Author Topic: stretch objects by color  (Read 2959 times)
ELOQUINTET
« on: March 03, 2005, 11:30:11 AM »
i have this lisp which stretches objects on selected layers. at my new job they don't use very many layers but instead change the color. i would like to modify this to do it according to color instead. is this possible and if so how would i modify this?
;;; STRETCHES SPECIFIC LAYERS ONLY
(defun c:SL
(/ layer_string ent enlay entlst ename olderr selset enum objlen dent layent layset lay pt1 pt2 ss ss1 ss2 en osm)
(if (null myerr)(load "myerr"))
(setq olderr *error* *error* myerr)
(setq osm (getvar "osmode"))
(if (null setvars)(load "setvars"))
(setq syslst
(setvars '(("cmdecho" . 0) ("osmode" . 0) ("trimmode" . 1)) )
(while (setq ent (entsel "\nSelect entity on layer..."))
(setq layer_string
(if layer_string
(strcat layer_string ","
(vla-get-layer (vlax-ename->vla-object (car ent)))
(princ "\nSelect objects to stretch by crossing-window or crossing-polygon...")
(command "._stretch" (ssget (list (cons 8 layer_string))) "")
(setvars syslst)
(setq *error* olderr)
(defun myerr (msg)
(if (or (= msg "quit / exit abort")
(= msg "Function cancelled"))
(if (and ctl undo_err) ; if undo_start used and returned value saved
(undo_err ctl)) ; in ctl then undo everything done so far.
(princ msg))
(if (and setvars syslst) ; if usual system var handler and variable exist
(setvars syslst)) ; then restore system vars
(setq *error* OLDERR ctl nil)
(defun setvars (syslst / oldlst)
(foreach dp syslst
(setq oldlst (cons
(cons (car dp) (getvar (car dp)))
oldlst)))
(foreach dp syslst
(setvar (car dp) (cdr dp))
oldlst
« Reply #1 on: March 03, 2005, 12:25:51 PM »
(defun c:SL
    osm
  (if (null myerr)
    (load "myerr")
*error* myerr
  (if (null setvars)
    (load "setvars")
  (setq syslst
(setvars '(("cmdecho" . 0) ("osmode" . 0) ("trimmode" . 1)))
  (while (setq ent (entsel "\nSelect entity color.."))
    (setq layer_string
  (if layer_string
    (vla-get-color (vlax-ename->vla-object (car ent)))
  (princ
  (ssget (list (cons 62 layer_string)))
  (setvars syslst)
(defun myerr (msg)
      (undo_err ctl)
    (princ msg)
    (setvars syslst)
ctl nil
  (foreach dp syslst
    (setq oldlst (cons
  oldlst
  (foreach dp syslst
  oldlst
I changed  (vla-get-layer (vlax-ename->vla-object (car ent))) to  (vla-get-color (vlax-ename->vla-object (car ent)))
and
(ssget (list (cons 8 layer_string))) to
It asks for two picks though
Ron
ELOQUINTET
« Reply #2 on: March 03, 2005, 12:57:29 PM »
ok ron it works so far but one more request if you don't mind. how do i modify it so i can select multiple colors?
ELOQUINTET
« Reply #3 on: March 04, 2005, 01:33:04 PM »
hmmm no responses i didn't think that was a big change. sigh it's so frustrating that they don't use layers i heavily used that stretch by layer lisp  :x
whdjr
« Reply #4 on: March 04, 2005, 03:08:45 PM »
Try this:
(defun c:SL (/ olderr *error* syslst ent elist clist)
  (defun myerr (msg)
(undo_err ctl)
      (princ msg)
      (setvars syslst)
 ctl  nil
    (foreach dp syslst
      (setq oldlst (cons
    oldlst
    (foreach dp syslst
    oldlst
*error* myerr
  (setq syslst (setvars '(("cmdecho" . 0) ("osmode" . 0) ("trimmode" . 1))))
  (setvar "ErrNo" 0)
  (while (/= (getvar "ErrNo") 52)
    (cond ((= (getvar "ErrNo") 7)
  (princ "\nSelection missed.  Please try again.")
  (setvar "ErrNo" 0)
 ((setq ent (car (entsel "\nSelect entity color(s): ")))
  (setq elist (cons ent elist))
  (princ (strcat "<1> Entity selected [" (itoa (length elist)) "] Total"))
  (if elist
    (and (setq clist (mapcar '(lambda (x)
(vla-get-color (vlax-ename->vla-object x))
    elist
(setq clist (mapcar '(lambda (x) (cons 62 x)) clist))
(setq clist (append '((-4 . "<AND")) clist '((-4 . "AND>"))))
    (princ "\nNothing selected!")
  (prompt
  (if clist
      (command "._stretch" (ssget clist))
      (command "" pause pause)
  (setvars syslst)
I didn't have time to configure it for finding the actual color of a bylayer entity.  Sorry.  Maybe later this weekend.
t-bear
« Reply #5 on: March 05, 2005, 01:09:55 PM »
Work hard, be dilligent, and soon you'll be the CAD manager.  THEN! you can make the ba$tards use layers like the rest of the civilized world.
OH yah ..... suck up a lot too LOLOL
ELOQUINTET
« Reply #6 on: March 07, 2005, 08:36:39 AM »
ha good one bear, my thoughts exactly but it's the first week so i'm not saying anything (yet)  :wink:
