« Reply #1 on: September 03, 2012, 10:19:42 PM »
See what you can make from this :
public static void ZoomExtents()
// cast as Autodesk.AutoCAD.Interop.AcadApplication
((AcadApplication)Application.AcadApplication).ZoomExtents();
public static void ZoomWindow(Point3d lowerleft, Point3d upperRight)
((AcadApplication)Application.AcadApplication).ZoomWindow(
lowerleft.ToArray(), upperRight.ToArray());
« Last Edit: September 03, 2012, 10:38:05 PM by Kerry »
Logged
