Author Topic: {Challenge}Get same zone boundary index set from the Matrix  (Read 17270 times)
chlh_jd
« on: September 24, 2012, 02:41:13 PM »
Hi, All
I have a problem , to Get all same elements's zone boundary elements's index code set from the matrix list .
Any of the following forms of two adjacent elements considered Unicom , like 米
  ...  1 1 1 ...
  ...   1 1 1 ...
  ...   1 1 1 ...))
e.g.
((nil 1 1 1 1 nil 0 2 2)
 (nil 1 1 1 1 1 0 nil 2)
 (nil nil 1 1 1 1 1 nil nil)
 (nil nil 0 1 2  3 1 0 nil)
fuction to cal (item = 1 )'s zone boundary , the result is ( ((0 1) (1 1) (2 2) (3 3)  (2 4) (2 5) (3 6) (2 6) (1 5) (0 4) (0 3) (0 2)) ...)
Here's item=1 has one zoon just supposed , Function have to cal all zones just like the nil item .
This function is very often encountered (e.g. used in Vector graphics), so I dubbed the "challenge" the beginning of .
ElpanovEvgeniy
  • Moscow (Russia)
Re: {Challenge}Get same zone boundary index set from the Matrix
« Reply #1 on: September 24, 2012, 03:00:06 PM »
I could not understand the task ...
publish a simple example with the call and response ...
graphics are welcome ...
chlh_jd
« Reply #2 on: September 25, 2012, 01:27:57 AM »
Sorry for my poor English .
Perhaps the function just like the Figure .
(setq l ((0 0 0 0 0 0 1 1 1 1 1 1 1 1 1)
  (0 0 0 0 0 1 1 1 1 2 1 1 1 1 1)
  (0 0 0 0 1 1 1 1 1 2 2 2 2 2 2)
  (0 0 0 0 1 1 1 1 1 1 2 2 2 2 2)
  (1 1 0 1 1 1 1 1 1 1 2 2 2 2 2)
  (1 1 1 1 0 1 1 1 2 2 2 2 1 1 1)
  (0 1 0 0 0 1 1 1 2 2 1 1 1 1 1)
  (1 1 0 1 1 1 1 1 1 1 1 1 1 1 1)
  (1 1 1 1 1 1 1 1 1 2 1 1 1 1 1)
  (1 1 1 1 1 1 1 1 1 2 2 2 1 1 1)
  (1 1 1 1 1 1 1 1 1 2 2 1 1 1 1)
  (1 1 1 1 1 1 1 1 1 2 2 1 1 1 2)
  (1 1 1 1 1 1 1 1 2 2 2 2 2 2 2)
  (1 1 1 1 1 1 1 1 1 2 2 2 2 2 1)
  (1 1 1 1 1 1 1 1 1 1 2 2 2 1 1)))
;;Cal same colour zone
(foo l) --->
(2 ((0 0) (1 0) (2 0) (3 0) (4 0) (5 0) (4 1) (3 2) (3 3) (3 4) (2 5) (1 4) (0 4) (0 3) (0 2) (0 1) (0 0))
   ((4 6) (4 7) (2 7) (2 8)))
(1 ((6 0) (7 0) (8 0) (8 1) (8 2) (9 3) (9 4) (9 5) (8 5) (7 6) (7 7) (8 8) (8 9) (8 10) (8 11) (8 12) (8 13)
    (7 14) (8 15) (9 16) (8 16) (7 16) (6 16) (5 16) (4 16) (3 16) (2 16) (1 16) (0 16) (0 15) (0 14) (0 13)
    (0 12) (0 11) (0 10) (0 9) (0 8) (0 7) (0 6) (0 5) (1 5) (1 6) (1 7) (1 8) (1 9) (2 9) (3 8) (4 8) (5 7)
    (5 6) (4 5) (4 4) (4 3) (4 2) (5 1) (6 0))
   ((9 0) (10 0) (11 0) (12 0) (13 0) (14 0) (14 1) (13 1) (12 1) (11 1) (10 1) (9 0))
   ((12 6) (13 6) (14 6) (14 7) (14 8) (14 9) (14 10) (14 11) (14 12) (13 13) (12 13) (11 13) (11 12) (11 11)
   (12 10) (11 9) (10 9) (9 8) (10 7) (11 7) (12 6))
   ((14 15) (14 16) (13 16) (14 15)))
(0 ((9 1) (10 2) (11 2) (12 2) (13 2) (14 2) (14 3) (14 4) (14 5) (13 5) (12 5) (11 6) (10 6) (9 7) (8 7)
  (8 6) (9 6) (10 5) (10 4) (10 3) (9 2) (9 1))
   ((14 14) (14 13) (13 14) (12 14) (10 14) (10 13) (10 12) (10 11) (11 10) (10 10) (9 9) (9 10) (9 11)
    (9 12) (9 13) (8 14) (9 15) (10 16) (12 16) (13 15) (14 14))))
« Last Edit: September 25, 2012, 01:43:37 AM by chlh_jd »
chlh_jd
« Reply #3 on: September 25, 2012, 01:30:18 AM »
To solve Vector Graphics must add other conditions , however , here we just suppose to cal the same colore zone , If only one small square , see as not can be link to other squares .
« Last Edit: September 25, 2012, 01:46:44 AM by chlh_jd »
chlh_jd
« Reply #4 on: September 25, 2012, 02:03:32 AM »
I found my English is too poor , I can't explain my right thoughts .
I post the result picture I want .
So the function is to cal the same colore zone's indexs of the colore zone matrix .
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: September 25, 2012, 04:31:19 AM »
problem is similar to search geodesic contours...
  1. (setq l '((0 0 0 0 0 0 1 1 1 1 1 1 1 1 1)
  2.           (0 0 0 0 0 1 1 1 1 2 1 1 1 1 1)
  3.           (0 0 0 0 1 1 1 1 1 2 2 2 2 2 2)
  4.           (0 0 0 0 1 1 1 1 1 1 2 2 2 2 2)
  5.           (0 0 0 0 1 1 1 1 1 1 2 2 2 2 2)
  6.           (1 1 0 1 1 1 1 1 1 1 2 2 2 2 2)
  7.           (1 1 1 1 0 1 1 1 2 2 2 2 1 1 1)
  8.           (0 1 0 0 0 1 1 1 2 2 1 1 1 1 1)
  9.           (1 1 0 1 1 1 1 1 1 1 1 1 1 1 1)
  10.           (1 1 1 1 1 1 1 1 1 2 1 1 1 1 1)
  11.           (1 1 1 1 1 1 1 1 1 2 2 2 1 1 1)
  12.           (1 1 1 1 1 1 1 1 1 2 2 1 1 1 1)
  13.           (1 1 1 1 1 1 1 1 1 2 2 1 1 1 1)
  14.           (1 1 1 1 1 1 1 1 1 2 2 1 1 1 2)
  15.           (1 1 1 1 1 1 1 1 2 2 2 2 2 2 2)
  16.           (1 1 1 1 1 1 1 1 1 2 2 2 2 2 1)
  17.           (1 1 1 1 1 1 1 1 1 1 2 2 2 1 1)
  18.          )
  19.       x 0
  20.       y -1
  21. )
  22.                     (setq x 0 y (1+ y))
  23.                     (mapcar (function (lambda (a b c d)
  24.                                         (entmakex (list '(0 . "3DFACE")
  25.                                                         '(100 . "AcDbEntity")
  26.                                                         '(67 . 0)
  27.                                                         '(410 . "Model")
  28.                                                         '(100 . "AcDbFace")
  29.                                                         (list 10 x y a)
  30.                                                         (list 11 (1+ x) y b)
  31.                                                         (list 12 (1+ x) (1+ y) d)
  32.                                                         (list 13 x (1+ y) c)
  33.                                                         '(70 . 0)
  34.                                                   )
  35.                                         )
  36.                                         (setq x (1+ x))
  37.                                       )
  38.                             )
  39.                             a
  40.                             (cdr a)
  41.                             b
  42.                             (cdr b)
  43.                     )
  44.                   )
  45.         )
  46.         l
  47.         (cdr l)
  48. )
chlh_jd
« Reply #6 on: September 25, 2012, 04:56:35 AM »
Thanks Evgeniy !
Good idea !
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: September 25, 2012, 06:07:14 AM »
  1. (defun eea-geodesic-contours-TheSwamp (l / X Y)
  2.   ;; by ElpanovEvgeniy
  3.   ;;(eea-geodesic-contours-TheSwamp l)
  4.   (defun min-max (a b c) (list (min a b c) (max a b c)))
  5.   (defun fix-z (p z) (list (car p) (cadr p) z))
  6.   (setq y -1.
  7.         l (apply (function append)
  8.                  (mapcar (function
  9.                            (lambda (a b)
  10.                              (setq x -1.
  11.                                    y (1+ y)
  12.                              )
  13.                              (apply (function append)
  14.                                     (mapcar (function
  15.                                               (lambda (a b c d / z)
  16.                                                 ;;(setq a (caar l) b (cadar l) c(caadr l) d(cadadr l))
  17.                                                 (setq x (1+ x)
  18.                                                       z (/ (+ a b c d) 4.)
  19.                                                 )
  20.                                                 (list (list (min-max a b z) (list x y a) (list (1+ x) y b) (list (+ x 0.5) (+ y 0.5) z))
  21.                                                       (list (min-max a c z) (list x y a) (list x (1+ y) c) (list (+ x 0.5) (+ y 0.5) z))
  22.                                                       (list (min-max b d z) (list (1+ x) y b) (list (1+ x) (1+ y) d) (list (+ x 0.5) (+ y 0.5) z))
  23.                                                       (list (min-max c d z) (list x (1+ y) c) (list (1+ x) (1+ y) d) (list (+ x 0.5) (+ y 0.5) z))
  24.                                                 )
  25.                                               )
  26.                                             )
  27.                                             a
  28.                                             (cdr a)
  29.                                             b
  30.                                             (cdr b)
  31.                                     )
  32.                              )
  33.                            )
  34.                          )
  35.                          l
  36.                          (cdr l)
  37.                  )
  38.           )
  39.   )
  40.   (foreach z '(0.5 1.5 2.5)
  41.     (foreach tr l
  42.       (if (and (<= (caar tr) z (cadar tr))
  43.                (cdr (setq tr (vl-remove nil
  44.                                         (list (inters (nth 1 tr) (nth 2 tr) (fix-z (nth 1 tr) z) (fix-z (nth 2 tr) z))
  45.                                               (inters (nth 2 tr) (nth 3 tr) (fix-z (nth 2 tr) z) (fix-z (nth 3 tr) z))
  46.                                               (inters (nth 1 tr) (nth 3 tr) (fix-z (nth 1 tr) z) (fix-z (nth 3 tr) z))
  47.                                         )
  48.                              )
  49.                     )
  50.                )
  51.           )
  52.         (entmakex (list '(0 . "line") (cons 62 (fix (* z 10))) (cons 10 (car tr)) (cons 11 (cadr tr))))
  53.       )
  54.     )
  55.   )
  56.   (princ)
  57. )
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #8 on: September 25, 2012, 06:18:19 AM »
small addition to supplementary contours ...  :-)
  1. (defun eea-geodesic-contours-TheSwamp (l lst-z / X Y)
  3.   ;;(eea-geodesic-contours-TheSwamp l '(0.5 1.5))
  6.   (setq y -1.
  9.                            (lambda (a b)
  10.                              (setq x -1.
  11.                                    y (1+ y)
  12.                              )
  17.                                                 (setq x (1+ x)
  19.                                                 )
  24.                                                 )
  25.                                               )
  26.                                             )
  27.                                             a
  28.                                             (cdr a)
  29.                                             b
  30.                                             (cdr b)
  31.                                     )
  32.                              )
  33.                            )
  34.                          )
  35.                          l
  36.                          (cdr l)
  37.                  )
  38.           )
  39.   )
  40.   (foreach z lst-z
  41.     (foreach tr l
  47.                                         )
  48.                              )
  49.                     )
  50.                )
  51.           )
  53.       )
  54.     )
  55.   )
  56.   (princ)
  57. )
(eea-geodesic-contours-TheSwamp l '(0.1 0.3 0.5 0.7 0.9 1.1 1.3 1.5 1.7 1.9))
dgorsman
« Reply #9 on: September 25, 2012, 11:10:46 AM »
There's probably some good information on edge detection in the image processing field that would be directly applicable.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
chlh_jd
« Reply #10 on: September 26, 2012, 01:48:47 AM »
Evgeniy's allways excellent !  :-)
I have to spend a lot of time to understand your implementation ideas and source code .
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: September 26, 2012, 05:08:17 AM »
added display of all triangles - will now be more clear, the algorithm of the program...
  1. (eea-geodesic-contours-TheSwamp l '(0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0))
  4.   ;; last edit 26.09.2012
  5.   (defun min-max (a b c) (list (min a b c) (max a b c)))
  6.   (defun fix-z (p z) (list (car p) (cadr p) z))
  7.   (setq y -1.
  8.         l (apply (function append)
  9.                  (mapcar (function
  10.                            (lambda (a b)
  11.                              (setq x -1.
  12.                                    y (1+ y)
  13.                              )
  14.                              (apply (function append)
  15.                                     (mapcar (function
  16.                                               (lambda (a b c d / z)
  17.                                                 (setq x (1+ x)
  19.                                                 )
  24.                                                 )
  25.                                               )
  26.                                             )
  27.                                             a
  28.                                             (cdr a)
  29.                                             b
  30.                                             (cdr b)
  31.                                     )
  32.                              )
  33.                            )
  34.                          )
  35.                          l
  36.                          (cdr l)
  37.                  )
  38.           )
  39.   )
  40.   (foreach tr l
  41.     (entmakex (list '(0 . "3DFACE")
  42.                     '(100 . "AcDbEntity")
  43.                     '(62 . 251)
  44.                     '(67 . 0)
  45.                     '(410 . "Model")
  46.                     '(100 . "AcDbFace")
  47.                     (cons 10 (cadr tr))
  48.                     (cons 11 (caddr tr))
  49.                     (cons 12 (cadddr tr))
  50.                     (cons 13 (cadddr tr))
  51.                     '(70 . 0)
  52.               )
  53.     )
  54.   )
  55.   (foreach z lst-z
  56.     (foreach tr l
  57.       (if (and (<= (caar tr) z (cadar tr))
  58.                (cdr (setq tr (vl-remove nil
  59.                                         (list (inters (nth 1 tr) (nth 2 tr) (fix-z (nth 1 tr) z) (fix-z (nth 2 tr) z))
  60.                                               (inters (nth 2 tr) (nth 3 tr) (fix-z (nth 2 tr) z) (fix-z (nth 3 tr) z))
  61.                                               (inters (nth 1 tr) (nth 3 tr) (fix-z (nth 1 tr) z) (fix-z (nth 3 tr) z))
  62.                                         )
  63.                              )
  64.                     )
  65.                )
  66.           )
  67.         (entmakex (list '(0 . "line")
  68.                         (cons 62 (atoi (rtos (* (- 2. z) 100) 2 0)))
  69.                         (cons 10 (car tr))
  70.                         (cons 11 (cadr tr))
  71.                   )
  72.         )
  73.       )
  74.     )
  75.   )
  76.   (princ)
  77. )
chlh_jd
« Reply #12 on: September 26, 2012, 07:43:37 AM »
So woderful for Height contours , Evgeniy.
After learn your codes , I write my first codes .
(defun test  (l / f1 f2 y x lst l1 a b c e res ss)
  (defun f1  (a l)
    (cond ((not l) nil)
  ((equal a (caar l))
   (cons 0 (car l)))
  ((equal a (cadar l))
   (cons 1 (car l)))
  (t (f1 a (cdr l)))
  (defun f2  (l / r p p0 p1)
    (setq r (list (car l))
  l (cdr l))
    (while (cadr l)
      (setq p  (car l)
    p1 (cadr l)
    l  (cdr l)
    p0 (car r))
      (if (not (or (= (car p0) (car p) (car p1))
   (= (cadr p0) (cadr p) (cadr p1))))
(setq r (cons p r))))
    (cons (car l) r))
  (setq y -0.5)
  (mapcar (function (lambda (a b)
      (setq y (1+ y)
    x -1.5)
  (setq x (1+ x))
  (if (/= a b)
    (setq lst
   (cons (list (list x y) (list (1+ x) y))
lst))
      a
      b)))
  l
  (cdr l))
  (setq y -1.5)
  (mapcar (function (lambda (a)
      (setq y (1+ y)
    x -0.5)
  (setq x (1+ x))
  (if (/= a b)
    (setq lst
   (cons (list (list x y) (list x (1+ y)))
lst))
      a
      (cdr a))))
  l
  (setq lst (vl-sort lst (function (lambda (a b)
     (if (equal (car a) (car b))
       (< (cadadr a) (cadadr b))
       (if (equal (cadar a) (cadar b))
(< (caar a) (caar b))
(< (cadar a) (cadar b))))))
  (while lst
    (setq a   (car lst)
  lst (cdr lst))
    (while (setq b (f1 (car a) lst))
      (setq lst (vl-remove (cdr b) lst)
    a (cons (if (zerop (car b))
(caddr b)
(cadr b))
      a)))
    (setq a (reverse a))
(caddr b)
(cadr b))
      a)))
    (setq a (f2 a))
    (setq res (cons a res)))
  (setq ss (ssadd))
  (foreach a  res
    (if (setq e (entmakex
  (append
    (list (cons 0 "LWPOLYLINE")
  (cons 100 "AcDbEntity")
  (cons 100 "AcDbPolyline")
  (cons 90 (length a))
    (mapcar (function (lambda (x) (cons 10 x))) a)
    (list (cons 70 0) (cons 62 6))
      (setq ss (ssadd e ss))))
  (vl-catch-all-apply
    (function vl-cmdf)
    (list "_.Pedit" "M" ss "" "S" ""))
Use Test fun : (Test l) ---->
chlh_jd
« Reply #13 on: September 26, 2012, 08:41:20 AM »
Try this List in Testlst.lsp , I don't get the result .
