Hi all. I apologize for my bad English.
I have some questions about Table Style. Please, run the "_tablestyle" command. Will be opened "Table style" window. Press the "Modify..." button. Will be open "Modify table style" window. My questions is about this window some settings.
1. How can I get/set some values for Cell Style, such as:
1.1.
General tab of "Modify table style" window:
1.1.1. Which
formated string must I use for the set 'format' option for Cell Style?
[IS SOLVED] Click "..." button. Will be opened "Table Cell Format window".
Please, show me the examples of formated string for:
1. Data type: Angle, Format: Decimal degrees, Precission: 0.000
2. Data type: Decimal Number, Format: Decimal, Precission: 0.00
3. Data type: Percentage, Precission: 0.000, Append symbol: checked
4. Data type: Point, Format: Decimal, Precission: 0.00, List separator: ','(Comma), X: checked, Y: checked, Z: unchecked
5. Data type: Text, Format: Uppercase
6. Data type: Text, Format: First capital //customTableStyle is IAcadTableStyle
customTableStyle.SetFormat2("MyCellStyleName", "necessary formated string...");//???
1.1.2. How can I set '
horizontal/vertical margins' options for each Cell Style
individual?
[IS SOLVED] //Next changes will be applied not for "MyCellStyleName" but for other. How can I do it for "MyCellStyleName"?
customTableStyle.HorzCellMargin = 1;
customTableStyle.VertCellMargin = 1;
1.2.
Borders tab of "Modify table style" window:
1.2.1. How can I set '
Linetype' option for Cell Style?
[IS SOLVED] 1.2.2. How can I set '
Double line' option for Cell Style?
[IS SOLVED] 1.2.3. How can I set '
Spacing' option for Cell Style?
[IS SOLVED]2. How can I create Table Style like it does the button "
select table to start from"?
[NOT SOLVED]3. What is the flag
BitFlags? ObjectARX 2013 SDK documentation does not contain any info about "IAcadTableStyle":
[NOT SOLVED]//customTableStyle is IAcadTableStyle
customTableStyle.BitFlags = 1;
Best Regards
