Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Equivalent of Flatshot command in .Net API
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Equivalent of Flatshot command in .Net API (Read 2060 times)
rom1_am
Guest
on:
August 23, 2012, 09:54:07 AM »
My need is to export a list of 3d solid contained in different blocks as if i was using the flatshot command (with the front view, and if possible in dxf format)
I've researched on the forum and found those topics:
http://www.theswamp.org/index.php?topic=36283.15
http://www.theswamp.org/index.php?topic=33105.msg385443#msg385443
Apparently it's not possible to use sendcommand with the flatshot command since we can't avoid the dialogbox.
Isn't there an equivalent of this command in the .net API?
(I use AutoCAD 2013 and C# with Visual studio express 2010)
I've also tried to understand how the 'dxfout' method works but didn't achieve to make it works.
Thanks for your help
Logged
zoltan
Newt
Re: Equivalent of Flatshot command in .Net API
Reply #1 on:
August 23, 2012, 11:13:32 AM »
I use the Section object to create 2D views of 3D objects. The objects don't have to intersect the section plane.
Logged
rom1_am
Guest
Reply #2 on:
August 24, 2012, 05:25:43 AM »
Thanks I'll try this possiblity.
Logged
rom1_am
Guest
Reply #3 on:
August 29, 2012, 04:40:17 AM »
We've effectively done what we wanted thanks to the GetSection method on the different solid3d objects.
Code - C#:
[Select]
Plane plane
new
Plane
Point3d
Origin
, Vector3d
YAxis
using
Region region
solid
GetSection
plane
(special thanks to Gile)
Logged
insmur
Mosquito
Reply #4 on:
June 29, 2019, 02:57:24 PM »
Could you share all code;
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