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #14 on: September 26, 2012, 10:12:17 AM »
  1. (eea-geodesic-contours-TheSwamp l '(0.25 0.5 0.75 1.0 1.25 1.5 1.75 2.0 2.25 2.5 2.75 3.0))
  2. (defun eea-geodesic-contours-TheSwamp (l lst-z / X Y)
  3.   ;; by ElpanovEvgeniy
  4.   ;;(eea-geodesic-contours-TheSwamp l '(0.5 1.5 2.5))
  5.   ;; last edit 26.09.2012
  6.   (defun min-max (a b c) (list (min a b c) (max a b c)))
  7.   (defun fix-z (p z) (list (car p) (cadr p) z))
  8.   (setq y -1.
  9.         l (apply (function append)
  10.                  (mapcar (function
  11.                            (lambda (a b)
  12.                              (setq x -1.
  13.                                    y (1+ y)
  14.                              )
  15.                              (apply (function append)
  16.                                     (mapcar (function
  17.                                               (lambda (a b c d / z)
  18.                                                 (setq x (1+ x)
  19.                                                       z (/ (+ a b c d) 4.)
  20.                                                 )
  21.                                                 (list (list (min-max a b z) (list x y a) (list (1+ x) y b) (list (+ x 0.5) (+ y 0.5) z))
  22.                                                       (list (min-max a c z) (list x y a) (list x (1+ y) c) (list (+ x 0.5) (+ y 0.5) z))
  23.                                                       (list (min-max b d z) (list (1+ x) y b) (list (1+ x) (1+ y) d) (list (+ x 0.5) (+ y 0.5) z))
  24.                                                       (list (min-max c d z) (list x (1+ y) c) (list (1+ x) (1+ y) d) (list (+ x 0.5) (+ y 0.5) z))
  25.                                                 )
  26.                                               )
  27.                                             )
  28.                                             a
  29.                                             (cdr a)
  30.                                             b
  31.                                             (cdr b)
  32.                                     )
  33.                              )
  34.                            )
  35.                          )
  36.                          l
  37.                          (cdr l)
  38.                  )
  39.           )
  40.   )
  41. ;;;  (foreach tr l
  42. ;;;    (entmakex (list '(0 . "3DFACE")
  43. ;;;                    '(100 . "AcDbEntity")
  44. ;;;                    '(62 . 251)
  45. ;;;                    '(67 . 0)
  46. ;;;                    '(410 . "Model")
  47. ;;;                    '(100 . "AcDbFace")
  48. ;;;                    (cons 10 (cadr tr))
  49. ;;;                    (cons 11 (caddr tr))
  50. ;;;                    (cons 12 (cadddr tr))
  51. ;;;                    (cons 13 (cadddr tr))
  52. ;;;                    '(70 . 0)
  53. ;;;              )
  54. ;;;    )
  55. ;;;  )
  56.   (foreach z lst-z
  57.     ;;(setq z 2.5)
  58.     (foreach tr l
  59.       (if (and (<= (caar tr) z (cadar tr))
  60.                (cdr (setq tr (vl-remove nil
  61.                                         (list (inters (nth 1 tr) (nth 2 tr) (fix-z (nth 1 tr) z) (fix-z (nth 2 tr) z))
  62.                                               (inters (nth 2 tr) (nth 3 tr) (fix-z (nth 2 tr) z) (fix-z (nth 3 tr) z))
  63.                                               (inters (nth 1 tr) (nth 3 tr) (fix-z (nth 1 tr) z) (fix-z (nth 3 tr) z))
  64.                                         )
  65.                              )
  66.                     )
  67.                )
  68.           )
  69.         (entmakex (list '(0 . "line")
  70.                         (cons 8 (rtos z 2 1))
  71.                         (cons 10 (car tr))
  72.                         (cons 11 (cadr tr))
  73.                   )
  74.         )
  75.       )
  76.     )
  77.   )
  78.   (princ)
  79. )
