Author Topic: variable name  (Read 2017 times)
jsr
variable name
« on: August 30, 2012, 06:00:32 AM »
Hi all
Is it possible to use value of a variable as the name of another variable. For example (setq a "st") and then use st as the name of some other variable. Note that the value "st" is determined during program execution for example it may represent name of a block.
Thanks.
Re: variable name
« Reply #1 on: August 30, 2012, 06:16:46 AM »
perhaps try
  1.
  2. (setq a "st"
  3.       b "mo"
  4. )
  5.
  6.
  7. ;;< .. >
  8.
  9. (set 'a 42)
  10.
  11. (set (quote b) "apples")
  12.
  13.
irneb
Re: variable name
« Reply #2 on: August 30, 2012, 06:24:57 AM »
Definately! Also try looking at the read & eval functions. E.g.
  1. (setq st "Some arb data here")
  2. (setq a "st")
  3. (read a) ; Returns a symbol st
  4. (print (eval (read a))) ;Evaluates the symbol st which is read from the contents of a and thus returns "Some arb data here"
  5. (print st) ;Returns the same thing "Some arb data here"
  6. (set (read a) "Changed data")
  7. (print (eval (read a))) ;Now it returns "Changed data"
  8. (print st) ;Same again "Changed data"
So see the read as something which converts a string into a lisp expression.
And eval as the opposite of quote.
Re: variable name
« Reply #3 on: August 30, 2012, 07:43:06 AM »
perhaps try
  1.
  2. (setq a "st"
  3.       b "mo"
  4. )
  5.
  6.
  7. ;;< .. >
  8.
  9. (set 'a 42)
  10.
  12.
  13.
The above is no different to:
  1. (setq a "st"
  2.       b "mo"
  3. )
  4.
  5. ;;< .. >
  6.
  7. (setq a 42
  8.       b "apples"
  9. )
Since 'setq' is simply a convenience function, short for (set (quote <symbol>) <value>)
I believe the OP was looking to bound a value to the symbol equivalent of the string "st", e.g.:
  1. _$ (setq a "st")
  2. "st"
  3. _$ (setq b "mo")
  4. "mo"
  5. _$ (set (read a) 42)
  6. 42
  7. _$ (set (read b) "apples")
  8. "apples"
  9.
  10. ;; Evaluate variables:
  11. _$ a
  12. "st"
  13. _$ b
  14. "mo"
  15. _$ st
  16. 42
  17. _$ mo
  18. "apples"
ElpanovEvgeniy
  • Moscow (Russia)
Re: variable name
« Reply #4 on: August 30, 2012, 07:46:48 AM »
feature set and read very slowly ...
Re: variable name
« Reply #5 on: August 30, 2012, 09:04:56 AM »
ahhh ! I misread the question :(
