Usually ... when a function becomes so large that a cond structure becomes "lost" and/or obscured ... causing you to need exit: This means your function is too convoluted, at least for Lisp-best-practise. I've seen some, and I've written some myself (most notably my AutoIncr's main input function - from line 1657
here :-[ - "when" I get the time I'm definitely going to re-write that, at the very least, into separate functions).
In the above AutoIncr sample I'd have to follow a method like MP's example in order to use the exit function - since I don't want the calling function to exit, only the current one. Which IMO might even make than function more convoluted, therefore the cond used is the best for that case. Though the contents of each cond makes the function lumber-some (never mind cumbersome). So in the "lisp-way" (though many languages advocate keeping each function minimal for ease of future support) would be to effectively extract each condition body into a separate defun of its own - then the condition would simply call that defun instead of inlining its code. That would make the cond structure a lot more readable for future edits.
