Author Topic: While with Initget  (Read 6838 times)
MeasureUp
While with Initget
« on: August 30, 2012, 08:09:59 PM »
Hi All,
I wrote this to draw "line" or "polyline".
Could you please help me on these questions:
1) The lines in red doesn't work. What is wrong? (i.e. it doesn't pass the call to draw "line" when click enter key without "L" or"P" input.)
2) Is the line in green necessary?
3) Is there anyother thing not making sense or incorrect?
Thanks in advance.
(defun c:TEST (/ LineType)
(initget "L P")
(while (setq LineType
(getkword "\n<L>ine or Polyline: ")
   ); end of setq
   [color=red](if (not LineType)
   (setq LineType "L")
   )[/color]; end of if
   (if (= LineType "L")
   (command "._line" pause pause)
   ); end of if
   (while (eq (getvar "cmdactive") 1)
  (command pause)
   ); end of while
   (if (= LineType "P")
   (command "._pline" pause pause)
   ); end of if
  (command PAUSE)
   ); end of while
   [color=green](initget "L P")[/color]
); end of while
PS. I can't show the texts in color in the code. Can someone point me out? Thanks.
« Last Edit: August 30, 2012, 09:32:23 PM by MeasureUp »
Re: While with Initget
« Reply #1 on: August 30, 2012, 09:54:18 PM »
Maybe this:
(defun c:test (/ linetype)
  (while (or (initget "L P")
             (setq linetype (getkword "\nLine or Polyline: ")))
      ((= linetype "P") (command "._pline" pause pause))
      ((command "._line" pause pause))
    (while (eq (getvar "cmdactive") 1) (command pause))
MeasureUp
« Reply #2 on: August 30, 2012, 10:09:36 PM »
Thanks CAB.
But I can't get the meaning of this line:
(or (initget "L P")
At this point, I can't draw "line" by default by simply hitting the enter key without any letter inputs.
« Reply #3 on: August 31, 2012, 12:13:42 AM »
Hitting ENTER only is your exit option.
If you want to hit ENTER to draw a line, how do you want to signal the exit from the loop?
Off to bed, see you tomorrow.  ZZzzzz...
MeasureUp
« Reply #4 on: August 31, 2012, 12:30:16 AM »
What I mean is on my original code this should allow me to draw "line" without type in "L":
(if (not LineType)
(setq LineType "L")
unfortunatly, it doesn't work what I expected.
Thanks.
BlackBox
« Reply #5 on: August 31, 2012, 12:52:35 AM »
Posting from my iPhone....
  (and
    (not (initget "Line Polyline"))
    (or (setq option (getkword "\nSelect an option [Line/Polyline]<Line>: "))
      (setq option "Line")
  (prompt (strcat "\nYou entered " option))
  (prompt "\n** No option entered **")
irneb
« Reply #6 on: August 31, 2012, 02:18:48 AM »
Actually I prefer not using the and/or when doing something like this. I use progn instead ... seeing as the test should have nothing to do with the return value of initget. Not that it's wrong to do so, it's just more clear when reading the code:
  1. (defun c:Test  (/ LineType)
  2.   (while (and (progn (initget "Line Polyline Exit") ;Initialize the keywords
  3.                      ;;Ask for the keywords + a default
  4.                      (or (setq LineType (getkword "Select an option [Line/Polyline/Exit] <Line>: "))
  5.                          (setq LineType "Line"))) ;If Enter/Space for default - set the value of default
  6.               (not (eq LineType "Exit"))) ;Allow for an exit condition to stop the routine
  7.     (cond ((eq LineType "Line") ;Is keyword Line
  8.            (command "._Line")
  9.            (while (> (getvar "CmdActive") 0) (command pause)))
  10.           ((eq LineType "Polyline") ;Is keyword Polyline
  11.            (command "._PLine")
  12.            (while (> (getvar "CmdActive") 0) (command pause)))))
  13.   (princ))
I've done some further alterations, like using cond instead of multiple ifs, simply added the while pause, and added an Exit keyword else the user has no option but to press Esc to stop. But that's off-topic I think.
MeasureUp
« Reply #7 on: August 31, 2012, 02:38:11 AM »
  13.   (princ))
Many thanks to irneb.
It works.
But just one more question:
Is there any way to modify your code to press the enter key to exit?
With your one I have to enter "E" to exit.
irneb
« Reply #8 on: August 31, 2012, 02:52:43 AM »
Yes very easily. There are 2 way to go about that:
Option 1:
Change the "default" to be Exit instead of Line
  1. ;;...
  2.   (while (progn (initget "Line Polyline Exit") ;Initialize the keywords
  4.                      (or (setq LineType (getkword "Select an option [Line/Polyline/Exit] <Exit>: "))
  5.                          (setq LineType "Exit"))) ;If Enter/Space for default - set the value of default
  7. ;;...
Option 2:
Since the getkword function returns nil if you press Enter/Space, use that feature to stop the while loop directly. This actually makes the condition portion a lot simpler
  1. ;;...
  4.                 (setq LineType (getkword "Select an option [Line/Polyline/Exit] <Exit>: ")))
  5. ;;...
MeasureUp
« Reply #9 on: August 31, 2012, 03:01:14 AM »
Thanks again, irneb.
Now I can see the conflict in logical.
I can't set the default for drawing "line" and "Exit" at the same time by pressing the "enter" key.
Am I right?
irneb
« Reply #10 on: August 31, 2012, 03:39:35 AM »
Uhm ... well ... yes  :|
AFAICT acad can't read minds ... yet!  :lmao:
BlackBox
« Reply #11 on: August 31, 2012, 07:44:29 AM »
 :lmao:
« Reply #12 on: August 31, 2012, 08:14:33 AM »
Here is how I might approach it:
  1. (defun c:test ( / lt )
  2.     (while
  3.         (progn
  4.             (initget "Line Polyline Exit")
  5.             (/= "Exit" (setq lt (getkword "\nLine or Polyline? [Line/Polyline/Exit] <Line>: ")))
  6.         )
  7.         (if (or (= "Line" lt) (null lt))
  8.             (command "_.line")
  9.             (command "_.pline")
  10.         )
  11.         (while (= 1 (logand 1 (getvar 'cmdactive)))
  12.             (command pause)
  13.         )
  14.     )
  15.     (princ)
  16. )
EDIT: Oops! I didn't read all the posts - it seems the OP now wants the 'Exit' to be default...
So maybe:
  2.     (while
  3.         (progn
  5.             (member (setq lt (getkword "\nChoose [Line/Polyline/Exit] <Exit>: ")) '("Line" "Polyline"))
  6.         )
  10.         )
  12.             (command pause)
  13.         )
  14.     )
  15.     (princ)
  16. )
« Last Edit: August 31, 2012, 08:19:16 AM by Lee Mac »
« Reply #13 on: August 31, 2012, 08:27:39 AM »
No  he wants LINE to be the default until he wants to exit and then he wants EXIT to be the default.  :evil:
irneb
« Reply #14 on: August 31, 2012, 08:31:02 AM »
:lmao:
Yeah!!! I know! Funny as hell!  :pissed:
Anyhow, I hope I didn't confuse you too much RM  :lmao: .
