Important To install fonts, you must have them on a floppy disk, CD, or your hard disk.
To install a font, follow these steps: 1.Click Start, and then click Run.
2.Type the following command, and then click OK:
%windir%\fonts
3.On the File menu, click Install New Font.
4.In the Drives box, click the drive that contains the font that you want to add.
Note The floppy disk drive is typically drive A or drive B. The CD drive is typically drive D.
5.In the Folders box, click the folder that contains the font that you want to add, and then click OK.
6.In the List of fonts box, click the font that you want to add. To select more than one font at a time, press and hold the CTRL key while you select each font.
7.Click to select the Copy Fonts To Fonts Folder check box. The new font is saved in the Windows\Fonts folder.
8.Click OK.
Note Windows supports TrueType fonts or fonts that are designed especially for Windows which can be purchased separately. Some programs also include special fonts that are installed as part of the program installation. Additionally, TrueType or special Windows fonts are frequently included with printers. Follow the directions that are included with these products to install these fonts.
