Author Topic: List Sub-Directories within a Directory  (Read 12029 times)
deegeecees
« on: August 20, 2012, 02:23:10 PM »
Been quite a while since I've hacked away in Lisp, but I'm looking for a way to list the sub-directories in a given directory. Fairly easy and straight forward. I've looked at the vl- functions but nothing seems to jump out at me. Could someone point me in the right direction?
gile
  • Marseille, France
Re: List Sub-Directories within a Directory
« Reply #1 on: August 20, 2012, 02:31:27 PM »
IMO, Vanilla LISP (DXF) is a better way with dictionaries.
Here's a little routine which returns an assoc list of all entries of the specified dictionary. Each pair is of type (key . ename).
Warning, Dictionariy entries may be either dictionaries or xrecords or custom objects.
  1. (defun gc:GetDictEntries (dict / result)
  2.   (and (= (type dict) 'ENAME) (setq dict (entget dict)))
  3.   (while
  4.     (setq dict (vl-member-if (function (lambda (x) (= (car x) 3))) (cdr dict)))
  5.      (setq result (cons (cons (cdar dict) (cdadr dict)) result))
  6.   )
  7.   (reverse result)
  8. )
BlackBox
« Reply #2 on: August 20, 2012, 02:37:14 PM »
You could use Scripting.FileSystemObject Object:
  1. (defun _GetSubFolders (oFolder / oSubs)
  2.   (if (< 0
  3.             (vlax-get
  4.               (setq oSubs (vlax-get oFolder 'subfolders))
  5.               'count
  6.             )
  7.          )
  8.     (vlax-for x oSubs
  9.       (setq subFolders (cons (vlax-get x 'path) subFolders))
  10.       (_GetSubFolders x)
  11.     )
  12.   )
  13. )
« Last Edit: August 20, 2012, 03:40:38 PM by RenderMan »
BlackBox
« Reply #3 on: August 20, 2012, 02:58:35 PM »
Quick example:
  1. (defun c:FOO (/ *error* _GetSubFolders acApp oShell oShellFolder path
  2.               oFso oFolder subFolders
  3.              )
  4.
  5.   (defun *error* (msg)
  6.     (if oShell
  7.       (vlax-release-object oShell)
  8.     )
  9.     (if oFso
  10.       (vlax-release-object oFso)
  11.     )
  12.     (cond ((not msg))                                                   ; Normal exit
  13.           ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
  14.           ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
  15.     )
  16.     (princ)
  17.   )
  18.
  19.   (defun _GetSubFolders (oFolder / oSubs)
  20.     (if (< 0
  21.            (vlax-get
  22.              (setq oSubs (vlax-get oFolder 'subfolders))
  23.              'count
  24.            )
  25.         )
  26.       (vlax-for x oSubs
  27.         (setq subFolders (cons (vlax-get x 'path) subFolders))
  28.         (_GetSubFolders x)
  29.       )
  30.     )
  31.   )
  32.
  33.            (setq oShell (vla-getinterfaceobject acApp "Shell.Application"))
  34.            (setq oShellFolder
  35.                   (vlax-invoke
  36.                     oShell
  37.                     'BrowseForFolder
  38.                     (vla-get-hwnd acApp)
  39.                     "Select a folder to add to SFSP:"
  40.                     0
  41.                     17
  42.                   )
  43.            )
  44.            (setq path (vlax-get-property
  45.                         (vlax-get-property oShellFolder 'Self)
  46.                         'Path
  47.                       )
  48.            )
  49.            (setq oFso
  50.                   (vla-getinterfaceobject acApp "Scripting.FileSystemObject")
  51.            )
  52.            (setq oFolder (vlax-invoke oFso 'getfolder path))
  53.            (not (_GetSubFolders oFolder))
  54.            subFolders
  55.       )
  56.     (progn
  57.       (prompt "\nSub-Folders found: \n")
  58.       (foreach sub subFolders
  59.         (prompt (strcat "\n\t\t" sub))
  60.       )
  61.       (terpri)
  62.       (*error* nil)
  63.     )
  64.     (cond (oFolder (*error* "No subfolders found"))
  65.           (oFso (*error* "Unable to obtain Folder Object"))
  66.           (path
  67.            (*error*
  68.              "Unable to create \"Scripting.FileSystemObject\" Object"
  69.            )
  70.           )
  71.           (oShellFolder (*error* "Unable to obtain path property"))
  72.           (oShell (*error* "No directory selected"))
  73.           (acApp
  74.            (*error* "Unable to create \"Shell.Application\" Object")
  75.           )
  76.     )
  77.   )
  78. )
gile
  • Marseille, France
« Reply #4 on: August 20, 2012, 03:27:29 PM »
Oopss !! I confused Directory and dictionary  :ugly:
Look at the vl-directory-files function with -1 flag.
chlh_jd
« Reply #5 on: August 20, 2012, 03:36:12 PM »
following's code written by xyp-1964
(defun xyp-GetFolders (path SubFolders-TNil / main sub folder)
  (defun main (path / folders)
    (if (member "." (setq folders (vl-directory-files path nil -1)))
      (cddr folders)
      folders
  (defun sub (path)
    (mapcar (function (lambda (folder / temp)
       (cons (setq temp (strcat path "/" folder))
     (apply 'append (sub temp))
    (main path)
  (if (setq lst
     (if SubFolders-TNil
       (apply (function append) (sub path))
       (if (setq folders (main path))
(mapcar (function (lambda (x) (strcat path "/" x))) folders)
    (vl-sort (mapcar (function strcase) lst) (function <))
irneb
« Reply #6 on: August 21, 2012, 04:22:53 AM »
Here's my version (also using vl-directory-files):
  1. (defun _GetSubfolders (path / )
  2.   (setq path (vl-string-right-trim "\\/" path))
  3.   (mapcar '(lambda (name) (strcat path "\\" name))
  4.           (vl-remove-if '(lambda (name) (wcmatch name "`.,`.`."))
