
                                pol.AddVertexAt(pol.NumberOfVertices, plane.ParameterOf(transformedPt), 0, 0, 0);
                                pol.SetEndWidthAt(j, 2);
                                pol.SetStartWidthAt(j, 2);
                                j++;
                            pol.SetBulgeAt(1, Math.PI / 4);
                            btr.AppendEntity(pol);
                            tr.AddNewlyCreatedDBObject(pol, true);
                            tr.Commit();
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                        ed.WriteMessage(ex.StackTrace);
fixo
« Reply #4 on: December 23, 2012, 02:13:57 PM »
In addition you can use this code too
                [DllImport("acad.exe", BestFitMapping = true, CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Auto)]
                private static extern int acedCmd(System.IntPtr cmd);
                [CommandMethod("FILET")]
                public static void TestFillet()
                    Transaction tr = db.TransactionManager.StartTransaction();
                    using (tr)
                        try
                            // Prompt for the polyline to revcloud
                            PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline:");
                            peo.SetRejectMessage("\nSelect polyline only");
                            peo.AddAllowedClass(typeof(Polyline), true);
                            PromptEntityResult per = ed.GetEntity(peo);
                            if (per.Status != PromptStatus.OK)
                                return;
                            ObjectId fid = per.ObjectId;
                            DBObject obj1 = tr.GetObject(fid, OpenMode.ForWrite);
                            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("CMDECHO", 0);
                            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("FILLETRAD", 50.0);
                            ResultBuffer buf = new ResultBuffer();
                            buf.Add(new TypedValue(5005, "_FILLET"));
                            buf.Add(new TypedValue(5005, "_P"));
                            buf.Add(new TypedValue(5006, fid));
                            acedCmd(buf.UnmanagedObject);
                            buf.Dispose();
                            Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("CMDECHO", 1);
                            tr.Commit();
                            ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
gile
  • Marseille, France
« Reply #5 on: December 23, 2012, 03:05:03 PM »
Here's a way using some geometry.
Code - C#: [Select]
  1. using System;
  2. using Autodesk.AutoCAD.ApplicationServices;
  3. using Autodesk.AutoCAD.DatabaseServices;
  4. using Autodesk.AutoCAD.EditorInput;
  5. using Autodesk.AutoCAD.Geometry;
  6. using Autodesk.AutoCAD.Runtime;
  7. using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
  8.
  9. [assembly: CommandClass(typeof(PolylineFillet.CommandMethods))]
  10.
  11. namespace PolylineFillet
  12. {
  13.     public class CommandMethods
  14.     {
  15.         [CommandMethod("Test", CommandFlags.Modal)]
  16.         public void Test()
  17.         {
  18.             Document doc = AcAp.DocumentManager.MdiActiveDocument;
  19.             Database db = doc.Database;
  20.             Editor ed = doc.Editor;
  21.
  22.             PromptDistanceOptions pdo = new PromptDistanceOptions("\nFillet radius: ");
  23.             pdo.AllowZero = false;
  24.             pdo.AllowNegative = false;
  25.             PromptDoubleResult pdr = ed.GetDistance(pdo);
  26.             if (pdr.Status != PromptStatus.OK)
  27.                 return;
  28.
  29.             double radius = pdr.Value;
  30.             PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline: ");
  31.             peo.SetRejectMessage("Not a polyline.");
  32.             peo.AddAllowedClass(typeof(Polyline), true);
  33.             PromptEntityResult per = ed.GetEntity(peo);
  34.             if (per.Status != PromptStatus.OK)
  35.                 return;
  36.
  37.             using (Transaction tr = db.TransactionManager.StartTransaction())
  38.             {
  39.                 Polyline pline = (Polyline)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
  40.                 FilletAll(pline, radius);
  41.                 tr.Commit();
  42.             }
  43.         }
  44.
  45.         private void FilletAll(Polyline pline, double radius)
  46.         {
  47.             int n = pline.Closed ? 1 : 2;
  48.             for (int i = 0; i < pline.NumberOfVertices - n; i++)
  49.                 i += Fillet(pline, radius, i, i + 1);
  50.             if (pline.Closed)
  51.                 Fillet(pline, radius, pline.NumberOfVertices - 1, 0);
  52.         }
  53.
