The SWF opens in Flash Player, but nothing seems to happen.What is a GPG file? I don't seem to find any program which opens such. Closest I get when searching the net seems to be a Public Key File - i.e. like a PGP file. But I'm sure that's not it.
Unfortunately that's not it either - tells me it's a corrupt image when trying to open it as a JPG.
how to Achieve only one pick point & both pick point (diagonal)
Quote from: Sam on August 23, 2012, 08:20:56 AMhow to Achieve only one pick point & both pick point (diagonal) From the gif it would appear that you already have the program?
Code - Auto/Visual Lisp: [Select](if (eq (progn (initget 7 "Two") (setq p (getpoint "\n Specify point or <two>:")) ) "Two" ) (progn (setq p1 (getpoint "\n Specify first point :")) (setq p2 (getpoint "\n Next point :" p1)) ))
(if (and ( that program is belong to you and you have access to it ) (if you mean lay the entity on a specific layer while inserting it ) )(just include the name of the layer within the entmake like this '(8 . "Your Layer name"))otherwise(You should show your codes))
