Author Topic: While with Initget  (Read 6840 times)
Re: While with Initget
« Reply #15 on: August 31, 2012, 08:32:56 AM »
Another variation.
(defun c:test ( / lt )
       (while
             ((initget "Line Pline Exit"))
             ((not (member (setq lt (getkword "\nLine or Pline? [Line/Polyline/Exit] <Exit>: "))'("Line" "Pline" "Exit"))) nil)
             (t
               (command (strcat "_." lt))
               (while (= 1 (logand 1 (getvar 'cmdactive)))
                 (command pause)
               ) t)
edit: should have tested it  :-(
« Last Edit: August 31, 2012, 08:40:02 AM by CAB »
irneb
« Reply #16 on: August 31, 2012, 08:37:27 AM »
Good one there CAB. Though shouldn't it be
(= "Exit" ...perhaps? Else it issues an exit command.
Edit ... just say you edited it!  :kewl:
Perhaps
(member (...) '("Exit" nil))
« Reply #17 on: August 31, 2012, 08:40:53 AM »
That one is better, off to get my second cup  8-)
« Reply #18 on: August 31, 2012, 08:42:12 AM »
EDIT: Oops! I didn't read all the posts - it seems the OP now wants the 'Exit' to be default...
No  he wants LINE to be the default until he wants to exit and then he wants EXIT to be the default.  :evil:
 :-D
irneb
« Reply #19 on: August 31, 2012, 08:49:02 AM »
Actually I'm with him on this: The best interface is no interface.
Unless they can get some decent brainwave translator going I don't think it's possible though!
« Reply #20 on: August 31, 2012, 08:59:47 AM »
The typical scenario I use is ENTER goes to your common choice and ESCape is the exit key.  8-)
BlackBox
« Reply #21 on: August 31, 2012, 09:42:28 AM »
:lmao:
Yeah!!! I know! Funny as hell!  :pissed:
Anyhow, I hope I didn't confuse you too much RM  :lmao: .
Not at all, my friend... Just ribbing you; Happy Friday!  :angel:
BTW - Thanks for posting a link to this article; I've only skimmed it, but it looks pretty interesting.
Cheers! :beer:
« Last Edit: August 31, 2012, 10:39:01 AM by RenderMan »
irneb
« Reply #22 on: August 31, 2012, 10:36:58 AM »
Gathered as much  :laugh: . Cheers! I'm off for the weekend  :mrgreen:
« Reply #23 on: August 31, 2012, 11:38:31 AM »
An interesting read. Thanks  8-)
MeasureUp
« Reply #24 on: September 04, 2012, 12:33:44 AM »
Nice explanation.
Thanks for everyone's help.
chlh_jd
« Reply #25 on: September 06, 2012, 09:20:29 AM »
Is this whether you prefer it  :-D
(defun c:test  (/ lt)
  ;; Edited from Alan's code
  (while
      ((initget "Line Pline "))
      ((member (setq lt
      (getpoint
"\nLine or Pline? [Line/Polyline] <Select Point For Line / exit>: "))
       '("Line" "Pline"))
(command pause)
       t
      ((vl-consp lt);_Select point , run default command "LINE"
       (command "_.Line")
       (command lt)
(command pause)
       t)
