Author Topic: Visual Studio Add-in  (Read 1644 times)
« on: September 13, 2012, 09:12:44 PM »
I'm in the process of re-installing and re-configuring everything ...
Does anyone know the name of the Visual Studio add-in that places a control on the right side of the IDE editor that allows for quick scrolling in the code ??
Refer this old snapshot I had backed up.
« Last Edit: September 13, 2012, 11:25:44 PM by Kerry »
LE3
Re: Visual Studio Add-in
« Reply #1 on: September 13, 2012, 10:22:45 PM »
owenwengerd
« Reply #2 on: September 13, 2012, 11:03:52 PM »
I've never used it, but Microsoft's VS Power Tools has one of those:
http://visualstudiogallery.msdn.microsoft.com/d0d33361-18e2-46c0-8ff2-4adea1e34fef
« Reply #3 on: September 13, 2012, 11:23:12 PM »
Just came back to post that link Owen.
That's not the one I had, but I'm using it because the Add-in has an excellent 'Add References' dialog.
Some of the other stuff is good too .. like the Middle-Click Scrolling
I use JetBrains ReSharper and I thought it was included with that, but apparently not :)
Thanks Luis and Owen.
Another one I found was http://www.hanselman.com/blog/IntroducingRockScroll.aspx
« Last Edit: September 13, 2012, 11:27:10 PM by Kerry »
Jeff H
« Reply #4 on: September 14, 2012, 12:11:17 AM »
