Author Topic: What does DIM mean?  (Read 5148 times)
HasanCAD
What does DIM mean?
« on: November 10, 2012, 11:10:08 PM »
What does DIM mean?
and what types of data can be declare in?
Re: What does DIM mean?
« Reply #1 on: November 10, 2012, 11:50:36 PM »
What does DIM mean?
Dim is a statement that declares and allocates storage space for one or more variables.
The type of data is declared seperately.
The usual format is :
Dim variableName As DataType
for more on DataTypes refer Visual Basic references on MSDN
HasanCAD
« Reply #2 on: November 11, 2012, 02:32:54 AM »
Thanks Kerry
fixo
« Reply #3 on: November 11, 2012, 11:15:25 AM »
Chuck Gabriel
« Reply #4 on: November 11, 2012, 10:20:10 PM »
Just for the sake of nostalgia, I'll add this time tidbit.  If memory serves, "dim" was originally short for "dimension," just like in autocad.
BlackBox
« Reply #5 on: November 12, 2012, 02:39:25 AM »
... Only unlike AutoCAD, "dimension" originates from FORTRAN, and even Dartmouth BASIC's need to dimension Arrays.
Later "declare in memory" was added as more data types were available.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #6 on: November 14, 2012, 07:26:15 PM »
DIM = someone with crazy ideas that could be considered dangerous   :laugh:
Just kidding
« Reply #7 on: November 14, 2012, 08:40:20 PM »
Quote from: Synonyms for Dim
blah, bleary, blurred, caliginous, cloudy, dark, dingy, dreary, dull, dusk, dusky, faded, faint, flat, fuzzy, gloomy, gray, ill-defined, indistinct, lackluster, lightless, mat, monotone, monotonous, murky, muted, obscured, opaque, overcast, pale, poorly lit, shadowy, sullied, tarnished, tenebrous, unclear, unilluminated, vague, weak
 :angel:
