Author Topic: How to find a Integer number's prime root and exponent  (Read 16401 times)
chlh_jd
Re: How to find a Integer number's prime root and exponent
« Reply #15 on: October 11, 2012, 01:06:07 AM »
this one does not work with 144
(defun test (n / a b c)
  (setq a (1+ (fix (/ (log n) (log 2)))))
  (while (setq a (1- a)
       c (expt n (/ 1. a))
       b (fix (+ c 0.5))
       c (not (equal (/ c b) 1 1e-8))
  (list b a)
posting just to demonstrate another approach
Thanks VovKa .
If num = 18
(test 18) ;;  -->' (18 1) not Prime factor .
chlh_jd
« Reply #16 on: October 11, 2012, 02:02:01 AM »
Hi , This my test result .
Num = 19487171
_$
;;QuickBench function see here http://www.theswamp.org/index.php?action=dlattach;topic=42091.0;attach=22832
Benchmarking ..... done for 32768 iterations. Sorted from fastest.
Statement                                Increment  Time(ms) Normalize  Relative
(#<USUBR @000000002d519ef8 SF:PF2> 1...)     32768      1840      1840      2.05
(#<USUBR @000000002d519d68 SF:PF> 19...)     16384      1061      2122      1.78
(#<USUBR @000000002d519d18 SS:PF> 19...)     16384      1310      2620      1.44
(#<USUBR @000000002d519db8 VK:PF> 19...)     16384      1701      3402      1.11
(#<USUBR @000000002d519e08 LM:PF> 19...)     16384      1887      3774      1.00
; 11 表格 从 #<editor "C:/Users/CLH/Desktop/prime-root.LSP"> 加载
_$
Num = 48828125
(#<USUBR @000000002d519368 SF:PF2> 4...)     32768      1778      1778      2.35
(#<USUBR @000000002d519188 SS:PF> 48...)     16384      1093      2186      1.91
(#<USUBR @000000002d5191d8 SF:PF> 48...)     16384      1216      2432      1.72
(#<USUBR @000000002d519228 VK:PF> 48...)     16384      1341      2682      1.56
(#<USUBR @000000002d519278 LM:PF> 48...)      8192      1046      4184      1.00
_$
« Last Edit: October 15, 2012, 11:07:22 PM by chlh_jd »
« Reply #17 on: October 11, 2012, 08:52:44 AM »
Nice code , Lee . Thank you very much .
This is the second time I saw this function 'Assoc++' is a wonderful application , (First in LM:give_change) :-)
Thank you - though the performance of my function pales in comparison to Stefan's code, since my more 'modular' approach is repeatedly iterating over previously factorised primes as noted above...
The 'assoc++' function is very useful indeed, I've utilised this construct in many of my applications - here is a generalisation of the function, if you are interested.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #18 on: October 11, 2012, 10:41:01 AM »
Hi all!
why in the name of the topic has not {Challenge}??
I think I missed the fun...
« Last Edit: October 11, 2012, 10:48:01 AM by ElpanovEvgeniy »
chlh_jd
« Reply #19 on: October 12, 2012, 02:30:37 AM »
In fact, I often follow with interest  about your site .
I'm sorry to have not been any traces , And thank you again .
chlh_jd
« Reply #20 on: October 12, 2012, 02:36:22 AM »
Hi all!
The question really is I would like to ask (though my poor english ).
I've been looking forward to your wonderful code  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: October 15, 2012, 10:03:48 AM »
my version
  1. (defun eea (n)
  2.   (defun f (n x y)
  3.     (cond ((or (> 1 n)(> x n)) nil)
  4.           ((zerop (rem n x)) (f (/ n x) x (1+ y)))
  5.           ((> y 0) (cons (list x y) (f n 2 0)))
  6.           ((f n (+ 1 x (rem x 2)) 0))
  7.     )
  8.   )
  9.   (f n 2 0)
  10. )
chlh_jd
« Reply #22 on: October 15, 2012, 10:05:24 PM »
my version
  1. (defun eea (n)
  2.   (defun f (n x y)
  7.     )
  8.   )
  9.   (f n 2 0)
  10. )
Hi , Evgeniy .
