Author Topic: loading lisp routines  (Read 11523 times)
« Reply #15 on: March 09, 2005, 05:19:36 PM »
Quote from: danny
< .. >kerry,
that found the path
Command: (findfile"35.lsp")
"G:\\AutoCADD misc\\lisp files\\UCS&Crosshairs\\35.lsp"
so now how about this ?
(if (setq tmp  (findfile"35.lsp") ) (load tmp) (prompt "woooooooops"))
« Reply #16 on: March 09, 2005, 05:23:15 PM »
Load this --
(defun *error* (msg) (vl-bt))
Now, what do these two statements output --
(load "G:\\AutoCADD misc\\lisp files\\UCS\\35.lsp")
(load "35.lsp")
danny
« Reply #17 on: March 09, 2005, 05:32:25 PM »
ok. I think i got it.
if I put this in the folder
;loads lisps at start-up
;loads lisps from directory -- "G:\\AutoCADD misc\\lisp files\\UCS"
(defun s::startup()
  (load "lisp here")
  (load "lisp here")
then ACAD will find the files.  This is similar to what dan posted earlier.
« Reply #18 on: March 09, 2005, 05:55:32 PM »
MP, this is weird.
I have never used ampersand in folder names, so I tried it ...
Command: (findfile"test_load.lsp")
"F:\\This&That\\test_load.lsp"
Command: (if (setq tmp (findfile"test_load.lsp") ) (load tmp) (prompt "woooooooops"))
 Here We are, all together again ..
nil
Command: (load "test_load.lsp")
nil
Not a problem ... Weird, heh ..
WinXP Pro SP2
« Reply #19 on: March 10, 2005, 12:57:55 AM »
That is weird Kerry. Sorry, I cant provide concrete examples, I have a vague recollection that some dos operations ( i.e. bat files ) went wonky with ampersands. I could be mistaken tho.
ELOQUINTET
« Reply #20 on: March 10, 2005, 08:50:02 AM »
danny yeah you just put this one lisp in your startup suite and add to it as you see fit. like i say this has worked the best for me
sinc
Re: loading lisp routines
« Reply #21 on: March 10, 2005, 12:13:09 PM »
Quote from: danny
I have my ACAD search path browsing to a folder which contains .lsp files and .mns file.  For some reason ACAD does not recognize the .lsp files.  How can I get this to work?
Just to be clear, by your "ACAD search path", you mean the "Support File Search Path" listing in the options dialog you get by typing OP, right?  Or are you talking about something else?
CADaver
« Reply #22 on: March 10, 2005, 12:33:24 PM »
Quote from: danny
Still doesn't reconize the .lsp files in that folder.  ... ACAD will not reconize it.
Okay, I'm slow, what do you mean by "recognize it"?  Is it not showing up in the appload list or what?
A lisp routine has to be loaded before it will function. Just placing the lisp file in a certain directory won't load it.
If you want deman-loading look into autoload.
In you MNL or ACAD.LSP add lines similar to these:
(autoload "e:/programs/ac2002/menus/csa/UTE.lsp" '("ute"))
(autoload "e:/programs/ac2002/menus/csa/PLOTTABS.lsp" '("PLOTTABS" "PLTB"))
(autoload "e:/programs/ac2002/menus/csa/lisp/xrbg.lsp" '("xrbg"))
(autoload "E:/Programs/AC2002/Menus/csa/Lisp/cld.lsp" '("cldr" "cldh"))
If I enter the command CLDR or CLDH, the last autoload line above will load lisp function "E:/Programs/AC2002/Menus/csa/Lisp/cld.lsp", if it's not already loaded.  Notice that the keyboard entries match the defun names, not necessarily the function file name.
nivuahc
« Reply #23 on: March 10, 2005, 12:37:16 PM »
Quote from: CADaver
Quote from: danny
Same way mine works.
I've been using the method I posted since AutoCAD R9.
CADaver
« Reply #24 on: March 10, 2005, 12:44:16 PM »
Quote from: nivuahc
I tried something similar to yours long ago, but I noodled it up somehow.  It kept getting hung in a never-ending loading loop.  Before I could figure out what I had noodled up, I found autoload.
nivuahc
« Reply #25 on: March 10, 2005, 12:51:09 PM »
Well the autoload method sure is cleaner, that's for sure.
You know what they say though... if it ain't broke, hire an architect. No. Wait. 'If it ain't broke don't fix it". That's it!
And, in defense of architects who might have taken offense to my mild attempt at humor I'll offer the following quote:
"If you think good architecture is expensive, try bad architecture."
- Brian Foote and Joseph Yoder
« Reply #27 on: March 10, 2005, 02:25:31 PM »
So I just loaded 2006 and set up my installer to load all my routines. I use CAB's method of loading my lisp but am getting this:
; error: no function definition: AUTOLOAD
My install uses Acad install and inno setup.
 Should place drop down menu......but didn't.
I have an acad.lsp with:
(AUTOLOAD "a2c" '("a2c"))
(AUTOLOAD "abl" '("abl"))
(AUTOLOAD "acret" '("acret"))......
and in my mnl file:
(vl-vbaload (findfile "C:/Program Files/AutoCAD Tools/create_lyrs.dvb"))
(vl-vbaload (findfile "C:/Program Files/AutoCAD Tools/acad.dvb"))
(load "C:/Program Files/AutoCAD Tools/acad.lsp")
HMMMM???
Ron
TimSpangler
  • CAD Naked!!
« Reply #28 on: March 10, 2005, 02:39:39 PM »
I have seen this before, I had a program to remove a search path and i got hose and deleted the "Main Search Path"
C:\Documents and Settings\tspangle\Application Data\Autodesk\AutoCAD 2006\R16.2\enu\support
and when that happened it will give you this error.  Obviuosly your will be differant unless you logon is the same as mine, in which case "I know your password" :lol:
look to see if you have a search path like this
ACA 2015 - Windows 7 Pro
« Reply #29 on: March 10, 2005, 03:41:37 PM »
Tim,
I have that path in the support file seach paths??
Ron
