Author Topic: Database.ObjectModified Event  (Read 15299 times)
BlackBox
« on: December 07, 2012, 04:42:43 PM »
I'm trying to learn more about the Database.ObjectModified Event, and have read from articles, blog posts, etc. to try and comprehend what I can.
One concept I'm seeking to have clarified, is the seeming importance of adding the e.DbObject.Id to an ObjectIdCollection for later action (as Tony points out here), rather than simply enacting changes on the matching/desired e.DBObject.Id.ObjectClass.Name via StartOpenCloseTransaction() within the ObjectModified Event handler itself (I've read of the No, No, of using StartTransaction() WRT REDO).
The (perhaps elementary?) scenario I'll use, is to select an entity in the drawing (of any type), and manually change it's layer, which then fires the Database.ObjectModified Event (as I have not registered an ObjectModified Event for that entity)... Then to prompt the user with something simple like:
Code - C#: [Select]
  1. acApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
  2.     e.DBObject.Id.ObjectClass.Name + " modified "
  3. );
In this scenario, no Command is invoked, thus I'm inclined to 'act' within the ObjectModified Event handler (via StartOpenCloseTransaction() )... Which seems not only logical, but pretty commonsensical to me, but again, I'm just learning - I could be completely wrong.
Sorry, simplest that I can come up with at the moment... Obviously, for an actual plug-in, further filtering, and action would ensue. Just trying further my learning... Code examples not expected, but always appreciated.
TIA
« Last Edit: December 07, 2012, 05:00:15 PM by RenderMan »
BlackBox
Re: Database.ObjectModified Event
« Reply #1 on: December 07, 2012, 05:45:16 PM »
I threw some pseudo code together to test the StartOpenCloseTransaction(), and all seemed to be working well... That is, once I added some logical conditions beforehand:
Code - C#: [Select]
  1.
  2. using Autodesk.AutoCAD.ApplicationServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.DatabaseServices;
  5. using Autodesk.AutoCAD.Internal;
  6. using Autodesk.AutoCAD.Runtime;
  7.
  8. using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
  9.
  10. using System;
  11.
  12. [assembly: ExtensionApplication(typeof(Foo.Bar))]
  13.
  14. namespace Foo
  15. {
  16.     class Bar: IExtensionApplication
  17.     {
  18.         void IExtensionApplication.Initialize()
  19.         {
  20.             DocumentCollection acDocs = acApp.DocumentManager;
  21.
  22.             // Normally I'd hook the DocumentCreated Event here
  23.
  24.             foreach (Document doc in acDocs)
  25.                 doc.Database.ObjectModified += onObjectModified;
  26.
  27.             acApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
  28.                 "\nObjectModifed demonstration "
  29.             );
  30.         }
  31.
  32.         void IExtensionApplication.Terminate()
  33.         {
  34.         }
  35.
  36.        // An onDocumentCreated Event handler would usually go here.
  37.
  38.         public static void onObjectModified(object sender, ObjectEventArgs e)
  39.         {
  40.             Editor ed = acApp.DocumentManager.MdiActiveDocument.Editor;
  41.
  42.             if (e.DBObject != null &&
  43.                 e.DBObject.IsErased != true &&
  44.                 e.DBObject.IsUndoing != true)
  45.             {
  46.                 string objName = e.DBObject.GetType().Name.ToString();
  47.
  48.                 if (Utils.WcMatch(objName, "MText,Text,*Leader"))
  49.                 {
  50.                     Entity ent = e.DBObject as Entity;
  51.
  52.                     ed.WriteMessage("\n[ObjectModified] : " + objName + " (" + ent.Layer + ") ");
  53.                 }
  54.             }
  55.         }
  56.
  57.     }
  58. }
  59.
  60.
... I'm sure there's something I've not yet thought of, or encountered. Again, this is only a working snippet.
