Author Topic: Installing ObjectARX help into Visual Studio Express  (Read 3974 times)
fxcastil
« on: August 14, 2012, 05:01:52 PM »
I am not able to see any ObjectARX help files from inside Visual Studio Express.
It seemed to install correctly and the install said ARX help is being intergrated into Visual Studio.
I palyed around with the help manager but I don't see where to add ARX help to Visual Studio menus?
See attached files
« Last Edit: August 14, 2012, 05:05:06 PM by fxcastil »
HYPERPICS
Re: Installing ObjectARX help into Visual Studio Express
« Reply #1 on: August 15, 2012, 01:43:13 PM »
I have not tried the ObjectARX 2012 Help Integration install, but I do know that the ObjectARX 2013 Help Integration install does work with Visual Studio 2010 Express.
You might want to verify that you are using offline Help:
1. Launch Visual C++ 2010 Express or Visual Basic 2010 Express.
2. From the menu bar, click Help > Manage Help Settings.
3. In the Help Library Manager dialog box, click Choose Online or Local Help.
4. Click I Want to Use Local Help and click OK.
5. Click Exit.
6. Press F1 and click the Contents tab.
That should show the ObjectARX and other offline Help topics.
fxcastil
« Reply #2 on: August 15, 2012, 03:27:49 PM »
I am not able to select the option to use local help??
The help files on the 2nd screen are installed but I can set them to local??
Can someone please provide a screen capture of the - choose online help or local help screen, I want to see where the help files are located on another VS install.
« Last Edit: August 15, 2012, 04:16:28 PM by fxcastil »
HYPERPICS
« Reply #3 on: August 15, 2012, 05:23:27 PM »
Your location and settings appear to be correct... what does the Help Viewer look like after it is launched?
fxcastil
« Reply #4 on: August 16, 2012, 01:52:14 PM »
If I enable help, it takes me to online help.
Did you notice that the OK button for choosing OFF-line help is NOT selectable.
I have removed all help files and re-installed them, but still no Local help.
HYPERPICS
« Reply #5 on: August 23, 2012, 03:48:30 PM »
Offline Help is set by the installer.  Can you post an image of what the Help window looks like, not the Settings dialog boxes?
