Author Topic: input options  (Read 1809 times)
jsr
input options
« on: September 02, 2012, 03:43:29 AM »
Hi all
When using PLINE command we are prompted to pick points or enter key words for arcs/length etc. How to get the same functionality in LISP programs. For example prompt user to either pick a point or enter some keyword such as 'L', which may trigger some other action.
Thanks.
BlackBox
Re: input options
« Reply #1 on: September 02, 2012, 04:10:02 AM »
Consider the INITGET and GETKWORD functions.
irneb
Re: input options
« Reply #2 on: September 02, 2012, 05:34:22 AM »
I think you mean initget with getpoint. But the idea is the same  ;)
BlackBox
Re: input options
« Reply #3 on: September 02, 2012, 02:23:28 PM »
It may not be the best solution (perhaps GETPOINT with INITGET's arbitrary input bit-code?), but it's the best suggestion I could think of given the specificity of the latter portion of the OP.
Re: input options
« Reply #4 on: September 02, 2012, 07:46:07 PM »
That's the quick fix.
(defun c:test (/ pt)
  (while
      (initget "Arc Close Halfwidth Length Undo Width")
      (setq pt (getpoint "\nSpecify next point or [Arc/Close/Halfwidth/Length/Undo/Width]:"))
        ((vl-consp pt) (princ "\nGot at point.") nil) ; exit while loop
        ((= pt "Arc") (print pt)t)
        ((= pt "Close") (print pt)t)
        ((= pt "Halfwidth") (print pt)t)
        ((= pt "Length") (print pt)t)
        ((= pt "Undo") (print pt)t)
        ((= pt "Width") (print pt)t)
        (t (princ "\nInvalid input."))
« Last Edit: September 02, 2012, 07:52:20 PM by CAB »
