Author Topic: Plot to DWF  (Read 1566 times)
Andrey Bushman
Plot to DWF
« on: September 10, 2012, 09:19:38 AM »
Hi all.
Anybody tried to run it code? I have tried at AutoCAD 2009,2013, but it ain't working to me (look my comments in the link). :(
Regards
gile
  • Marseille, France
Re: Plot to DWF
« Reply #1 on: September 10, 2012, 02:42:47 PM »
You can have a look here:
http://www.theswamp.org/index.php?topic=31897.msg474069#msg474069
This code is for 3dDwf plotting but can be easily adapted for DWF (changing the DsdEntry and DsdData settings and removing the DsdData file rewriting).
Andrey Bushman
Re: Plot to DWF
« Reply #2 on: September 10, 2012, 04:00:36 PM »
Thank you for link, but... Did you try to run code at my link? I want to understand the reason of problem. And this code is shown as an example in ADN. I will read your link tomorrow, thanks and good night.
Regards.
« Last Edit: September 10, 2012, 04:07:34 PM by Andrey »
Andrey Bushman
Re: Plot to DWF
« Reply #3 on: September 11, 2012, 10:17:39 AM »
Ok. I placed archive here. It needs to be unpacked in C:\. Simpler doesn't happen. Somebody can run it? It a code from first message of this topic....
Andrey Bushman
Re: Plot to DWF
« Reply #4 on: September 11, 2012, 02:15:47 PM »
the problem is solved, the question is closed.
