If I might add to the discussion....
I believe Lee is attempting to determine the AEC version by reading the header code that you will see, were you to open any DWG using a text editor (i.e., Notepad, Notepad++, etc.)... Look at the first six characters of the first line.
In any event, I suspect that this method will not be the correct solution, only as a result of verticals supporting both the SaveAs, and Export to AutoCAD methods... Unless I am mistaken, were one to open a Civil 3D 2013 drawing (for example), create an Alignment, then SaveAs 2010 file format, the Alignment (in this case an AECC Object) is still in 2013 format, despite the drawing being opened in 2010, 2011, or 2012.
** Edit - Only when using the Export to AutoCAD command does the AECC Object (the Alignment) get converted to 2010 format. This is a flaw, IMO, for verticals such as Civil 3D.
Perhaps someone more knowledgeable with AEC (not AECC) can clarify?
