Author Topic: Frame viewport no display  (Read 14796 times)
vnanhvu
« on: November 15, 2012, 11:57:46 AM »
   Someone help me plz!
My drawing, in layout: Frame viewport no display.
Help me turn on Frame viewport
Thank you very much !
Tharwat
  • Hypersensitive
Re: Frame viewport no display
« Reply #1 on: November 15, 2012, 12:28:19 PM »
Select all with Cntrl+A and remove the viewport and create a new one .
« Reply #2 on: November 15, 2012, 12:49:55 PM »
The viewport is there just that it is the same color as the background.
You can still select it.
Or change the color of layer NETCAT.
vnanhvu
« Reply #3 on: November 15, 2012, 01:30:40 PM »
@Tharwat,CAB: i still cant select Frame Viewport. ( I dont see Viewport's Layer ) I change color Layer NETCAT but..no success...Hix :-(
« Reply #4 on: November 15, 2012, 01:48:11 PM »
Shot in the dark... try setting MAXACTVP to a larger number
« Reply #5 on: November 15, 2012, 03:04:01 PM »
Try the -vports command restore
Command: -vports
Specify corner of viewport or
[ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/2/3/4] <Fit>: r
Enter viewport configuration name or [?] <*Active>:
No that didn't work. Just created a new VP.
« Last Edit: November 15, 2012, 03:08:37 PM by CAB »
« Reply #8 on: November 15, 2012, 05:03:34 PM »
Looks like the easy way out.
I've looked at the dump vla & dxf & made some changes but still not visible.
Perhaps it was a clipped VP & somehow the pline reactor got disconnected from the VP.
Jeff_M
  • C3D user & customizer
« Reply #9 on: November 15, 2012, 05:14:36 PM »
This is what I determined as well. The VP says it is clipped, yet there is no Clipping object in the drawing. An Audit does not correct it, so not sure what is going on.
Cathy
« Reply #10 on: November 15, 2012, 05:28:27 PM »
I selected the viewport using Quick Select, then vpclipped it with that gray rectangle.  Then I used VPClip again to delete the clipping and the red viewport re-appeared.  So, yeah, it was something to do with the clipping.  But easier probably just to create a new vp.
Rod
« Reply #11 on: November 15, 2012, 09:26:17 PM »
I'm not in front of Autocad today. At my other job. But from memory if the clipping frame was created on a different layer to the viewport itself and the clipping object layer was frozen or off the viewport would still be visible but with no selectable frame.
Rod
"All models are wrong, some models are useful" - George Box
RolandOrzabal
  • "memories fade but the scars still linger"
« Reply #12 on: November 16, 2012, 01:14:12 AM »
weird?
 tried every possible way i know but still can't get the vport to show...
Stefan
  • The most I miss IRL is the Undo button
« Reply #13 on: November 16, 2012, 02:15:53 AM »
Try this:
1) delete polyline
2) select all (ctrl+A) (now, the only object selected should be your viewport)
3) use CLIP command, choose "P" and draw a frame around visible objects
4) Use CLIP again; select newly created frame; choose "Delete".
vnanhvu
« Reply #14 on: November 18, 2012, 11:13:43 AM »
  Thanks for all.
I fixed this error. I use command Vpmax ...and surprisingly, I was successful. Yeah...  :lmao:
