Author Topic: Final release of VS 2012 is out  (Read 7818 times)
vegbruiser
Re: Final release of VS 2012 is out
« Reply #1 on: August 15, 2012, 03:23:41 PM »
That's cracking news; Thanks!
I've been tearing my hair out with the RC the past 2 days - it was working, then I installed a couple of add-ins and Boom! Nothing, nada, zip..
2 reinstalls and a visit to Windows 7 safe mode later and I got it functioning again only to have it fail once more.
[sarcasm]I Look forward to downloading/installing the RTM version..[/sarcasm]
 :cry:
« Reply #2 on: August 15, 2012, 09:24:50 PM »
AutoCAD does NOT play well with the .NET 4.5 framework.
user beware.
KewlToyZ
« Reply #3 on: August 15, 2012, 09:47:14 PM »
Yeah I had lots of failures, and uninstalling to get things stable again was hairy to say the least...
2013 Din't like it at all :ugly:
vegbruiser
« Reply #4 on: August 16, 2012, 04:26:55 AM »
user beware.
I'm sure I read here somewhere that AutoCAD flat-out fails if you use the default .NET 4.5 settings;
That said, it should work ok if you switch to .NET 4.0 right?  :|
« Reply #5 on: August 16, 2012, 04:32:30 AM »
I had the 4.5 prelim installed.
I uninstalled it and re-installed 4.0 and the updates.
... wasn't too painfull :)
kaefer
« Reply #6 on: August 16, 2012, 06:20:22 AM »
I've just installed a highly compatible, in-place update to .NET Framework 4, ostensibly published 08/02/2012, and haven't experienced any deleterious effects yet.
Surely there are a couple of subtle and not so subtle differences between RC and RTM...
« Reply #7 on: August 16, 2012, 07:11:08 AM »
I have no idea about subtle differences kaefer;
All I know is that I could reproduce crashes and AutoCAD developers advised me of the incompatibility.
.. this was late July. I'm not sure if it was the build signed July 9 or a previous framework build .... perhaps MS have made changes that rectify the AutoCAD incompatibility ... I'm sure we'll find out soon enough.
Regards
KewlToyZ
« Reply #8 on: August 16, 2012, 10:01:26 AM »
My problem was uninstalling the VS NET 2012 Beta
CADbloke
  • Crash Test Dummy
« Reply #9 on: August 25, 2012, 08:13:52 AM »
There are (apparently) WPF incompatibilities in .NET 4.0 on Windows XP because you can't update XP to 4.5. Here is a not-very-short thread about it: http://social.msdn.microsoft.com/Forums/en/wpf/thread/c05a8c02-de67-47a9-b4ed-fd8b622a7e4a
This is not entirely related to what you're talking about here but it may be relevant for some.
vegbruiser
« Reply #10 on: August 25, 2012, 08:54:22 AM »
Did you manage to fix the problem?
VS 2012 RTM is completely hosed for me at the moment. (Uninstalling, reinstalling doesn't fix it!) :x