Yours can't seem to get rigtht result (prime-root and it's exponent , or named prime factors) .
(eea 19683) ;; --> NIL      must '(3 9)
(eea 19487171) ;; -->NIL  must '(11 7)
(eea 48828125) ;; -->NIL  must  '(5 11)
(eea 256) ;; --> NIL          must  '(2 8)
(eea 144) ;; --> NIL         must NIL
(eea 18) ;; --> '((2 4))     must 'NIL
« Reply #23 on: October 15, 2012, 10:26:00 PM »
Num = 48828125
_$
chlh_jd,
I can't understand your presentation of processing times.
Can you please post or link to your code.
Note: personally I use a modified verson of MP's Benchmark program.
I've modified Michaels build so that the fastest version is base 1.0 and other times are relative to that.
ie:
if the fastest takes 1000 and the slowest takes 4100 then the relative time is 1.0 for the fastest and 4.1 for the slowest ... so the relative ratio represents the longer processing time.
...  the slowest takes 4.1 times as long to process.
Regards
chlh_jd
« Reply #24 on: October 15, 2012, 11:01:17 PM »
Num = 48828125
_$
chlh_jd,
ie:
Regards
I'm sorry to miss the link , I'll add it .
Thanks Kerry for notice , This function QuickBench From theswamp, I have not changed anything .
Can you send your comparison function, thanks a lot .
« Last Edit: October 15, 2012, 11:08:08 PM by chlh_jd »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #25 on: October 16, 2012, 02:27:08 AM »
I'm sorry, the first time was not accurate ...
  1. (defun eea (n)
  2.   (defun f (n x y)
  3.     (cond ((= n 1) (list x y))
  5.           ((or (> x n)(and (> y 0) (f n 2 0))) nil)
  7.     )
  8.   )
  9.   (f n 2 0)
  10. )
« Last Edit: October 16, 2012, 02:33:24 AM by ElpanovEvgeniy »
« Reply #26 on: October 16, 2012, 06:12:14 AM »
I thought you were looking for the prime factorisation... i.e.
_$ (prime_factors2 19683)
((3 9))
_$ (prime_factors2 19487171)
((11 7))
_$ (prime_factors2 48828125)
((5 11))
_$ (prime_factors2 256)
((2 8))
_$ (prime_factors2 144)
((2 4) (3 2))
_$ (prime_factors2 18)
((2 1) (3 2))
Or have I misunderstood the task?
ribarm
  • Marko Ribar, architect
« Reply #27 on: October 16, 2012, 06:50:21 AM »
If you checked first (eea n), you'll see that later he omitted some good lines :
  1. (defun primefactors-eea ( n )
  2.   (defun f ( n x y )
  3. ;    (cond ((= n 1) (list x y))
  4.     (cond ((= n 1) (list (list x y)))
  5.           ((zerop (rem n x)) (f (/ n x) x (1+ y)))
  6. ;          ((or (> x n)(and (> y 0) (f n 2 0))) nil)
  7.           ((> y 0) (cons (list x y) (f n 2 0)))
  8.           ((f n (+ 1 x (rem x 2)) 0))
  9.     )
  10.   )
  11.   (f n 2 0)
  12. )
  13.
But it can't do recursion for large numbers like 9876543210 and yours Lee can... :wink:
M.R. on Youtube
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: October 16, 2012, 07:41:13 AM »
old
  1. (defun eea (n)
  2.   (defun f (n x y)
  3.     (cond ((> 1 n) nil)
  6.           ((> x n) nil)
  7.           ((f n (+ 1 x (rem x 2)) 0))
  8.     )
  9.   )
  10.   (f n 2 0)
  11. )
« Reply #29 on: October 16, 2012, 08:11:38 AM »
old
  1. (defun eea (n)
  2.   (defun f (n x y)
  6.           ((> x n) nil)
  8.     )
  9.   )
  10.   (f n 2 0)
  11. )
  1. ((> y 0) (cons (list x y) (f n 2 0)))
Could become:
  1. ((> y 0) (cons (list x y) (f n x 0)))
Since all factors less than x have already been factored out.
Nice code :-)