« Last Edit: December 08, 2012, 04:11:09 PM by RenderMan »
TheMaster
« Reply #2 on: December 08, 2012, 03:46:38 PM »
Your code is using a transaction to get a managed wrapper for a currently-open database object for which you already have a managed wrapper for (the DBObject passed into the event handler).
There's no need to use a transaction in that case because the DBObject that is passed into the event handler is already open (and most-likely in state that would not allow it to be modified in any way), so you can use that DBObject directly.
« Last Edit: December 08, 2012, 03:52:08 PM by TT »
BlackBox
« Reply #3 on: December 08, 2012, 04:04:42 PM »
Thanks for the correction, Tony.
I was mistaken in thinking that the ObjectModified also implied that the ObjectClosed had occurred, and now better understand why you aptly suggested storing the ObjectId's for later action, but am unsure how to utilize that, given that no Command is being used.
I am attempting to hook the Database.ObjectModified Event, rather than manage adding an ObjectModified Event to each existing entity and all those appended to the Database thereafter.
... Is it possible to modify the Object via Database.ObjectModified, or need I register an entity level ObjectClosed Event handler during Database.ObjectModified (untested)?
TheMaster
« Reply #4 on: December 08, 2012, 06:11:31 PM »
Hard to say, without seeing the larger picture. What is it you are trying to accomplish?
BlackBox
« Reply #5 on: December 08, 2012, 06:45:52 PM »
Sorry for not being more clear in previous posts.
I'm toying with the idea of an 'AnnoAuto' plug-in that would (based on user-defined XML settings), automatically apply the desired annotation entity settings for each a Dimension, Leader, MText, MLeader, and Text entities, based upon the Layer these entities reside, or are placed upon.
For years I've used Command Reactors (Visual LISP) to automatically configure certain properties, current layer, etc. for me, and am now attempting to enhance that via .NET API features, and ease of gathering requirements via XML, etc..
Scenario: Add an MLeader to the drawing, where CLAYER = 0, then manually select the MLeader and move it to another layer, where that layer has predefined settings for each of the above entity types, and what settings should be applied. I'm basically attempting to make the Standards Command no longer necessary, and something that is applied during production, rather than manually invoked prior to save/close
My intent was to use the ObjectModified Event to trigger these pseudo-annotation standards being applied, but obviously need to interact (ForWrite) with the Objects themselves, and to (ForRead) access the MLeader Style, TextStyle, etc. ObjectId's as applicable via Transaction... Hope that makes (more?) sense.
TheMaster
« Reply #6 on: December 09, 2012, 12:56:54 AM »
Objects can be modified when there is no running command, so how did you handle that in LISP ?
BlackBox
« Reply #7 on: December 09, 2012, 01:10:31 PM »
That's the distinction, my LISP simply didn't have this functionality.
The Command Reactor would store the current setting like Clayer, etc. and check/make/set the needed layer for say XREFs and then restore when done. I never did spend the time proper to make this Annotation aspect work in LISP (not sure that it cannot), but am progressively working to move to .NET and using small ideas like this as pilots so to speak.
I'll have to read up on the available Database Events, to better formulate this idea, as I know there's fruit to e had from it (when I get it to work)... Without having to implement an event handler for each, and every annotation entity that exists, or is appended to the Database.
Perhaps I can use the Database.ObjectModified event to store the ObjectIds then use the Database.ObjectClosed event to 'act' (without having looked in Object Browser, as I am on my iPhone at the moment).
As always, I appreciate you time and feedback to ask questions that make me think this through rather than just giving me the answer so to speak. Cheers! :beer:
BillZndl
« Reply #8 on: December 10, 2012, 08:01:45 AM »
Very interesting subject and one I would like to know more about.
I ran into this same problem when I tried to work on an Object when the ObjectModified event fired,
(finding that the Object was not accessible as it was still open at this time(?)).
What I did was store the ObjectId in separate Class ObjectIdCollection on the ObjectModified event.
