Author Topic: Changing a Hyperlink PATH in block  (Read 2622 times)
krampaul82
« on: November 09, 2012, 11:17:25 AM »
Hey Swampers
I have about 1000 blocks that are hyperlinked to a specific PATH that will display a pdf cut sheet.
The PATH has now changed. does anyone know of a vba routine that can change the hyperlinks
without having to use the block editor properties to change the path of the hyperlinked file? as well as the properties hyperlink PATH?  I have posted on the lisp board as well any help appreciated! :|
