(defun C:XSCALE(/ bp ss xscal yscal entL)
(defun errexit (s)
(princ "\nError: ")
(princ s)
(restore)
(defun restore ()
(setvar "CMDECHO" (car oldvar))
(setq *error* olderr)
(defun MAKEUNBLOCK (ss ip / tmp errexit mbx BLAYER)
(setq T (not nil))
(setq olderr *error*
*error* errexit
(setq oldvar
(list
(getvar "CMDECHO")
(setvar "CMDECHO" 0)
(terpri)
(if BLAYER
(command "._LAYER"
(if (tblsearch "LAYER" BLAYER) "_S" "_M")
BLAYER
(if (and ip ss)
(entmake (list
(cons '0 "BLOCK")
(cons '2 "*U")
(cons '70 1)
(cons '10 ip)
(setq cnt (sslength ss))
(while (>= (setq cnt (1- cnt)) 0)
(setq tmp (ssname ss cnt))
(entmake (setq el (entget tmp)))
(if (> (cdr (assoc 66 el)) 0)
(while
(/= "SEQEND"
(cdr
(assoc 0
(entmake (setq el (entget (entnext (cdr (assoc -1 el))))))
(entdel tmp)
(setq tmp (entmake (list (cons '0 "ENDBLK"))))
(entmake (list
(cons '0 "INSERT")
(cons '2 tmp)
(cons '10 ip)
(restore)
(setq ss (ssget)) ;;;You can add the scaling type
(if ss
(setvar "cmdecho" 0)
(setq bp (getpoint "Scaling reference point (<0,0,0>): "))
(if (not bp) (setq bp (list 0 0 0)))
(setq xscal (getreal "X scale <1>: "))
(if (not xscal) (setq xscal 1))
(setq yscal (getreal "Y scale <1>: "))
(if (not yscal) (setq yscal 1))
(MAKEUNBLOCK ss bp)
(setq entL (entget (entLast))
entL (subst (cons 41 xscal) (assoc 41 entL) entL)
entL (subst (cons 42 yscal) (assoc 42 entL) entL)
(entmod entL)
(command "_explode" "l" "")
(princ )