  54.         private int Fillet(Polyline pline, double radius, int index1, int index2)
  55.         {
  56.             if (pline.GetSegmentType(index1) != SegmentType.Line ||
  57.                 pline.GetSegmentType(index2) != SegmentType.Line)
  58.                 return 0;
  59.             LineSegment2d seg1 = pline.GetLineSegment2dAt(index1);
  60.             LineSegment2d seg2 = pline.GetLineSegment2dAt(index2);
  61.             Vector2d vec1 = seg1.StartPoint - seg1.EndPoint;
  62.             Vector2d vec2 = seg2.EndPoint - seg2.StartPoint;
  63.             double angle = vec1.GetAngleTo(vec2) / 2.0;
  64.             double dist = radius / Math.Tan(angle);
  65.             if (dist > seg1.Length || dist > seg2.Length)
  66.                 return 0;
  67.             Point2d pt1 = seg1.EndPoint.TransformBy(Matrix2d.Displacement(vec1.GetNormal() * dist));
  68.             Point2d pt2 = seg2.StartPoint.TransformBy(Matrix2d.Displacement(vec2.GetNormal() * dist));
  69.             double bulge = Math.Tan((Math.PI / 2.0 - angle) / 2.0);
  70.             if (Clockwise(seg1.StartPoint, seg1.EndPoint, seg2.EndPoint))
  71.                 bulge = -bulge;
  72.             pline.AddVertexAt(index2, pt1, bulge, 0.0, 0.0);
  73.             pline.SetPointAt(index2 + 1, pt2);
  74.             return 1;
  75.         }
  76.
  77.         private bool Clockwise(Point2d p1, Point2d p2, Point2d p3)
  78.         {
  79.             return ((p2.X - p1.X) * (p3.Y - p1.Y) - (p2.Y - p1.Y) * (p3.X - p1.X)) < 1e-8;
  80.         }
  81.     }
  82. }
  83.
« Last Edit: December 23, 2012, 04:48:55 PM by gile »
krkec
« Reply #6 on: December 24, 2012, 03:22:09 AM »
thanks guys i am trying it now
gile
  • Marseille, France
« Reply #7 on: December 24, 2012, 04:38:35 AM »
Here's a better (more reusable) implementation:
Testing command
Code - C#: [Select]
  1.     public class CommandMethods
  2.     {
  3.         [CommandMethod("Test", CommandFlags.Modal)]
  4.         public void Test()
  5.         {
  6.             Document doc = AcAp.DocumentManager.MdiActiveDocument;
  7.             Database db = doc.Database;
  8.             Editor ed = doc.Editor;
  9.
  10.             PromptDistanceOptions pdo = new PromptDistanceOptions("\nFillet radius: ");
  11.             pdo.AllowZero = false;
  12.             pdo.AllowNegative = false;
  13.             PromptDoubleResult pdr = ed.GetDistance(pdo);
  14.             if (pdr.Status != PromptStatus.OK)
  15.                 return;
  16.             double radius = pdr.Value;
  17.
  18.             PromptEntityOptions peo = new PromptEntityOptions("\nSelect a polyline: ");
  19.             peo.SetRejectMessage("Not a polyline.");
  20.             peo.AddAllowedClass(typeof(Polyline), true);
  21.             PromptEntityResult per = ed.GetEntity(peo);
  22.             if (per.Status != PromptStatus.OK)
  23.                 return;
  24.
  25.             using (Transaction tr = db.TransactionManager.StartTransaction())
  26.             {
  27.                 Polyline pline = (Polyline)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
  28.                 pline.FilletAll(radius);
  29.                 tr.Commit();
  30.             }
  31.         }
  32.     }
Extension methods
Code - C#: [Select]
  1.     static class Extensions
  2.     {
  3.         /// <summary>
  4.         /// Adds an arc (fillet), if able, at each polyline vertex.
  5.         /// </summary>
  6.         /// <param name="pline">The instance to which the method applies.</param>
  7.         /// <param name="radius">The arc radius.</param>
  8.         public static void FilletAll(this Polyline pline, double radius)
  9.         {
  10.             int j = pline.Closed ? 0 : 1;
  11.             for (int i = j; i < pline.NumberOfVertices - j; i++)
  12.             {
  13.                 i += pline.FilletAt(i, radius);
  14.             }
  15.         }
  16.
