Author Topic: How to find a Integer number's prime root and exponent  (Read 16398 times)
chlh_jd
« on: October 10, 2012, 10:22:48 AM »
Hi All
There is a Ineger number , how to find it's prime root and exponent ?
If function Foo to solve it .
(Foo 19683) --> '(3 9) ;;(expt 3 9) = 19683
(Foo 19487171) -->'(11 7) ;; (expt 11 7) = 19487171
(Foo 48828125 ) -->'(5 11) ;; (expt 5 11) = 48828125
(Foo 256) --> '(2 8)  ;; (expt 2 8) = 256
(Foo 144) --> NIL ;;(expt 12 2) = 144 , But 12 is not Prime Number .
« Last Edit: October 10, 2012, 10:26:03 AM by chlh_jd »
chlh_jd
Re: How to find a Integer number's prime root and exponent
« Reply #1 on: October 10, 2012, 12:07:38 PM »
my version
(defun is-prime (n / foo)
  (defun foo  (n try)
    (if (= n try)
      T
      (if (zerop (rem n try))
nil
(foo n (+ try 1))
  (foo n 2)
(defun is-power (num n / foo)
  (setq num (float num))
  (defun foo (num n i)
     (cond ((= num 1)
    i)
   ((> num 1)
    (foo (/ num n) n (1+ i))
  (foo num n 0))
(defun prime-root (num / foo)
  ;; by GSLS(SS) 2012-10-10
  (defun foo (num n / i)
    (cond ((and (= (rem num n) 0)
(is-prime n)
(setq i (is-power num n))
(> i 0))
   (list n i))
  ((<= n num)
   (foo num (1+ n)))))
  (foo num 2)
(prime-root 19683) ;; --> '(3 9)
(prime-root 19487171) ;; -->'(11 7)
(prime-root 48828125) ;; --> '(5 11)
(prime-root 256) ;; --> (2 8)
(prime-root 144) ;; --> NIL
chlh_jd
« Reply #2 on: October 10, 2012, 12:11:24 PM »
But somewhat surprisingly, this can not return value ?
(prime-root (expt 11 20))
Is it a Vlisp  BUG ?
(rem (expt 11 20) 11) --> 6
(rem (expt 11. 20) 11) --> 7.0
dgorsman
« Reply #3 on: October 10, 2012, 02:03:41 PM »
When you provide a number as "6" to a function, its considered an integer.  If you provide a number as "6.0" its considered a real.  When LISP does math on two integers, the result is typically an integer; when one of the values is a real the result is a real.  Sometimes you need to force values from integers to reals in order to get desired results.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Stefan
« Reply #4 on: October 10, 2012, 02:59:15 PM »
For reasonable integers
  1. (defun prime_factors (n / x l old)
  2.   (setq x 2)
  3.   (while (> n 1)
  4.     (if (zerop (rem n x))
  5.       (setq n (/ n x)
  6.             l (if (setq old (assoc x l))
  7.                 (subst (list x (1+ (cadr old))) old l)
  8.                 (cons (list x 1) l)
  9.                 )
  10.             )
  11.       (if (> (setq x (if (= x 2) 3 (+ 2 x))) (sqrt n)) (setq x n))
  12.       )
  13.     )
  14.   (reverse l)
  15.   )
_$ (prime_factors 19683) ->((3 9))
_$ (prime_factors 19487171)->((11 7))
_$ (prime_factors 48828125)->((5 11))
_$ (prime_factors 256)->((2 8))
_$ (prime_factors 144)>((2 4) (3 2))
« Reply #5 on: October 10, 2012, 03:26:03 PM »
  1. (defun primefactors ( n / f i p l )
  2.     (setq f 1
  3.           i n
  4.     )
  5.     (while (< f i)
  6.         (setq p (lowestprimedivisor n)
  7.               f (* f p)
  8.               n (/ i f)
  9.               l (assoc++ p l)
  10.         )
  11.     )
  12.     l
  13. )
  14.
  15. (defun assoc++ ( x l / a )
  16.     (if (setq a (assoc x l))
  17.         (subst (list x (1+ (cadr a))) a l)
  18.         (cons  (list x 1) l)
  19.     )
  20. )
  21.
  22. (defun lowestprimedivisor ( n / i r c )
  23.     (if (= 0 (rem n 2))
  24.         2
  25.         (progn
  26.             (setq i 1
  27.                   r n
  28.                   c (fix (1+ (sqrt n)))
  29.             )
  30.             (while (< (setq i (+ 2 i)) c)
  31.                 (if (= 0 (rem n i))
  32.                     (setq r i i c)
  33.                 )
  34.             )
  35.             r
  36.         )
  37.     )
  38. )
  39.
_$ (primefactors 19683)
((3 9))
_$ (primefactors 19487171)
((11 7))
_$ (primefactors 48828125)
((5 11))
_$ (primefactors 256)
((2 8))
_$ (primefactors 144)
((3 2) (2 4))
« Reply #6 on: October 10, 2012, 03:57:50 PM »
Nice code Stefan (as always)  8-)
VovKa
  • Ukraine
« Reply #7 on: October 10, 2012, 04:21:32 PM »
this one does not work with 144
(defun test (n / a b c)
  (setq a (1+ (fix (/ (log n) (log 2)))))
  (while (setq a (1- a)
       c (expt n (/ 1. a))
       b (fix (+ c 0.5))
       c (not (equal (/ c b) 1 1e-8))
  (list b a)
posting just to demonstrate another approach
« Last Edit: October 10, 2012, 06:13:34 PM by VovKa »
« Reply #8 on: October 10, 2012, 04:59:04 PM »
An optimisation of Stefan's code:
  1. (defun prime_factors2 ( n / d l x )
  2.     (setq x 2)
  3.     (while (< 1 n)
  4.         (setq d 0)
  5.         (while (zerop (rem n x))
  6.             (setq d (1+ d)
  7.                   n (/ n x)
  8.             )
  9.         )
  10.         (if (< 0 d)
  11.             (setq l (cons (list x d) l))
  12.         )
  13.         (if (< 1 (sqrt n) (setq x (if (= x 2) 3 (+ 2 x))))
  14.             (setq l (cons (list n 1) l)
  15.                   n 0
  16.             )
  17.         )
  18.     )
  19.     (reverse l)
  20. )
Stefan
« Reply #9 on: October 10, 2012, 05:00:16 PM »
Thank you very much Lee.
Looking at your code, I suggest to call lowestprimedivisor with 2 args, in which the second would be the last known divisor.
You don't need to check [again] lower than that, as they are already factorized.
Stefan
« Reply #10 on: October 10, 2012, 05:19:12 PM »
  2.     (setq x 2)
  3.     (while (< 1 n)
  4.         (setq d 0)
  6.             (setq d (1+ d)
  7.                   n (/ n x)
  8.             )
  9.         )
  10.         (if (< 0 d)
  12.         )
  15.                   n 0
  16.             )
  17.         )
  18.     )
  19.     (reverse l)
  20. )
That make sense, since a multiple divisor  can be found in consecutive steps.
Anyway, I still looking for a better method to find the next divisor, since I think my method is highly inefficient.
« Reply #11 on: October 10, 2012, 05:44:02 PM »
The problem reduces to finding a sequence of primes...  :|
chlh_jd
« Reply #12 on: October 11, 2012, 12:34:35 AM »
Thanks dgorsman , I there a way to solve the deviation of expt function ?
chlh_jd
« Reply #13 on: October 11, 2012, 12:50:17 AM »
  2.   (setq x 2)
  3.   (while (> n 1)
  5.       (setq n (/ n x)
  9.                 )
  10.             )
  12.       )
  13.     )
  14.   (reverse l)
  15.   )
Thanks Stefan , thank you very much .
1+
chlh_jd
« Reply #14 on: October 11, 2012, 12:55:15 AM »
  2.     (setq f 1
  3.           i n
  4.     )
  5.     (while (< f i)
  7.               f (* f p)
  8.               n (/ i f)
  9.               l (assoc++ p l)
  10.         )
  11.     )
  12.     l
  13. )
  14.
  19.     )
  20. )
  21.
  24.         2
  25.         (progn
  26.             (setq i 1
  27.                   r n
  29.             )
  32.                     (setq r i i c)
  33.                 )
  34.             )
  35.             r
  36.         )
  37.     )
  38. )
  39.
((3 9))
((11 7))
((5 11))
((2 8))
((3 2) (2 4))
Nice code , Lee . Thank you very much .
This is the second time I saw this function 'Assoc++' is a wonderful application , (First in LM:give_change) :-)
