Author Topic: Restore grdraw graphics after zoom?  (Read 3913 times)
roy_043
  • BricsCAD 18
« on: December 18, 2012, 06:22:32 AM »
I am trying to restore grdraw graphics after zoom, pan etc. The code below doesn't do the trick. After a zoom action the temp line is briefly visible but then disappears. My guess is that the CAD-program performs a redraw after the call-back. Tested on BricsCAD 13.
Is there a way to restore grdraw graphics? Or is the best course of action temporary xlines?
  1. ;;; Global list for testing, the list contains a point and an angle:
  2. (setq *TempGraphics_DataList* (list '(0.0 0.0 0.0)  (/ pi 4.0)))
  3.
  4. (setq *TempGraphics_acdbReactor*
  5.     nil ; No data.
  6.     '((:vlr-objectModified . TempGraphics_CallBack_Acdb_ObjectModified))
  7.   )
  8. )
  9.
  10. (defun TempGraphics_CallBack_Acdb_ObjectModified (rea lst / object)
  11.   (print "TempGraphics_CallBack_Acdb_ObjectModified")
  12.   (setq object (vlax-ename->vla-object (cadr lst)))
  13.   (if
  14.     (and
  15.       *TempGraphics_DataList*
  16.       (member
  17.         (strcase (vla-get-objectname object))
  18.         '("ACDBVIEWPORT" "ACDBVIEWPORTTABLERECORD")
  19.       )
  20.     )
  21.     (TempGraphics_Draw *TempGraphics_DataList*)
  22.   )
  23. )
  24.
  25. (defun TempGraphics_Draw (lst / pt ang)
  26.   (print "TempGraphics_Draw")
  27.   (setq pt (car lst))
  28.   (setq ang (cadr lst))
  29.   (redraw)
  30.   (grdraw pt (polar pt ang 1.0e6) 1 1) ; (grdraw <point> <point> <color> [<highlight>])
  31. )
  32.
irneb
Re: Restore grdraw graphics after zoom?
« Reply #1 on: December 18, 2012, 06:48:22 AM »
What you've noticed is exactly correct: A zoom / pan causes a redraw. So all grdraw's / grvec's will be "erased".
If your grdraw is simply a line from one side to another, then you "could" go for a "temporary" XLine - though then you're left with "When should it be deleted?"
Unfortunately I'm not sure of a reactor noticing when something like a scroll zoom / pan happened. Otherwise you could have simply redrawn the grdraw.
roy_043
  • BricsCAD 18
« Reply #2 on: December 18, 2012, 10:32:41 AM »
Actually my code does detect zoom and pan actions. That is not the issue. The problem is that there is an automatic redraw after the call-back.
The sequence seems to be:
- Zoom/scroll action is detected by the reactor.
- The call-back recreates the temp graphics.
- The CAD-program redraws the current view destroying the temp graphics.
Peter2
« Reply #3 on: November 04, 2019, 12:10:33 PM »
Hi roy_043
could you solve this challenge? I'm also looking for an reactor, creating grdraw after zoom commands...
Peter
BricsCAD V23
roy_043
  • BricsCAD 18
« Reply #4 on: November 04, 2019, 02:09:28 PM »
Peter2
« Reply #5 on: November 05, 2019, 03:02:24 AM »
I just started to experiment with "dcl-delayedInvoke" from Opendcl, and it looks fine:
http://www.opendcl.com/HelpFiles/index.php?lang=ENU&page=Reference/Function/DelayedInvoke.htm
  1. (defun TempGraphics_CallBack_Acdb_ObjectModified (rea lst / object)
  2.     (dcl-DelayedInvoke 100 "mima")    ; mima is a subroutine which "grdraws" a cross x in the middle of the screen
  3. )
Edit 1:
Actually the grdraw works fine, but the reactor fires 150 times for every "zoom extents". Have to take a look ..
« Last Edit: November 05, 2019, 05:45:11 AM by Peter2 »
Peter
BricsCAD V23