  17.         /// <summary>
  18.         /// Adds an arc (fillet) at the specified vertex.
  19.         /// </summary>
  20.         /// <param name="pline">The instance to which the method applies.</param>
  21.         /// <param name="index">The index of the verex.</param>
  22.         /// <param name="radius">The arc radius.</param>
  23.         /// <returns>1 if the operation succeeded, 0 if it failed.</returns>
  24.         public static int FilletAt(this Polyline pline, int index, double radius)
  25.         {
  26.             int prev = index == 0 && pline.Closed ? pline.NumberOfVertices - 1 : index - 1;
  27.             if (pline.GetSegmentType(prev) != SegmentType.Line ||
  28.                 pline.GetSegmentType(index) != SegmentType.Line)
  29.             {
  30.                 return 0;
  31.             }
  32.             LineSegment2d seg1 = pline.GetLineSegment2dAt(prev);
  33.             LineSegment2d seg2 = pline.GetLineSegment2dAt(index);
  34.             Vector2d vec1 = seg1.StartPoint - seg1.EndPoint;
  35.             Vector2d vec2 = seg2.EndPoint - seg2.StartPoint;
  36.             double angle = vec1.GetAngleTo(vec2) / 2.0;
  37.             double dist = radius / Math.Tan(angle);
  38.             if (dist == 0.0 || dist > seg1.Length || dist > seg2.Length)
  39.             {
  40.                 return 0;
  41.             }
  42.             Point2d pt1 = seg1.EndPoint + vec1.GetNormal() * dist;
  43.             Point2d pt2 = seg2.StartPoint + vec2.GetNormal() * dist;
  44.             double bulge = Math.Tan((Math.PI / 2.0 - angle) / 2.0);
  45.             if (Clockwise(seg1.StartPoint, seg1.EndPoint, seg2.EndPoint))
  46.             {
  47.                 bulge = -bulge;
  48.             }
  49.             pline.AddVertexAt(index, pt1, bulge, 0.0, 0.0);
  50.             pline.SetPointAt(index + 1, pt2);
  51.             return 1;
  52.         }
  53.
  54.         /// <summary>
  55.         /// Evaluates if the points are clockwise.
  56.         /// </summary>
  57.         /// <param name="p1">First point.</param>
  58.         /// <param name="p2">Second point</param>
  59.         /// <param name="p3">Third point</param>
  60.         /// <returns>True if points are clockwise, False otherwise.</returns>
  61.         private static bool Clockwise(Point2d p1, Point2d p2, Point2d p3)
  62.         {
  63.             return ((p2.X - p1.X) * (p3.Y - p1.Y) - (p2.Y - p1.Y) * (p3.X - p1.X)) < 1e-8;
  64.         }
  65.     }
<Edit: added comments>
<Edit: corrected a dysfunction with colinear segments by checkin dist == 0.0>
« Last Edit: October 01, 2017, 03:47:10 AM by gile »
krkec
« Reply #8 on: December 27, 2012, 02:13:12 PM »
 Thanks for response but I have problem with your code gile.
1. First code  I tryed  but it doesnt fillet at all vertex points
2. When I convert second code to vb.net  and copy it to  visual studio  i get thi error
Error   1   'FilletAt' is not a member of 'Autodesk.AutoCAD.DatabaseServices.Polyline'.    on this line --->  i += pline.FilletAt(i, radius) and
Error   2   'FilletAll' is not a member of 'Autodesk.AutoCAD.DatabaseServices.Polyline'.    on this line ---> pline.FilletAll(radius)
what am I doing wrong???
gile
  • Marseille, France
« Reply #9 on: December 27, 2012, 03:46:35 PM »
With VB, extension methods have to be defined in a module and with a 'System.Runtime.CompilerServices.Extension' attribute.
One other thing: with VB, the 'for' statement does not check the condition at each loop so, to loop for each vertex while adding some new ones, you must use a 'while' statement instead.
VB
Code - vb.net: [Select]
  1.     Module Extensions
  2.
  3.         ' Adds an arc (fillet) at each polyline vertex, if able.
  4.         <System.Runtime.CompilerServices.Extension> _
  5.         Public Sub FilletAll(pline As Polyline, radius As Double)
  6.             Dim i As Integer = If(pline.Closed, 0, 1)
  7.             While i < If(pline.Closed, pline.NumberOfVertices, pline.NumberOfVertices - 1)
  8.                 i += 1 + pline.FilletAt(i, radius)
  9.             End While
  10.         End Sub
  11.
  12.         ' Adds an arc (fillet) at the specified vertex. Retuns 1 if the operation succeeded, 0 if it failed.
  13.         <System.Runtime.CompilerServices.Extension> _
  14.         Public Function FilletAt(pline As Polyline, index As Integer, radius As Double) As Integer
  15.             Dim prev As Integer = If(index = 0 AndAlso pline.Closed, pline.NumberOfVertices - 1, index - 1)
  16.             If pline.GetSegmentType(prev) <> SegmentType.Line OrElse _
  17.                 pline.GetSegmentType(index) <> SegmentType.Line Then
  18.                 Return 0
  19.             End If
  20.             Dim seg1 As LineSegment2d = pline.GetLineSegment2dAt(prev)
  21.             Dim seg2 As LineSegment2d = pline.GetLineSegment2dAt(index)
  22.             Dim vec1 As Vector2d = seg1.StartPoint - seg1.EndPoint
  23.             Dim vec2 As Vector2d = seg2.EndPoint - seg2.StartPoint
  24.             Dim angle As Double = (Math.PI - vec1.GetAngleTo(vec2)) / 2.0
  25.             Dim dist As Double = radius * Math.Tan(angle)
  26.             If dist > seg1.Length OrElse dist > seg2.Length Then
  27.                 Return 0
  28.             End If
  29.             Dim pt1 As Point2d = seg1.EndPoint + vec1.GetNormal() * dist
  30.             Dim pt2 As Point2d = seg2.StartPoint + vec2.GetNormal() * dist
  31.             Dim bulge As Double = Math.Tan(angle / 2.0)
  32.             If Clockwise(seg1.StartPoint, seg1.EndPoint, seg2.EndPoint) Then
  33.                 bulge = -bulge
  34.             End If
  35.             pline.AddVertexAt(index, pt1, bulge, 0.0, 0.0)
  36.             pline.SetPointAt(index + 1, pt2)
  37.             Return 1
  38.         End Function
  39.
  40.         ' Evaluates if the points are clockwise.
  41.         Private Function Clockwise(p1 As Point2d, p2 As Point2d, p3 As Point2d) As Boolean
  42.             Return ((p2.X - p1.X) * (p3.Y - p1.Y) - (p2.Y - p1.Y) * (p3.X - p1.X)) < 0.00000001
  43.         End Function
  44.
  45.     End Module
krkec
« Reply #10 on: December 27, 2012, 03:55:32 PM »
thank you very very much its working
gile
  • Marseille, France
« Reply #11 on: December 27, 2012, 04:06:28 PM »
You're welcome krkec, I had fun writing this snippet.
If someone have some interest, here's a F# implementation of these extension methods.
Code - F#: [Select]
  1. // Evaluates if the points are clockwise.
  2. let clockwise (p1: Point2d) (p2: Point2d) (p3: Point2d) =
  3.     ((p2.X - p1.X) * (p3.Y - p1.Y) - (p2.Y - p1.Y) * (p3.X - p1.X)) < 1e-8
  4.
  5. type Polyline with
  6.     // Adds an arc (fillet) at the specified vertex. Retuns 1 if the operation succeeded, 0 if it failed.
  7.     member pl.FilletAt index radius =
  8.         let prev = (if index = 0 && pl.Closed then pl.NumberOfVertices else index) - 1
  9.         if pl.GetSegmentType(prev) <> SegmentType.Line ||
  10.             pl.GetSegmentType(index) <> SegmentType.Line then
  11.             0
  12.         else
  13.             let seg1 = pl.GetLineSegment2dAt(prev)
  14.             let seg2 = pl.GetLineSegment2dAt(index)
  15.             let vec1 = seg1.StartPoint - seg1.EndPoint
  16.             let vec2 = seg2.EndPoint - seg2.StartPoint
  17.             let angle = (Math.PI - vec1.GetAngleTo(vec2)) / 2.
