Author Topic: FindFile() | FilerError  (Read 3850 times)
BlackBox
« on: September 25, 2012, 10:33:38 AM »
I am iterating a list of strings (files), and using HostApplicationServices.Current.FindFile() within a try block to search for each respective file in SFSP. This results in an Autodesk.AutoCAD.Runtime.Exception if no file is found as Kean illustrates here.
Am I missing something, or shouldn't FindFile() simply return null if no file is found?  :?
dgorsman
Re: FindFile() | FilerError
« Reply #1 on: September 25, 2012, 11:17:58 AM »
I think its fairly common coding practice to only return valid results, throwing an error rather than returning a null which would need to be tested for.  That way, a try/catch can handle a number of different possible problems (including "Dave's not here, man...").
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
MexicanCustard
« Reply #2 on: September 25, 2012, 12:48:49 PM »
RenderMan, looks like your running into the same problem I had with the property sets and AutoCAD API causing exceptions instead of returning results.
Why not use the .NET API System.IO.Directory or System.IO.File classes?
BlackBox
« Reply #3 on: September 25, 2012, 01:41:24 PM »
As it happens, I wrote much of the OP in my last response to you in that thread, then felt that it would detract from your original topic (while loosely related), so I started a separate thread, given the Method specificity.
I'm searching the Support File Search Paths (SFSP) for a given Document.
Does System.IO offer such functionality for AutoCAD's SFSP, or would I have to parse, then iterate each path in SFSP + Application.GetSystemVariable("DWGPREFIX"), etc.?
BlackBox
« Reply #4 on: September 25, 2012, 01:44:50 PM »
Also, if I can use System.IO for a FindFile() alternative, I am not opposed as I am already including calls to File.GetAttributes, File.SetAttributes, File.Exists, File.Delete, File.Move, etc..
TheMaster
« Reply #5 on: September 25, 2012, 10:11:47 PM »
It's probably easier to deal with the exception thrown by FindFile(), because I'm pretty sure that not all the paths it searches are actually included in DWGPREFIX.
BlackBox
« Reply #6 on: September 25, 2012, 11:25:51 PM »
As I understand it, DwgPrefix is searched before the first path in SFSP; which is the premis for how that Acad.lsp[fas] virus perpetuates.
Regarding the exception, I appreciate your clarifying... This is just something I'm now making peace with as I transition from using Nil with LISP, into .NET development. Each has their place, and with time I will better be able to negotiate logic and necessary exception handling.
Cheers! :beer:
MexicanCustard
« Reply #7 on: September 26, 2012, 07:53:22 AM »
No, you would have to get the paths from AutoCAD and then retrieve all the filenames with System.IO.Directory.  It would add a couple of extra steps but it would avoid exception trapping if that bothers you.
BlackBox
« Reply #8 on: September 26, 2012, 09:57:30 AM »
No worries; I think this is just a bit of growing pains on my part as I learn a higher level language. I'm beginning to understand that there's more out there than Nil:-D
FWIW - I've actually done this before (iterating SFSP in lieu of FindFile), in this old post... I had (unsuccessfully) tried to employ FindFile first and wasn't getting the desired results, but Gile got me squared away.
« Last Edit: September 26, 2012, 10:02:57 AM by RenderMan »
