Author Topic: Erase segments from polyline  (Read 15327 times)
cadplayer
« on: October 01, 2012, 10:23:30 AM »
Hi!
I´ve done here a simple routines which can erase segments in a polyline. My problem is, sometimes works break command not rigtht. Know anybody a better way to can do program it.
I only want erase a picked segment in a polyline but not explode line because I need them som Polyline.
  (while
    (setq obj (entsel "\nselect Breakobject! ")
  en (car obj)
  pt (car (cdr obj))
      (or
(equal (cdr (assoc 0 (entget en))) "POLYLINE")
(equal (cdr (assoc 0 (entget en))) "LWPOLYLINE")
(setq i  (fix (vlax-curve-getParamAtPoint en
(vlax-curve-getClosestPointTo en pt)
      p1 (vlax-curve-getPointAtParam en i)
      p2 (vlax-curve-getPointAtParam en (1+ i))
(list p1 p2)
    (command "_BREAK" obj "_F" p1 p2)
pBe
Re: Erase segments from polyline
« Reply #1 on: October 01, 2012, 10:41:49 AM »
Hi!
My problem is, sometimes works break command not rigtht...
What constitute a "not right" break?
« Reply #2 on: October 01, 2012, 10:51:20 AM »
The 'cheats' way:
  1. (defun c:delseg ( / e )
  2.     (if (and (setq e (entsel "\nSelect LWPolyline: "))
  3.              (= "LWPOLYLINE" (cdr (assoc 0 (entget (car e)))))
  4.         )
  5.         (command "_.trim" e "" e "")
  6.     )
  7.     (princ)
  8. )
pBe
« Reply #3 on: October 01, 2012, 11:01:53 AM »
The 'cheats' way:
  4.         )
  6.     )
  7.     (princ)
  8. )
 :lol:   i was about to suggest that. trying to understand what is the "not right" break? I was hoping there's more to it that just that?
« Reply #4 on: October 01, 2012, 11:44:05 AM »
Or perhaps:
  1. ;; Delete LWPolyline Segment  -  Lee Mac
  2. (defun c:delseg ( / e h l p )
  3.     (if
  4.         (and
  5.             (setq l (entsel "\nSelect LWPolyline: "))
  6.             (= "LWPOLYLINE" (cdr (assoc 0 (entget (setq e (car l))))))
  7.         )
  8.         (progn
  9.             (setq p (trans (cadr l) 1 0)
  10.                   p (trans
  11.                         (vlax-curve-getpointatparam e
  12.                             (1+ (fix (vlax-curve-getparamatpoint e (vlax-curve-getclosestpointto e p))))
  13.                         )
  14.                         0 e
  15.                     )
  16.                   p (list 10 (car p) (cadr p))
  17.                   e (entget e)
  18.                   h (reverse (cons (assoc 210 e)  (member (assoc 39 e) (reverse e))))
  19.                   e (vl-remove (assoc 210 e) (cdr (member (assoc 39 e) e)))
  20.             )
  21.             (if (= 1 (logand 1 (cdr (assoc 70 h))))
  22.                 (entmod
  23.                     (append
  24.                         (subst (cons 70 (boole 4 1 (cdr (assoc 70 h)))) (assoc 70 h) h)
  25.                         (member p e)
  26.                         (reverse (cdr (member p (reverse e))))
  27.                     )
  28.                 )
  29.                 (progn
  30.                     (entmake (append h (member p e)))
  31.                     (entmake (append h (reverse (cdr (member p (reverse e))))))
  32.                     (entdel (car l))
  33.                 )
  34.             )
  35.         )
  36.     )
  37.     (princ)
  38. )
chlh_jd
« Reply #5 on: October 01, 2012, 04:39:48 PM »
Hi!
change
...(command "_BREAK" obj "_F" p1 p2)...
into
...(command "_BREAK" en  p1 p2)...
or
...(command "_BREAK"  p1 p2)...
cadplayer
« Reply #6 on: October 02, 2012, 07:21:19 AM »
Thanks at all. Very nice help from all ... it goes better now... 8-)
cadplayer
« Reply #7 on: October 17, 2012, 10:38:50 AM »
Lee your routines for delete segments in LwPolylines is very good.
I ´m wondering how could I do this with 3dPolylines. I find a sugestion in this code. Is it possible to can erase segment  from point segA to segE or there is another way.
