Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Switch from Viewport to Paper
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Switch from Viewport to Paper (Read 1450 times)
Andrey Bushman
Swamp Rat
on:
September 12, 2012, 06:14:15 AM »
Hi all.
How can I to switch from Viewport to Paper?
Code - C#:
[Select]
Boolean modalSpaceIsCurrent
Int16
acad
GetSystemVariable
"TILEMODE"
1
true
false
if
modalSpaceIsCurrent
ed
WriteMessage
"Command is canceled - MODEL space is current.
\n
return
Boolean viewportIsCurrent
modalSpaceIsCurrent
Int16
acad
GetSystemVariable
"CVPORT"
1
true
false
if
viewportIsCurrent
ed
WriteMessage
"Go out from Viewport to Paper...
\n
//But it not switched from Viewport to paper:
ed
SwitchToPaperSpace
How can I do it?
Regards
Logged
Andrey Bushman
Swamp Rat
Re: Switch from Viewport to Paper
Reply #1 on:
September 12, 2012, 06:24:18 AM »
I apologize... I forgot to write transaction.Commit();
Problem is solved.
Moderator, delete it topic, please.
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #2 on:
September 12, 2012, 06:30:37 AM »
Andrey, I'll leave it there if you don't mind.
The post may help someone later.
Can you post the rectified code, just for completeness please ?
Regards
Logged
Andrey Bushman
Swamp Rat
Reply #3 on:
September 12, 2012, 07:53:09 AM »
Code - C#:
[Select]
Int16
acad
GetSystemVariable
"TILEMODE"
1
true
false
if
modalSpaceIsCurrent
ed
WriteMessage
\n
return
modalSpaceIsCurrent
Int16
acad
GetSystemVariable
"CVPORT"
1
true
false
if
viewportIsCurrent
ed
WriteMessage
\n
ed
SwitchToPaperSpace
//tr - Transaction
tr
Commit
// <- it row need.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