(C#)
void Database_ObjectAppended(object sender, ObjectEventArgs e)
            if (e.DBObject.GetType().Name.Equals("Group"))
                Module.GrpInfoTbl.Add(e.DBObject.ObjectId);
public class Module
        private static ObjectIdCollection OIDColl = new ObjectIdCollection();
        public static ObjectIdCollection GrpInfoTbl
            get
                return OIDColl;
        public Module()
Then when the command that did the modifying ended, would do the work on the ObjectIds contained therein using a separate method.
Not posting this as an example because I am only a "dabbler" in programming
but am hoping to learn more about this myself on how valid of a solution this would be for the problem.
BlackBox
« Reply #9 on: December 10, 2012, 09:42:22 AM »
Well, as it happens, there is no such Database.ObjectClosed Event (Oops).
So the best I can determine in a quick MgdDbg test this morning, when manually selecting an entity, and changing it's layer via Properties Palette, only raises the Database.ObjectOpenedForModify, and Database.ObjectModified Events.
When I have time during lunch, I will test two scenarios:
1.)  Not sure if it's possible to register a DBObject.ObjectClosed Event handler during Database.ObjectModified, given that the DBObject is already open.
2.)  If not, the only logical (dependable?) other idea I have is to store the ObjectIds to ObjectIdCollection during the Database.ObjectModified Event, and then attempt to 'act' during one of the Editor.PointFilter, or Editor.PointMonitor Events.  *not sure*
« Reply #10 on: December 10, 2012, 10:06:49 AM »
What I've used is to keep an ObjectIdCollection of modified Objects I need to act on, then do so when the Editor's EnteringQuiescentState event fires.
BlackBox
« Reply #11 on: December 10, 2012, 10:09:25 AM »
At least I was able to get in the correct vicinity on my own, thanks for the information, Jeff (as always)
BillZndl
« Reply #12 on: December 10, 2012, 03:29:17 PM »
Gives my confidence a boost also. Thanks!  :-D
« Reply #13 on: December 10, 2012, 03:46:40 PM »
I am still not following completely on why does it have to be changed during a modified event rather than doing it during insertion or creation.
Are you trying to keep people from modifying a entity or during  modifying set all properties?
BlackBox
« Reply #14 on: December 10, 2012, 04:12:46 PM »
Perhaps I can clarify... I don't need to do anything during Database.ObjectModified per-se, what I do need to do is to modify specific entity types if they're modified by the user, specifically without depending on a Command Event (i.e., a user selects an MLeader and changes it's layer via Properties Palette).
When doing this, there are only two Database Events that are raised, ObjectOpenedForModify, and ObjectModified... Since I cannot effectively employ UpgradeOpen() within ObjectModified (as the DBObject is no yet Closed), I am forced to store the desired ObjectIds to an ObjectIdCollection, then handle them after the fact.
As I am sure most companies do, we have different text hights/styles (Small, Medium, Large, etc.) and we place them each on specific layers. I often copy a label and manually place it on another layer... It's at this point that I want my plug-in to automagically correct the necessary 'standards' for that entity type when I change it's layer (based upon my XML settings for that particular layer), without the need for running a supplementary custom Command, let alone the Standards Command prior to drawing close.
This would allow for me to catch/filter/enforce these pseudo-annotation standards on the fly, including vanilla, LISP Commands, etc., and further, easily allow me to quickly customize a new 'standard' for each Client as needed, as the XML settings are loaded via valid FindFile() result.
I've got EnteringQuiescentState working to a point, but need more time to work out how to better manage the ObjectIdCollection handling to ensure that handled ObjectIds are in fact removed properly... Still working through the logic (on my part)... Checking for Contains(id), etc., and wanting to compare EnteringQuiescentState to ObjectClosed at entity level (for my own edification, and learning purposes), etc, etc..
« Last Edit: December 10, 2012, 04:45:12 PM by RenderMan »