(defun c:test ( /
  (setvar "OSMODE" 0)
      (= (cdr
           (assoc 0
                  (entget
                    (setq en (car
                               (setq pt (entsel "\nSelect Polyline "))
         "POLYLINE")
      (setq segN (abs (fix (vlax-curve-getendparam en)))) ; number of segments
      (setq vl-en (vlax-ename->vla-object en))
      (setq pt (vlax-curve-getClosestPointTo vl-en (cadr pt)))
      (setq segP (vlax-curve-getparamAtPoint vl-en pt))
      (setq segA (vlax-curve-getpointatparam vl-en (fix segP)))
      (setq segE (vlax-curve-getpointatparam vl-en (1+ (fix segP))))
« Reply #8 on: October 17, 2012, 02:49:31 PM »
Thank you  :-)
I'm wondering how could I do this with 3dPolylines.
A program could certainly be constructed to retrieve the set of VERTEX entities of a selected POLYLINE entity and proceed to manipulate the vertices based on the picked segment (as per my LWPOLYLINE program posted above), however, I cannot justify devoting voluntary time to such a project.
If this is intended as a shortcut for use in everyday drafting work, have you considered simply using the TRIM command as per my initial post?
cadplayer
« Reply #9 on: October 18, 2012, 02:25:32 AM »
Trim works good but bad if crossing a Polyline themselves, I think it´s better to do with break.
In this code I have problem only with 3d-Polylines sometimes I click on a segment but get wrong segment in routines. Have somebody a idea to program that better
(defun c:test ( /
               en
               vl-en
               pt
               segN
               segP
               segA
               segE
  (setvar "OSMODE" 0)
  (setq en (car (setq pt (entsel "\nSelect Polyline "))))
  (if (wcmatch (strcase (cdr (assoc 0 (entget en)))) "*POLYLINE")
      (command "_break" en segA segE)
    (princ "\nObject was not a Polyline")
vlax-curve-getEndParam give not right segmentnumber !?
Here is a example file you can test it.
« Last Edit: October 18, 2012, 02:51:09 AM by cadplayer »
« Reply #10 on: October 18, 2012, 06:57:12 AM »
Here is an example using the break command:
  1. (defun c:delsegbreak ( / l p )
  2.     (if
  3.         (and
  4.             (setq l (entsel "\nSelect Polyline: "))
  5.             (wcmatch (cdr (assoc 0 (entget (car l)))) "*POLYLINE")
  6.         )
  7.         (progn
  8.             (setq p
  9.                 (fix
  10.                     (vlax-curve-getparamatpoint (car l)
  11.                          (vlax-curve-getclosestpointto (car l) (trans (cadr l) 1 0))
  12.                     )
  13.                 )
  14.             )
  15.             (command "_.break" l "_F"
  16.                 "_non" (trans (vlax-curve-getpointatparam (car l)     p ) 0 1)
  17.                 "_non" (trans (vlax-curve-getpointatparam (car l) (1+ p)) 0 1)
  18.             )
  19.         )
  20.     )
  21.     (princ)
  22. )
cadplayer
« Reply #11 on: October 18, 2012, 07:34:40 AM »
Lee very good idea to transform points... but sorry I have the same scenario, I have to more think about it.
Is it a bug i vl-function that I don´t get right segment
(setq p
                   (fix
For example I click on the short segment in polyline and get p=0 but it´s 2
« Reply #12 on: October 18, 2012, 08:18:11 AM »
Its not a bug with the vlax-curve-* functions, try the following instead:
  2.     (if
  3.         (and
  6.         )
  7.         (progn
  8.             (setq p
  9.                 (fix
  11.                         (vlax-curve-getclosestpointtoprojection
  12.                             (car l)
  13.                             (trans (cadr l) 1 0)
  14.                            '(0.0 0.0 1.0)
  15.                         )
  16.                     )
  17.                 )
  18.             )
  19.             (command "_.break" l "_F"
  20.                 "_non" (trans (vlax-curve-getpointatparam (car l)     p ) 0 1)
  21.                 "_non" (trans (vlax-curve-getpointatparam (car l) (1+ p)) 0 1)
  22.             )
  23.         )
  24.     )
  25.     (princ)
  26. )
cadplayer
« Reply #13 on: October 18, 2012, 08:33:31 AM »
It goes... thank you so much Lee, you have done it perfect. It was maybe precision that vlax-curve-getClosestPointToProjection is in this case better.
Certanly I´m not realy understand so much with VisualLisp but I believe that explanation in "theswamp" is much better as from Autodesk.
Construction for beginners I´m missing :wink:
« Reply #14 on: October 18, 2012, 09:12:45 AM »
You're welcome  :-)
It was not a precision problem, but rather the difference in how vlax-curve-getclosestpointo and vlax-curve-getclosestpointtoprojection calculate the returned closest point.
vlax-curve-getclosestpointo will return the point given by the shortest 3D vector to the supplied curve; whereas  vlax-curve-getclosestpointtoprojection will project the curve to the plane with the supplied normal vector, before returning the point given by the shortest 2D vector to the projection of the curve in the plane.
Hopefully the following diagram is somewhat comprehensible:
