Author Topic: To add/remove/edit context menu by Sheet Set, Sheet and Subset elements  (Read 2617 times)
Andrey Bushman
Hi all.
Anybody knows how to add/remove/edit context menu by Sheet Set, Sheet and Subset elements via .NET? From ADN I didn't receive the response to the matter: it was the formal reply, not contained the answer (the request number 06930535) :(:
Note that customizing a context menu might be doable by invoking Win32 APIs, though it might not be straightforward and considered as a hack, so not supported from ADN perspective.
Philippe Leefsma
Is the everything really so bad? :(
Sheet Sets have a weak functionality. For my users I need to extend it.
Regards
« Last Edit: September 17, 2012, 11:23:00 AM by Andrey »
Andrey Bushman
Re: To add/remove/edit context menu by Sheet Set, Sheet and Subset elements
« Reply #1 on: September 18, 2012, 12:49:11 AM »
The sad statistics - my topics don't live. :(
« Reply #2 on: September 18, 2012, 02:04:31 AM »
Sorry Andrey,
I haven't played with Sheet sets at all.
From the answer from the ADN it looks like their techs haven't done snything with them either.
Good luck with an answer :)
Regards,
That's because you ask all the hard questions that no one has investigated. :)
BlackBox
« Reply #3 on: September 18, 2012, 09:51:39 AM »
FWIW -
The Florida Department of Transportation (FDOT) has wasted thousands, upon thousands of taxpayer dollars to create a utility they call SheetSet Organizer (which allows Microstation users to manage multiple DSTs for a single Civil 3D project :roll:).
This utility is included with their Civil 3D 2012 State Kit (which has been in Beta for the past +/-6 years :roll:), which Autodesk has willingly worked with them to expose APIs, develop code, and even SP2.1, etc..
In any event... Use Reflection, or IlSpy to navigate   C:\FDOT2012.C3D\APPS\SheetSetOrganizer\SheetSetOrganizer.exe   (post-install)... To see how they use an external application to interact with SSM. Maybe that will present a rabbit hole for you to explorer.  :wink:
HTH
LE3
« Reply #4 on: September 18, 2012, 12:57:31 PM »
not an anwer too of if can help you in anyway, but recall seeing some app related with the SSM here:
http://www.jtbworld.com/SSMPropEditor.htm
Matt__W
  • I like my water diluted.
« Reply #5 on: September 18, 2012, 01:09:14 PM »
Here's a little sumpin' sumpin' I created a while back.  Some of the code (or ideas) I got from the JTB site.  I think....   :|
It's not going to work in a 64-bit install because the code is running out of process because VBA isn't integrated with AutoCAD anymore.  But feel free to disect it.  Maybe it'll help you.  It creates a DST file on the fly with predefined subcategories.
Autodesk Expert Elite
Andrey Bushman
« Reply #6 on: September 20, 2012, 04:36:18 AM »
I don't want to buy another's program. I want to write.
Andrey Bushman
« Reply #7 on: September 20, 2012, 04:43:04 AM »
I can do it, thank you, but my question was about other.
