Author Topic: Find the possible route and calculate route length between 2 blocks  (Read 6006 times)
qdzung
Hi everybody,
I took a few days to find from Internet but has not answer. I hope some friends would like to help me.
I want to write VBA app for my job. This tool will take out many cables length run through trays.
For example : has 1 tray system, and many cables run between blocks. So how can the Tool can find the possible route and "run" through it.
Can advise me some code to calculate the length from
Block A to Block 1
Block A to Block 2
Block B to Block 1
Block B to Block 2
I also send the sample drawing.
Many thanks,
dgorsman
Re: Find the possible route and calculate route length between 2 blocks
« Reply #1 on: August 15, 2012, 10:41:01 AM »
Sounds like the Travelling Salesman problem - one of the classic classroom assignments for algorithm development.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
qdzung
« Reply #2 on: August 15, 2012, 10:53:59 AM »
thank you guy
But now I don't know how to "Find the way from A to 1", while they are connected by many lines, which has many cross point. After found some ways, we can calculate the length throuth lines
 So could you advise me some example code
« Reply #3 on: August 15, 2012, 11:32:05 AM »
Consider using Dijkstra's algorithm, where the 'weights' for each path would be the length of the line segment.
qdzung
« Reply #4 on: August 15, 2012, 11:41:32 AM »
Thank you very much Lee :D I will try
qdzung
« Reply #5 on: August 16, 2012, 04:11:16 AM »
I found code from Mr CAB, could anybody help me to "translate it" to VBA
http://www.theswamp.org/index.php?topic=1749.msg22949#msg22949
;;   pline path finder.lsp
;;   Charles Alan Butler 07/08/2004
;;   Modified routine to find a path from picked start entity
;;   to picked end entity.
;;   Returns the first path if it exist else nil, not the shortest path
;;   Selects & highlites the path also
 ;shortcut
(defun c:plp () (c:PlinePath))
;;;               Original Routine
;;;  ;; based on Inline.lsp by John Uhden
;;;  ;; modified Joe Burke 5/15/03
;;;  ;; pick a line, arc or lwpline
;;;  ;; creates a selection set of objects which meet end to end
;;;  ;; only selects objects on the same layer as picked object
;;;  ;; pass selection set to pedit join...
;;      -=<  Sub Routines  >=-
;;  Return (ename Startpt Endpt)
(defun @arc (ent / e rp r ba ea p1 p2)
  (setq e  (cdr (assoc -1 ent))
        rp (cdr (assoc 10 ent))
        r  (cdr (assoc 40 ent))
        ba (cdr (assoc 50 ent))
        ea (cdr (assoc 51 ent))
        p1 (trans (polar rp ba r) e 0)
        p2 (trans (polar rp ea r) e 0)
  (list e p1 p2)
) ;end
(defun @line (ent)
  (list
    (cdr (assoc 11 ent))
) ;end
(defun @pline (ent / e)
  (setq e (cdr (assoc -1 ent)))
  (list
    e
    (car (getends e))
    (cadr (getends e))
) ;end
;;  Add ent-> (ename Startpt Endpt) to list
(defun @list (e / ent)
  (setq ent (entget e))
    ((= (cdr (assoc 0 ent)) "LINE")
     (setq sslist (cons (@line ent) sslist))
    ((= (cdr (assoc 0 ent)) "ARC")
     (setq sslist (cons (@arc ent) sslist))
    ((= (cdr (assoc 0 ent)) "LWPOLYLINE")
     (setq sslist (cons (@pline ent) sslist))
) ;end
;;argument: an ename - returns: Start and End points as a list
(defun getends (vobj / name stpt endpt)
  (if (= (type vobj) 'ename)
    (setq vobj (vlax-ename->vla-object vobj))
  (and
    (setq name (vla-get-objectname vobj))
      ((vl-position
         name
         '("AcDbArc"           "AcDbLine"          "AcDbEllipse"
           "AcDbSpline"        "AcDbPolyline"      "AcDb2dPolyline"
           "AcDb3dPolyline"
       (setq stpt (vlax-curve-getstartpoint vobj))
       (setq endpt (vlax-curve-getendpoint vobj))
    ) ;cond
  ) ;and
  (list stpt endpt)
) ;end
;; get list of (ename startpt endpt) for picked ent
(defun get:elst(ent)
     (setq ent (@arc ent))
     (setq ent (@line ent))
     (setq ent (@pline ent))
  ent
); end defun
;;          main function
(defun c:plinepath (/      sslist elist  ss     ssres  i      e      e2
                    found  ent    ent2   ok     start  end    start2 end2
                    fuzz   layer  ssex   typlst
  ;; Get the start object
  (if ; vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
    (and
      (cadr (ssgetfirst)) ;objects are selected
      ;;at least one arc, line or pline
      (setq ssex (ssget "i" (list (cons 0 "LINE,ARC,LWPOLYLINE"))))
    ) ;and
     ;; ======  then  =============
     (setq e (ssname ssex 0))
     ;; ======  else  =============
       (sssetfirst)
       (setq typlst '("LINE" "ARC" "LWPOLYLINE"))
       (while
         (or
           (not (setq e (car (entsel "\nSelect Starting line, pline or arc: "))))
           (not (member (cdr (assoc 0 (entget e))) typlst))
          (princ "\nMissed pick or wrong object type: ")
       ) ;while
     ) ;progn
  ) ;if  ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
  ;;  Get the End object added by CAB
  (while
    (or
      (not (setq e2 (car (entsel "\nSelect Ending line, pline or arc: "))))
      (not (member (cdr (assoc 0 (entget e2))) typlst))
  ) ;while
  (and
    (setq ok   1
          fuzz 1e-8 ; 0.00000001
    (setq ent (entget e)) ; first or picked ent
    (setq ent2 (entget e2)) ; second picked ent, CAB
    (setq layer (cdr (assoc 8 ent))) ; layer to match
    (= layer (cdr (assoc 8 ent2))) ; layers match
    (setq ent    (get:elst ent)
          elist  '()
          start  (cadr ent)
          end    (caddr ent)
          ent2   (get:elst ent2); CAB
          start2 (cadr ent2)
          end2   (caddr ent2)
    (setq ss ; get all objects that matched picked
           (ssget "X" (list '(0 . "LINE,ARC,LWPOLYLINE") (cons 8 layer)))
    (ssdel e ss) ; remove picked start from selection set
    ;;  make a list of all from ss  ((ename startpt endpt) ....)
    (setq i 0)
    (repeat (sslength ss)
      (@list (ssname ss i))
      (setq i (1+ i))
    ) ;repeat
    ;;  CAB revised from here down
    ;;  find attached items, does not test all branches
    (@ckpoint start ent sslist)
    (if (not found)
      (@ckpoint end ent sslist)
  ) ;and
  (if found
      (setq elist (cons ent elist))
      (setq ssres (ssadd))
      (foreach x elist ; creat a selection set of the list
        (ssadd (car x) ssres)
      (prompt "\n*-* Done *-*\n")
      (cadr(sssetfirst nil ssres)) ; display the selected items
    ); progn
    (prompt "\n*-* Path not found *-*")
) ;end
;;  @ckPoint by CAB
;;  check the list for matching points
;;  p point to match
;;  elst (ename startpt endpt) of pt
;;  |List list pf remaining elst
(defun @ckpoint( p elst |list / entx ex p1 p2 idx res)
  (setq idx (length |List))
  (while (and (not found) (>= (setq idx (1- idx)) 0))
    (setq entx (nth idx |List)
          ex  (car entx)
          p1  (cadr entx)
          p2  (caddr entx)
    (cond ; test point match with fuzz factor
      ((equal p start2 fuzz) ; text for target
       (setq found 1)
       (setq elist (cons ent2 elist))
      ((equal p end2 fuzz) ; text for target
       (setq found 1)
      ((equal p p1 fuzz) ; test for next branch
       (setq res (@ckpoint p2 entx (vl-remove entx |List)))
       (if found ; we are backing out collecting the path
        (setq elist (cons entx elist))
      ((equal p p2 fuzz) ; test for next branch
       (setq res (@ckpoint p1 entx (vl-remove entx |List)))
       (if found; we are backing out collecting the path
  ); while
  T ; return to satisfy AND
); defun
;;   End Of File
fixo
« Reply #6 on: August 20, 2012, 07:11:01 AM »
Try this one, assuming this will work with straight segments only,
 not treated on your drawing, just I've grab them from my old codes
Option Explicit