  18.             let dist = radius * tan(angle)
  19.             if dist > seg1.Length || dist > seg2.Length then
  20.                 0
  21.             else
  22.                 let pt1 = seg1.EndPoint + vec1.GetNormal() * dist
  23.                 let pt2 = seg2.StartPoint + vec2.GetNormal() * dist
  24.                 let mutable bulge = tan(angle / 2.)
  25.                 if clockwise pt1 seg1.EndPoint pt2 then bulge <- -bulge
  26.                 pl.AddVertexAt(index, pt1, bulge, 0., 0.)
  27.                 pl.SetPointAt(index + 1, pt2)
  28.                 1
  29.
  30.     // Adds an arc (fillet) at each vertex, if able.
  31.     member pl.FilletAll radius =
  32.         let rec loop i =
  33.             if i < pl.NumberOfVertices then
  34.                 loop (i + 1 + pl.FilletAt i radius)
  35.         loop (if pl.Closed then 0 else 1)
krkec
« Reply #12 on: December 27, 2012, 04:43:46 PM »
Thanks i will try this code
can i ask for one more help.
i implemented your code  and added my own
here is my code:
Private Sub spoly_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles spoly.Click
        Dim doc As Document = DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim rad As Double = radius.Text
        Dim peo As New PromptEntityOptions(vbLf & "Select a polyline: ")
        peo.AddAllowedClass(GetType(Polyline), True)
        Dim per As PromptEntityResult = ed.GetEntity(peo)
        If per.Status <> PromptStatus.OK Then
            Return
        End If
        Dim kutevi As New DoubleCollection
        Dim tocke As New Point3dCollection
        Dim duljine As New DoubleCollection
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim pline As Polyline = DirectCast(tr.GetObject(per.ObjectId, OpenMode.ForWrite), Polyline)
            FilletAll(pline, rad)
            For i As Integer = 0 To pline.NumberOfVertices - 1
                If pline.GetSegmentType(i) = SegmentType.Arc Then
                    kutevi.Add(pline.GetArcSegment2dAt(i).EndAngle - pline.GetArcSegment2dAt(i).StartAngle)
                    Dim j As Integer = 1
                    Dim l12d As New LineSegment2d(pline.GetArcSegment2dAt(i).StartPoint, pline.GetArcSegment2dAt(i).EndPoint)
                    Dim vecv2d As Vector2d = (l12d.MidPoint - pline.GetArcSegment2dAt(i).Center)
                    Dim kut2 As Double = vecv2d.Angle
                    Dim x As Double = rad / Math.Cos((pline.GetArcSegment2dAt(i).EndAngle - pline.GetArcSegment2dAt(i).StartAngle) * 0.5)
                    Dim k As Point3d = PolarPoint(pline.GetArcSegmentAt(i).Center, kut2, x)
                    'tocke.Add(k)
                    Dim vl1 As New Line(pline.GetArcSegmentAt(i).StartPoint, k)
                    Dim VL2 As New Line(pline.GetArcSegmentAt(i).EndPoint, k)
                    tocke.Add(VL2.EndPoint)
                    MsgBox("x=" & k.X.ToString & " y=" & k.Y.ToString)
                    draw(HostApplicationServices.WorkingDatabase, vl1)
                    draw(HostApplicationServices.WorkingDatabase, VL2)
                End If
            Next
            tr.Commit()
        End Using
problem is with this
I constructed point
but when I do this MsgBox("x=" & k.X.ToString & " y=" & k.Y.ToString)
I get x=0 y = -2.35 or some thing simular wich is not true
line vl1 i vl2 uses k point and its ok  but for anything else isnt
Can you tell me thy?
gile
  • Marseille, France
« Reply #13 on: December 29, 2012, 12:35:07 PM »
I can't understand what point you're looking for, neither reading nor trying you code.
Could you attach a drawing showing some examples ?
krkec
« Reply #14 on: January 02, 2013, 01:52:38 PM »
 I solved that problem. Thanks for help
