This is what I discovered :
When used SPLPUCS on spline obtained from ellipse, you should convert 2nd degree spline to 3rd degree, and change knot parametrisation to uniform... Only then spline will be processed to be projected on some relative UCS correctly...
If someone knows any better way, please reply...