Public Sub blockPath()
Dim oSset As AcadSelectionSet
Dim pt As Variant
Dim blk1 As AcadBlockReference
Dim blk2 As AcadBlockReference
Dim ent As AcadEntity, ent1 As AcadEntity, ent2 As AcadEntity
Dim ft(0) As Integer
Dim fd(0) As Variant
ft(0) = 0: fd(0) = "lwpolyline"
ThisDrawing.Utility.GetEntity ent1, pt, vbCrLf & "Select First Block:"
If Not TypeOf ent1 Is AcadBlockReference Then
Exit Sub
End If
Set blk1 = ent1
Dim verts1() As Double
verts1 = BoundingBoxTest(ent1)
Dim PointsList1(0 To 11) As Double
Dim cnt, i
cnt = 0
For i = 0 To UBound(verts1, 1)
PointsList1(cnt) = verts1(i, 0)
PointsList1(cnt + 1) = verts1(i, 1)
PointsList1(cnt + 2) = verts1(i, 2)
cnt = cnt + 3
Next
ThisDrawing.Utility.GetEntity ent2, pt, vbCrLf & "Select Second Block:"
If Not TypeOf ent2 Is AcadBlockReference Then
Exit Sub
End If
Set blk2 = ent2
Dim verts2() As Double
verts2 = BoundingBoxTest(ent2)
Dim PointsList2(0 To 11) As Double
cnt = 0
For i = 0 To UBound(verts2, 1)
PointsList2(cnt) = verts2(i, 0)
PointsList2(cnt + 1) = verts2(i, 1)
PointsList2(cnt + 2) = verts2(i, 2)
cnt = cnt + 3
Next
ThisDrawing.Utility.GetEntity ent, pt, vbCrLf & "Select main polyline:"
If Not TypeOf ent Is AcadLWPolyline Then
Exit Sub
End If
Dim mpoly As AcadLWPolyline
Set mpoly = ent
          With ThisDrawing.SelectionSets
               While .Count > 0
                    .Item(0).Delete
               Wend
          End With
          Set oSset = .Add("$PolySet$")
     End With
Dim mode As Integer
mode = acSelectionSetCrossingPolygon
oSset.SelectByPolygon mode, PointsList1, ft, fd
Dim pline1 As AcadLWPolyline
Set ent = oSset.Item(0)
Set pline1 = ent
               While .Count > 0
                    .Item(0).Delete
               Wend
          End With
     End With
oSset.SelectByPolygon mode, PointsList2, ft, fd
Dim pline2 As AcadLWPolyline
Set pline2 = ent
Dim intpts1 As Variant
Dim j
intpts1 = pline1.IntersectWith(mpoly, acExtendNone)
Dim inspt1(0 To 2) As Double
If VarType(intpts1) <> vbEmpty Then
        For i = LBound(intpts1) To UBound(intpts1)
            inspt1(0) = intpts1(j): inspt1(1) = intpts1(j + 1): inspt1(2) = intpts1(j + 2)
            i = i + 2
            j = j + 3
        Next
    End If
Dim intpts2 As Variant
intpts2 = pline2.IntersectWith(mpoly, acExtendNone)
j = 0
Dim inspt2(0 To 2) As Double
If VarType(intpts2) <> vbEmpty Then
        For i = LBound(intpts2) To UBound(intpts2)
            inspt2(0) = intpts2(j): inspt2(1) = intpts2(j + 1): inspt2(2) = intpts2(j + 2)
            i = i + 2
            j = j + 3
        Next
    End If
Dim leg As Double
leg = Distance(inspt1, inspt2)
MsgBox "Common Length: " & vbCr & CStr(leg + pline1.Length + pline2.Length)
End Sub
Private Function BoundingBoxTest(oEnt As AcadEntity) As Double()
Dim MaxPoint As Variant
Dim MinPoint As Variant
Dim Vertices(0 To 3, 0 To 2) As Double
oEnt.GetBoundingBox MinPoint, MaxPoint
Vertices(0, 0) = MinPoint(0)
Vertices(0, 1) = MinPoint(1)
Vertices(0, 2) = MinPoint(2)
Vertices(1, 0) = MaxPoint(0)
Vertices(1, 1) = MinPoint(1)
Vertices(1, 2) = MinPoint(2)
Vertices(2, 0) = MaxPoint(0)
Vertices(2, 1) = MaxPoint(1)
Vertices(2, 2) = MinPoint(2)
Vertices(3, 0) = MinPoint(0)
Vertices(3, 1) = MaxPoint(1)
Vertices(3, 2) = MinPoint(2)
BoundingBoxTest = Vertices
End Function
Private Function Distance(fPoint As Variant, sPoint As Variant) As Double
    Dim x1 As Double, x2 As Double
    Dim y1 As Double, y2 As Double
    Dim z1 As Double, z2 As Double
    Dim cDist As Double
    x1 = sPoint(0): x2 = fPoint(0)
    y1 = sPoint(1): y2 = fPoint(1)
    z1 = sPoint(2): z2 = fPoint(2)
    cDist = Sqr(((x2 - x1) ^ 2) + ((y2 - y1) ^ 2) + ((z2 - z1) ^ 2))
    Distance = cDist
End Function
~'J'~
qdzung
« Reply #7 on: August 23, 2012, 01:35:53 AM »
thank you, Sir  8-)
fixo
« Reply #8 on: August 29, 2012, 04:06:59 PM »
You're welcome,
Cheers  :-)
~'J'~
