Author Topic: Civil 3D: how to create a surface from the supplied shp files  (Read 3924 times)
alanjt
  • Standby for witty remark...
« on: August 22, 2012, 03:19:55 PM »
I've received the following shp files, but when I insert them into Civil 3D, I can't figure out how to create a surface from them. I notice, under an extra field "OD:Contour1Ft", it gives a value for a field called "ContourEle". Is there a way to access this and assign it to the "Elevation" field and then create a surface from newly elevated polylines (they come in with a 0 elevation) or is there a way to just create a surface?
See attached file. Thanks guys.
Dropbox
Willie
  • Going nowhere slowly
Re: Civil 3D: how to create a surface from the supplied shp files
« Reply #2 on: August 24, 2012, 01:42:30 AM »
Click Home tab → Create Ground Data panel → Surfaces drop-down → Create Surface From GIS Data
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 8  64-bit Enterprise | Civil 3D 2015 and 2016| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
alanjt
« Reply #3 on: August 28, 2012, 09:55:58 AM »
That's awesome!
BTW (for future users), don't forget to hit the "login" button and "map GIS data to Civil3D properties".
Thank you, thank you, thank you.
Dropbox
huiz
  • Certified Prof C3D
« Reply #4 on: August 28, 2012, 10:04:25 AM »
Indeed, what alanjt says!
In the past I did some complicated things with Map queries to get the Elevation Object Data into the property of the contourlines but this functionality does that all! I wish I knew before! Silly how this one is hidden deeply inside the Ribbon.
Thank you, unpronounceable name! :-)
alanjt
« Reply #5 on: August 28, 2012, 10:07:20 AM »
This should be stickied.
Now if I could only find some FEMA data that would come in correctly, I'd be set.
Dropbox
