Author Topic: eGraphicsNotGenerated  (Read 2508 times)
TJK44
« on: August 24, 2012, 03:36:57 PM »
Has anyone ran across this error before and know what it means? It's happening at this line of code when trying to generate a PDF.
pe.BeginGenerateGraphics(Nothing)
Full Code:
                            Try
                                Dim layMgr As LayoutManager = LayoutManager.Current
                                Dim loObjId As ObjectId = layMgr.GetLayoutId(layMgr.CurrentLayout)
                                Dim lo As Layout = DirectCast(tr.GetObject(loObjId, OpenMode.ForRead), Layout)
                                Dim ps As New PlotSettings(lo.ModelType)
                                ps.CopyFrom(lo)
                                Dim pi As New PlotInfo()
                                pi.Layout = loObjId
                                Dim psv As PlotSettingsValidator = Autodesk.AutoCAD.DatabaseServices.PlotSettingsValidator.Current
                                psv.SetPlotConfigurationName(ps, "DWG To PDF.pc3", "ANSI_B_(11.00_x_17.00_Inches)")
                                psv.RefreshLists(ps)
                                psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents)
                                psv.SetUseStandardScale(ps, True)
                                psv.SetStdScaleType(ps, StdScaleType.ScaleToFit)
                                pi.OverrideSettings = ps
                                Dim pe As PlotEngine = PlotFactory.CreatePublishEngine()
                                Try
                                    pe.BeginPlot(Nothing, Nothing)
                                    Dim validator As New PlotInfoValidator()
                                    validator.MediaMatchingPolicy = Autodesk.AutoCAD.PlottingServices.MatchingPolicy.MatchEnabled
                                    validator.Validate(pi)
                                    'Dim plotFile As String = Path.GetFullPath(Application.DocumentManager.MdiActiveDocument.Database.Filename)
                                    Dim plotFile As String = Path.GetFullPath(doc2.Name)
                                    plotFile = plotFile.Remove(plotFile.Length - 4)
                                    pe.BeginDocument(pi, doc.Name, Nothing, 1, True, plotFile & ".pdf")
                                    Dim pageInfo As New PlotPageInfo()
                                    pe.BeginPage(pageInfo, pi, True, Nothing)
                                    pe.EndGenerateGraphics(Nothing)
                                    pe.EndPage(Nothing)
                                    pe.EndDocument(Nothing)
                                    pe.EndPlot(Nothing)
                                Catch ex As System.Exception
                                    Windows.MessageBox.Show(ex.Message)
                                End Try
                                pe.Destroy()
                                tr.Commit()
                            End Try
Thanks for any help,
-Ted
t0w
Re: eGraphicsNotGenerated
« Reply #1 on: October 03, 2016, 06:37:26 AM »
Sry for reviving this,
resolving error for me was making sure that the image was not open in an Adobe Acrobat Reader DC tab.
