Author Topic: s the Autodesk Exchange already not support the VBA plugins?  (Read 1570 times)
Andrey Bushman
« on: October 29, 2012, 07:34:02 AM »
I don't see the "VBA" variant for AppType on this page. Is the Autodesk Exchange already not support the VBA plugins, or is it misprint in documentation?
Re: s the Autodesk Exchange already not support the VBA plugins?
« Reply #1 on: October 29, 2012, 07:38:54 AM »
Yes Andrey, it surprised me a little too.
Andrey Bushman
« Reply #2 on: October 29, 2012, 10:35:45 AM »
My next question about the same link.
For "AppType", we can assign values "Bundle" and "Dependency". I don't understand, why this variants is necessary (except ARX/DBX/.NET/LISP/MNU/CUI(X))...
But what I must set to "ModuleName" in this (both) cases?
P.S. It is a horrible, PackageContents.xml has not a XSD scheme. It is as run in a dark. And good examples is absent.
« Last Edit: October 29, 2012, 10:51:14 AM by Andrey »
