Author Topic: Set the default hatch pattern  (Read 5352 times)
Fabricio28
« on: November 30, 2012, 07:28:07 AM »
Hi guys!!
How Can I add solid hatch in ALIASEDIT to use it as  shortcut key??
Thank you.
Regards
 :kewl:
« Last Edit: November 30, 2012, 11:45:17 AM by FABRICIO28 »
Fabricio28
Re: SOLID HATCH
« Reply #1 on: November 30, 2012, 08:56:51 AM »
Hi guys,
How Can I change the hatch of the default??
I'd like to change ANGLE to SOLID.
Thanks.
Krushert
  • FREE BEER Tomorrow!!
Re: SOLID HATCH
« Reply #2 on: November 30, 2012, 11:26:54 AM »
What version of Autocad are you using?
Check out this for setting the hatch for 2012?
http://autocadtips.wordpress.com/2012/01/03/set-the-default-hatch-pattern/
Fabricio28
Re: Set the default hatch pattern
« Reply #3 on: November 30, 2012, 11:42:41 AM »
Thanks for replay, Krushert
I'm using AutoCad 2012.
This link above didn't help me, to be honest.
Because after I've set "SOLID" in HPNAME command, when I opened a new drawing I had to do it again.
Is there other alternative to set the default hatch pattern permanent?
« Reply #4 on: November 30, 2012, 12:09:03 PM »
From the AutoCAD help:
HPNAME (System Variable)
Sets the default hatch pattern name.
Type:   String
Saved in:   Not-saved
Initial value:   ANSI31 (imperial) or ANGLE (metric)
If you have an acad*.lsp file just add (setvar 'hpname "solid") to it and you should be good.
JNieman
« Reply #5 on: November 30, 2012, 12:39:15 PM »
That will only really work for the first time you call up the hatch routine, and so long as you only use solid hatches.
As soon as you use a different hatch pattern, that will be your new 'default hatch' - it seems the behavior of Autocad is to start with ANSI31, to start with, and then just "default to last pattern" after that.  Every time I call up the hatch command dialog, it defaults to the pattern I last selected with the hatch dialog.
Fabricio28
« Reply #6 on: November 30, 2012, 12:53:03 PM »
Thanks all of you, guys.
Type:   String
Saved in:   Not-saved
I've added (setvar 'hpname "solid") into my acad*.lsp file.
Problem solved.
Thank you for the good explanation.
 :wink:
« Reply #7 on: November 30, 2012, 01:07:46 PM »
Glad to help  8-)
