Author Topic: Something newer than 2013?  (Read 2559 times)
« on: November 30, 2012, 02:18:57 PM »
Thought this was odd. Got this dwg from someone else.
Drafter X
Re: Something newer than 2013?
« Reply #1 on: November 30, 2012, 02:36:43 PM »
In created by it doesn't say 'The Doctor' does it?
CadJockey Militia Commander
« Reply #2 on: November 30, 2012, 02:59:33 PM »
Negative ....
« Reply #3 on: November 30, 2012, 03:01:34 PM »
Auditing Entities Pass 1
Pass 1 20200   objects auditedAeccDbRootSettingsNode(3FEB2)     was not repaired.
Pass 1 22500   objects audited
Auditing Entities Pass 2
Pass 2 20200   objects auditedAeccDbRootSettingsNode(3FEB2)     was not repaired.
Pass 2 22500   objects audited
Auditing Blocks
 109     Blocks audited
Auditing AcDsRecords
Total errors found 2 fixed 0
Erased 0 objects
« Reply #4 on: November 30, 2012, 03:04:42 PM »
Fixing those errors didn't change anything. :(
huiz
  • Certified Prof C3D
« Reply #5 on: November 30, 2012, 03:45:30 PM »
I've seen this before, but can't remember when. I think it has something to do with AEC objects. The message of Civil3D doesn't mean there is Civil3D 2014 yet, but just a general message that it can't read the AEC objects. It might be a drawing from MEP, Revit, or something else that contains other object types, for which you don't have an object enabler for.
