Author Topic: How to get negative values with GETDIST?  (Read 2740 times)
Woabow
« on: September 26, 2012, 10:38:34 AM »
This code snippet is from a program that moves selections in only X direction after asking the distance. The user can enter both positive and negative values, no problem so far.
(setq ss1 (ssget))
(if (/= nil ss1)
        (setq ss ss1)
    (setq
    af (getdist "\nDistance: ")
    pt1 (list 0.0 0.0 0.0)
    pt2 (list af 0.0 0.0)
        (command ".move" ss "" "_none" pt1 "_none" pt2)
But I would like to enter the distance by picking two points too. This only returns positive values (as a distance is always positive).
Can somebody help me with a way to have both input modes (direct input and two points) possible, but returning a negative value when the first X value of the point is higher as the second one? Are the two points entered stored somewhere maybe?
ribarm
  • Marko Ribar, architect
Re: How to get negative values with GETDIST?
« Reply #1 on: September 26, 2012, 11:39:43 AM »
(setq ss (ssget))
(if ss
    (setq p1 (getpoint "\nPick or enter first point : "))
    (setq p2 (getpoint p1 "\nPick or enter second point - distance : "))
    (if (> (car p1) (car p2))
      (command "_.move" ss "" "_non" p1 "_non" (mapcar '+ p1 (list (distance p1 p2) 0.0 0.0)))
      (command "_.move" ss "" "_non" p1 "_non" (mapcar '- p1 (list (distance p1 p2) 0.0 0.0)))
Yes, all variables that are setq-ed and not localized by defined function, after execution of function are stored in memory of ACAD and are called global variables... You can view them among other defined functions in a list that is called with :
(atoms-family 0)
or if you want to use a list with them only as strings as elements with :
(atoms-family 1)
If you want to view values of them, you can use :
(mapcar 'eval (atoms-family 0))
But with this you'll get complete list of variables/values stored in CAD memory; if you want only setq-ed ones you have to before you do setq on them store all list in some variable like *list*
(setq *list* (atoms-family 0))
then you do setq-es with starting function without localized variables you want to view, or just setq them...
then you view them by :
(vl-remove-if '(lambda (x) (member x *list*)) (atoms-family 0))
or view their values with :
(mapcar 'eval (vl-remove '*list* (vl-remove-if '(lambda (x) (member x *list*)) (atoms-family 0))))
« Last Edit: September 26, 2012, 02:28:31 PM by ribarm »
M.R. on Youtube
« Reply #2 on: September 26, 2012, 02:13:50 PM »
Since you cannot obtain a negative distance using getdist with two points picked from the drawing, you would need to use getpoint with a base point (or use the origin as the base point with a single getpoint call).
So perhaps:
  1. (defun c:moveit ( / p1 p2 ss )
  2.     (if (and
  3.             (setq ss (ssget "_:L"))
  4.             (setq p1 (getpoint "\n1st Point: "))
  5.             (setq p2 (getpoint "\n2nd Point: " p1))
  6.         )
  7.         (command "_.move" ss "" "_non" '(0.0 0.0) "_non" (list (- (car p2) (car p1)) 0.0))
  8.     )
  9.     (princ)
  10. )
owenwengerd
« Reply #3 on: September 26, 2012, 02:45:47 PM »
As mentioned, you can use (getpoint) to obtain the points, but you would need to use (initget 128) to allow arbitrary input for the first (getpoint), then convert any arbitrary input to a real number with (atof) if the first (getpoint) returns a string instead of a point.
« Reply #4 on: September 26, 2012, 03:11:17 PM »
Maybe this:
(defun c:test (/ ss p1 p2 x)
  (defun txt2num (txt) ; CAB 10/2005
      ((distof txt 5))
      ((distof txt 2))
      ((distof txt 1))
      ((distof txt 4))
      ((distof txt 3))
  (setq ss (ssget))
  (initget 128)
  (setq p1 (getpoint "\nDistance: "))
  (if (and ss p1)
      (if (listp p1) (setq p2 (getpoint p1 "\nSpecify second point.")))
      (if (and p1 p2)
         (setq x (distance p1 p2)
               x (if (< (car p2) (car p1)) (- x) x))
         (setq x (txt2num p1))
      (if x (command ".move" ss "" "_none" '(0 0 0) "_none" (list x 0 0)))
« Last Edit: September 26, 2012, 03:22:37 PM by CAB »
« Reply #5 on: September 26, 2012, 03:20:41 PM »
Nice idea Owen to use arbitrary input, I hadn't thought of that  :-)
Perhaps CAB's code could be condensed to:
  1. (defun c:test ( / di p1 p2 ss )
  2.     (if (and
  4.             (progn
  5.                 (initget 128)
  6.                 (setq p1 (getpoint "\nDistance: "))
  7.             )
  8.             (or (and
  9.                     (listp p1)
  10.                     (setq p2 (getpoint "\nSpecify second point: " p1))
  11.                     (setq di (distance p1 p2)
  12.                           di (if (< (car p1) (car p2)) di (- di))
  13.                     )
  14.                 )
  15.                 (setq di (distof p1))
  16.             )
  17.         )
  18.         (command "_.move" ss "" "_non" '(0 0 0) "_non" (list di 0 0))
  19.     )
  20.     (princ)
  21. )
I figured the user would specify a distance in the same units as the drawing units, hence omitted the format argument from distof.
Cheers guys :)
Woabow
« Reply #6 on: September 26, 2012, 03:31:40 PM »
The (initget 128) is what I was looking for indeed. When just asking two points the user cannot enter a distance with the keyboard.
Thanks all.
owenwengerd
« Reply #7 on: September 26, 2012, 03:42:39 PM »
I would use (setq di (- (car p2) (car p1))) and ignore the other coordinates completely.
« Reply #8 on: September 26, 2012, 03:42:47 PM »
Squeeze Mode ON.  8-)
      ((distof txt 5))
      ((distof txt 2))
      ((distof txt 1))
      ((distof txt 4))
      ((distof txt 3))
  (if (and (setq ss (ssget))
           (or (initget 128)(setq p1 (getpoint "\nDistance: ")))
           (or(and (listp p1) (setq p2 (getpoint p1 "\nSpecify second point."))
                         x (if (< (car p2) (car p1)) (- x) x)))
                   (setq x (txt2num p1))))
« Reply #9 on: September 26, 2012, 04:34:46 PM »
  3.                     )
Incidentally, I had indeed considered using that approach (as per my earlier code), however since the prompt is for a distance, I thought it may be counter-intuitive for the program to only use a component of the picked distance - but for such simple code, I suppose the point is moot.
