Author Topic: Search "CODE" in list  (Read 2658 times)
cadplayer
« on: September 06, 2012, 08:10:25 AM »
Hi
I have two lists
1) (setq CL '("VK" "SK" "TR" "DI" "K" "NB" "DB" "M" "TB" "MU" "vg" "Spik" "FG" "BS" "el" "0"))
and
2) (setq CLIST '(("LAYER" "M-BEF-MUR") ("CODE" "MU") ("BESCHREIBUNG" "Mur")) (("LAYER" "M-BEF-PLANTERING") ("CODE" "VE") ("BESCHREIBUN...
Now I want look for if it is "VK" from variable CL in variable CLIST in  ("CODE" "....")
If not I should display "Code not definition"
I try it so here but it works not right. Can somebody help me
Two codes one for erase duplicates
(defun _RemoveDuplicates ( lst / foo index )
    (defun foo (x)
            ((vl-position x index))
            ((null (setq index (cons x index))))
    (vl-remove-if
       'foo
        lst
and what I try it
(foreach M CL  ; M... "VK"
        (foreach N CLIST ; N...(("LAYER" "0") ("CODE" "BU") ("BESCHREIBUNG" "Buskar"))
            ((/= M (cadr (assoc "CODE" N)))
             (princ "\nCode ready in list")
            (nil
             (setq NCODE (cons M NCODE))
             (princ "\nCode not in list")
      (if (setq NCODE (_RemoveDuplicates NCODE))
        (princ NCODE " Code not defiintion")
« Last Edit: September 06, 2012, 08:13:38 AM by cadplayer »
Tharwat
  • Hypersensitive
Re: Search "CODE" in list
« Reply #1 on: September 06, 2012, 08:36:00 AM »
This ... ?
  1. (setq CL '("VK" "SK" "TR" "DI" "K" "NB" "DB" "M" "TB" "MU" "vg" "Spik" "FG" "BS" "el" "0"))
  2. (setq CLIST '(("LAYER" "M-BEF-MUR") ("CODE" "MU") ("BESCHREIBUNG" "Mur")("LAYER" "M-BEF-PLANTERING") ("CODE" "VE")))
  3.
  4. (foreach x clist
  5.   (if (member "VK" x) (setq found t))
  6.   )
  7. (if found (princ "\n Not found")
  8.   (princ "\n Just found it"))
  9.
« Reply #2 on: September 06, 2012, 09:15:38 AM »
Maybe:
  1. (foreach a cl
  2.     (cond
  3.         (   (vl-some '(lambda ( b ) (and (= "CODE" (car b)) (= a (cadr b)))) clist)
  4.             (princ (strcat "\n" a " already in list."))
  5.         )
  6.         (   (not (member a ncode))
  7.             (setq ncode (cons a ncode))
  8.         )
  9.     )
  10. )
  11. (print ncode)
cadplayer
« Reply #3 on: September 06, 2012, 10:01:00 AM »
Thanks both
@Tharwat
Your solution shows always "Just found it"
@Lee
ncode returns same list from CL-variable in NCODE-variable
CL: ("VK" "SK" "TR" "DI" "K" "NB" "DB" "M" "TB" "MU" "vg" "Spik" "FG" "BS" "el" "0")
NCODE: ("0" "el" "BS" "FG" "Spik" "vg" "MU" "TB" "M" "DB" "NB" "K" "DI" "TR" "SK" "VK")
« Reply #4 on: September 06, 2012, 10:15:44 AM »
@Lee
Using your given examples, the result for my code is:
MU already in list.
("0" "el" "BS" "FG" "Spik" "vg" "TB" "M" "DB" "NB" "K" "DI" "TR" "SK" "VK")
cadplayer
« Reply #5 on: September 06, 2012, 10:31:53 AM »
Sorry my fel
codes you can see in CL should founded in CLIST if not in CLIST show "Code not in list"
CL:
CLIST
((("LAYER" "0") ("CODE" "HPS") ("BESCHREIBUNG" "Hjälppunktstation")) (("LAYER" "0") ("CODE" "PP") ("BESCHREIBUNG" "Polygonpunkt")) (("LAYER" "0") ("CODE" "FIX") ("BESCHREIBUNG" "Fixpunkt")) (("LAYER" "0") ("CODE" "HP") ("BESCHREIBUNG" "Hjälppunkt")) (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "NB") ("BESCHREIBUNG" "Nedstigningsbrunn")) (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "TB") ("BESCHREIBUNG" "Tillsynsbrunn")) (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "AV") ("BESCHREIBUNG" "Avstängningsventil")) (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "DB") ("BESCHREIBUNG" "Dagvattenbrunn")) (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "TR") ("BESCHREIBUNG" "Trumma")) (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "BL") ("BESCHREIBUNG" "Brunnslock")) (("LAYER" "M-BEF-BERGLINJE") ("CODE" "BF") ("BESCHREIBUNG" "Bergfot")) (("LAYER" "M-BEF-VÄGKANT") ("CODE" "AK") ("BESCHREIBUNG" "Asfaltkant")) (("LAYER" "M-BEF-VÄGKANT") ("CODE" "VK") ("BESCHREIBUNG" "Vägkant")) (("LAYER" "0") ("CODE" "M") ("BESCHREIBUNG" "Marknivå")) (("LAYER" "M-BEF-VÄGKANTSTÖD") ("CODE" "K") ("BESCHREIBUNG" "Kantstöd")) (("LAYER" "M-BEF-BERGLINJE") ("CODE" "B") ("BESCHREIBUNG" "Berg")) (("LAYER" "M-BEF-DIKE") ("CODE" "DI") ("BESCHREIBUNG" "Dike")) (("LAYER" "M-BEF-VÄGKANT") ("CODE" "P") ("BESCHREIBUNG" "Plattyta")) (("LAYER" "M-BEF-VÄGKANT") ("CODE" "GR") ("BESCHREIBUNG" "Grusyta")) (("LAYER" "0") ("CODE" "SK") ("BESCHREIBUNG" "Stakkäpp")) (("LAYER" "0") ("CODE" "ES") ("BESCHREIBUNG" "El-telestolpe")) (("LAYER" "M-BEF-VÄGRÄCKE") ("CODE" "VR") ("BESCHREIBUNG" "Vägräcke")) (("LAYER" "M-BEF-STAKET") ("CODE" "SL") ("BESCHREIBUNG" "Stängsel")) (("LAYER" "0") ("CODE" "TH") ("BESCHREIBUNG" "Tomthörn")) (("LAYER" "M-BEF-TRAPPA") ("CODE" "TA") ("BESCHREIBUNG" "Trappa")) (("LAYER" "M-BEF-STAKETM") ("CODE" "ST") ("BESCHREIBUNG" "Staket")) (("LAYER" "M-BEF-MUR") ("CODE" "MU") ("BESCHREIBUNG" "Mur")) (("LAYER" "M-BEF-PLANTERING") ("CODE" "VE") ("BESCHREIBUNG" "Vegetationsgräns")) (("LAYER" "0") ("CODE" "T") ("BESCHREIBUNG" "Träd")) (("LAYER" "0") ("CODE" "BU") ("BESCHREIBUNG" "Buskar")) ("LAYER" "M-BEF-MUR") ("CODE" "MU") ("BESCHREIBUNG" "Mur") ("LAYER" "M-BEF-PLANTERING") ("CODE" "VE"))
For example "vg" "Spik""el" "0" can´t find in CLIST
Is it possible to build in your code Lee?
« Reply #6 on: September 06, 2012, 10:57:24 AM »
Try this:
  1. (defun c:test ( / cl clist ncode )
  2.
