Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Inserire Modificare Cancellare valori su un database access
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Inserire Modificare Cancellare valori su un database access (Read 1424 times)
Lupo76
Bull Frog
on:
August 28, 2012, 07:24:30 AM »
Hello to all,
is possible in lisp insert, edit and delete values of a Microsoft Access database?
Do you have a little 'sample code, or know a website that deals with this problem?
Thanks in advance.
Logged
irneb
Water Moccasin
ACad R9-2016, Revit Arch 6-2016
WWW
Re: Inserire Modificare Cancellare valori su un database access
Reply #1 on:
August 28, 2012, 07:50:13 AM »
ADOLisp
uses ADO or ODBC connections to databases. You can then send SQL queries to the database to UPDATE/INSERT/DELETE/SELECT rows from tables / combinations of tables.
I think it includes a sample of working with an Access MDB file.
Logged
Lupo76
Bull Frog
Reply #2 on:
August 28, 2012, 08:29:10 AM »
Perfect!
thank you!
Yes, confirm, there is an example in it.
Now I get to work
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