  5.             (vl-directory-files path nil -1))))
  6.
  7. (defun _GetRecursiveSubfolders (path /)
  8.   (setq path (vl-string-right-trim "\\/" path))
  9.          (mapcar '(lambda (name / temp)
  10.                     (if (setq temp (_GetRecursiveSubfolders (setq name (strcat path "\\" name))))
  11.                       (cons name temp)
  12.                       (list name)))
  13.                  (vl-remove-if '(lambda (name) (wcmatch name "`.,`.`."))
  14.                    (vl-directory-files path nil -1)))))
Just take note that if your folders contain Unicode characters this won't list them. If you use unicode characters in your foldernames, then RenderMan's solution of using the Scripting.FileSystemObject is the only one I know of which works well.
Edit: Slightly simplified recursive subfolder list:
  1. (defun _GetRecursiveSubfolders (path /)
  3.          (mapcar '(lambda (name / temp)
  4.                     (cons name (_GetRecursiveSubfolders (setq name (strcat path "\\" name)))))
  5.                  (vl-remove-if '(lambda (name) (wcmatch name "`.,`.`."))
  6.                    (vl-directory-files path nil -1)))))
I don't seem to be able to get at a tail-call-recursive method for this though. So if your paths are around 20000 deep expect errors ... though you'd have some strange folder structure to get to that point  :ugly:
« Last Edit: August 21, 2012, 04:33:37 AM by irneb »
irneb
« Reply #7 on: August 21, 2012, 04:58:07 AM »
And my version using the FileSystemObject:
  1. (defun _GetSubfolders  (path recurse / fso folders)
  2.              (setq fso (vl-catch-all-apply 'vlax-get-or-create-object '("Scripting.FileSystemObject")))))
  3.     (setq folders (apply 'append
  4.                          (mapcar '(lambda (f / p)
  5.                                     (cons (setq p (vlax-get f 'Path))
  6.                                           (if recurse (_GetSubfolders p recurse))))
  7.                                  (cond ((and (not (vl-catch-all-error-p (setq path (vl-catch-all-apply 'vlax-invoke (list fso 'GetFolder path)))))
  8.                                              (not (vl-catch-all-error-p (setq folders (vl-catch-all-apply 'vlax-get (list path 'SubFolders))))))
  9.                                         (Collection->List folders)))))))
  10.   (vl-catch-all-apply 'vlax-release-object (list fso))
  11.   folders)
gile
  • Marseille, France
« Reply #8 on: August 21, 2012, 05:38:36 AM »
AFAIK, AutoLISP doesn't manage tail-recursion.
irneb
« Reply #9 on: August 21, 2012, 06:22:09 AM »
Yes, I know - though it's still a good principle to try for. Otherwise all recursive functions would run into stack overflows if the list of calls are long (even if the interpreter/compiler optimizes tail-recursion).
Anyhow, it's a moot point for this scenario. I think the PC might just crash if you have folder paths 20000 levels deep!
One other thing to take note of: The recursive folder listing might take some time if there are 100's (or even 1000's) of folders - never mind their depth. A possible solution is to use dgorsman's depth-limit, see my version of this here.
« Reply #10 on: August 21, 2012, 06:33:09 AM »
Perhaps as an iterative version:
  1. (defun _getsubfolders ( dir / lst out sub )
  2.     (setq lst (list dir))
  3.     (while lst
  4.         (setq sub nil)
  5.         (foreach dir lst
  6.             (setq sub
  7.                 (append sub
  8.                     (mapcar (function (lambda ( x ) (strcat dir "\\" x)))
  9.                         (vl-remove-if
  10.                             (function (lambda ( x ) (member x '("." ".."))))
  11.                             (vl-directory-files dir nil -1)
  12.                         )
  13.                     )
  14.                 )
  15.             )
  16.         )
  17.         (setq out (append sub out)
  18.               lst sub
  19.         )
  20.     )
  21.     out
  22. )
irneb
« Reply #11 on: August 21, 2012, 06:38:31 AM »
Yes, I was thinking in the same lines. But seeing as the recursive error only happens so far along (http://www.cadtutor.net/forum/showthread.php?62502-Help-Limit-of-recursive&s=f9ecbd9f8180770b9dac40e615ddf486) I don't think it would ever apply in this case.
Anyhow, folder pathing simply lends itself to recursion doesn't it? It's basically a tree structure, which is one of the major uses of recursion. Though as you've shown you don't "need" recursion for such - just some state variables.
« Reply #12 on: August 21, 2012, 06:57:24 AM »
Just skinning the cat  8-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: August 21, 2012, 06:57:45 AM »
deegeecees
« Reply #14 on: August 21, 2012, 09:04:00 AM »
Thats the one, thank you!
I appreciate all the help, and replies. Some interesting concepts.