  3.     (setq cl '("VK" "SK" "TR" "DI" "K" "NB" "DB" "M" "TB" "MU" "vg" "Spik" "FG" "BS" "el" "0"))
  4.     (setq clist
  5.        '(
  6.             (("LAYER" "0") ("CODE" "HPS") ("BESCHREIBUNG" "Hjälppunktstation"))
  7.             (("LAYER" "0") ("CODE" "PP")  ("BESCHREIBUNG" "Polygonpunkt"))
  8.             (("LAYER" "0") ("CODE" "FIX") ("BESCHREIBUNG" "Fixpunkt"))
  9.             (("LAYER" "0") ("CODE" "HP") ("BESCHREIBUNG" "Hjälppunkt"))
  10.             (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "NB") ("BESCHREIBUNG" "Nedstigningsbrunn"))
  11.             (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "TB") ("BESCHREIBUNG" "Tillsynsbrunn"))
  12.             (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "AV") ("BESCHREIBUNG" "Avstängningsventil"))
  13.             (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "DB") ("BESCHREIBUNG" "Dagvattenbrunn"))
  14.             (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "TR") ("BESCHREIBUNG" "Trumma"))
  15.             (("LAYER" "M-BEF-BRUNNAR-VA") ("CODE" "BL") ("BESCHREIBUNG" "Brunnslock"))
  16.             (("LAYER" "M-BEF-BERGLINJE") ("CODE" "BF") ("BESCHREIBUNG" "Bergfot"))
  17.             (("LAYER" "M-BEF-VÄGKANT") ("CODE" "AK") ("BESCHREIBUNG" "Asfaltkant"))
  18.             (("LAYER" "M-BEF-VÄGKANT") ("CODE" "VK") ("BESCHREIBUNG" "Vägkant"))
  19.             (("LAYER" "0") ("CODE" "M") ("BESCHREIBUNG" "Marknivå"))
  20.             (("LAYER" "M-BEF-VÄGKANTSTÖD") ("CODE" "K") ("BESCHREIBUNG" "Kantstöd"))
  21.             (("LAYER" "M-BEF-BERGLINJE") ("CODE" "B") ("BESCHREIBUNG" "Berg"))
  22.             (("LAYER" "M-BEF-DIKE") ("CODE" "DI") ("BESCHREIBUNG" "Dike"))
  23.             (("LAYER" "M-BEF-VÄGKANT") ("CODE" "P") ("BESCHREIBUNG" "Plattyta"))
  24.             (("LAYER" "M-BEF-VÄGKANT") ("CODE" "GR") ("BESCHREIBUNG" "Grusyta"))
  25.             (("LAYER" "0") ("CODE" "SK") ("BESCHREIBUNG" "Stakkäpp"))
  26.             (("LAYER" "0") ("CODE" "ES") ("BESCHREIBUNG" "El-telestolpe"))
  27.             (("LAYER" "M-BEF-VÄGRÄCKE") ("CODE" "VR") ("BESCHREIBUNG" "Vägräcke"))
  28.             (("LAYER" "M-BEF-STAKET") ("CODE" "SL") ("BESCHREIBUNG" "Stängsel"))
  29.             (("LAYER" "0") ("CODE" "TH") ("BESCHREIBUNG" "Tomthörn"))
  30.             (("LAYER" "M-BEF-TRAPPA") ("CODE" "TA") ("BESCHREIBUNG" "Trappa"))
  31.             (("LAYER" "M-BEF-STAKETM") ("CODE" "ST") ("BESCHREIBUNG" "Staket"))
  32.             (("LAYER" "M-BEF-MUR") ("CODE" "MU") ("BESCHREIBUNG" "Mur"))
  33.             (("LAYER" "M-BEF-PLANTERING") ("CODE" "VE") ("BESCHREIBUNG" "Vegetationsgräns"))
  34.             (("LAYER" "0") ("CODE" "T") ("BESCHREIBUNG" "Träd"))
  35.             (("LAYER" "0") ("CODE" "BU") ("BESCHREIBUNG" "Buskar"))
  36.             (("LAYER" "M-BEF-MUR") ("CODE" "MU") ("BESCHREIBUNG" "Mur"))
  37.             (("LAYER" "M-BEF-PLANTERING") ("CODE" "VE"))
  38.         )
  39.     )
  40.
  41.     (foreach a cl
  42.         (cond
  43.             (   (vl-some '(lambda ( b ) (= a (cadr (assoc "CODE" b)))) clist)
  44.                 (princ (strcat "\n" a " already in list."))
  45.             )
  46.             (   (not (member a ncode))
  47.                 (setq ncode (cons a ncode))
  48.             )
  49.         )
  50.     )
  51.     (print ncode)
  52.     (princ)
  53. )
PS: Formatting code in your posts
cadplayer
« Reply #7 on: September 06, 2012, 11:02:35 AM »
Yes super. I try it in a couple of hours  :x and you have it in minutes  :-o
Thank so much!
« Reply #8 on: September 06, 2012, 11:09:21 AM »
Thank so much!
It's all practice cadplayer  :-)
You're welcome.
