Author Topic: More beta testing  (Read 10311 times)
More beta testing
« Reply #15 on: December 12, 2003, 03:07:13 PM »
Nope, both beta's. Different apps all together.
BTW, thanks to all of participating.
Craig
More beta testing
« Reply #16 on: December 12, 2003, 03:33:07 PM »
Quote from: rugaroo
Ahhhhh man...got my hopes up and all I do is fail...back to the design stage for me :)
All well...I will be the nice guy here, and let you all try and find ways to tweak this one...
(DEFUN RUG-TEST (/ cmd)
  (SETQ cmd (GETVAR "cmdecho"))
  (ALERT "\nAttempting to do your work for you...")
  (ALERT "\nPlease click OK to continue.")
  (SETVAR "cmdecho" 0)
  (command "-layer" "s" "0" "")
  (princ "\n")
  (COMMAND "-layer" "off" "*" "y" "")
  (ALERT "\nAutocad failed to do your work for you.")
  (ALERT "\nNow get back to work you lazy person!")
  (ALERT
    "\nAutocad failed to save any of you work. Now exiting."
  (SETVAR "cmdecho" cmd)
  (COMMAND "quit" "y")
  (PRINC)
Pretty lame, but you'd be suprised how well it works on newbies.  :twisted:
Rug
Hey I already have a button that does almost the same thing
rugaroo
  • The Other CAD Guy
More beta testing
« Reply #17 on: December 12, 2003, 03:36:28 PM »
Buttons are too much of a hassel...better to make the user try to remember all of the key on the keboard first...People have to remember that not everything can be done with a mouse, and if you are really 'anal retentive' then nothing is done with the mouse. :)
LDD06-09 | C3D 04-19 | Infraworks 360 | VS2012-VS2017
hendie
More beta testing
« Reply #18 on: December 15, 2003, 05:07:56 AM »
Command: _appload MST-ABC.VLX successfully loaded.
Command:
then....
edited because I should read things properly first !
thankyou for being my beta tester
Make a note of this number -> 1523356899
'och
More beta testing
« Reply #19 on: December 15, 2003, 06:56:35 AM »
Thank you for being my beta tester
Make note of this number-> 1523356899
More beta testing
« Reply #20 on: December 15, 2003, 09:48:27 AM »
Sorry i didnt see this thread.
It worked for me too mark.
