Author Topic: What is the equivalent namespace for AutoCAD 2013?  (Read 3862 times)
cannorth
« on: November 08, 2012, 10:51:05 AM »
Hello,
  I used this before in AutoCAD R12 as an expression:
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
  Now it doesn't seem to work in R13 anymore.  It doesn't recognize AcadDocument.  Does anyone know what
the equivalent form of this is in R13?
Thanks,
cannorth
« Last Edit: November 08, 2012, 02:41:53 PM by cannorth »
BlackBox
Re: What is the equivalent namespace for AutoCAD R13?
« Reply #1 on: November 08, 2012, 02:21:38 PM »
I think we had this issue before, where you mention R13, but you actually meant 2013, no?
If so, I believe that this is what you're after:
Code - C#: [Select]
  1. Autodesk.AutoCAD.Interop.AcadDocument
  2.
cannorth
Re: What is the equivalent namespace for AutoCAD 2013?
« Reply #2 on: November 08, 2012, 02:42:47 PM »
That didn't seem to work for me.
This is my code snippet from before:
            Dim doc As AutoCAD.AcadDocument = CType(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument, AcadDocument)
BlackBox
« Reply #3 on: November 08, 2012, 02:49:03 PM »
Did you add the necessary Interop assembly reference?
gile
  • Marseille, France
« Reply #4 on: November 08, 2012, 03:04:45 PM »
In the 2013 .NET API the AcadDocument property have been replaced by a GetAcadDocument() extension method.
Try:
Code - vb.net: [Select]
  1. Imports Autodesk.AutoCAD.ApplicationServices.DocumentExtension
  2. ...
  3.     Dim doc As AutoCAD.AcadDocument = _
  4.         CType(Application.DocumentManager.MdiActiveDocument.GetAcadDocument(), AcadDocument)
« Last Edit: July 28, 2013, 04:01:03 AM by gile »
BlackBox
« Reply #5 on: November 08, 2012, 03:19:22 PM »
I do not have 2013 software - Thanks for the correction, Gile.  :-)
