You could use the
vl-exit-with-value to get something similar to C#/C++'s return keyword. Unfortunately though it only works from inside a compiled VLX using a separate namespace (if you use it inside the document namespace - i.e. a same namespace VLX or a FAS/LSP file - it acts like exit but without calling the *error* function or returning a value)
... why that should be you'd have to ask ADesk. My guess is it "exits the namespace, rather than the defun". Same goes for the
vl-exit-with-error it seems. At least from my quick tests here in Vanilla 2012:
1)
2)
(defun c:test
(/ *error*)
Both those simply exit to command prompt without returning anything or calling the localized *error* defun at all.
I'd go with Kerry & RM's idea though! There's nothing worse than a user finding his OSnaps turned off after using your custom command. Even in C#/C++ you need to watch for this. If your defun doesn't alter stuff which should revert back, then you may not need to exit cleanly - but there's many times that you'd set some sysvar to make your programming work less or to make the user-interface more to your liking. In which case an error-handler is an absolute MUST.
Actually there's some debate about the use of return / break to stop a function / loop halfway through (even in C/C++/C#). Some deem it a form of "lazy programming". Their main gripe is exactly this "cleanup" idea - though they tend to use memory leaks as an example (which is less of an issue in lisp).
E.g. If your C function allocates memory dynamically (say using malloc or in C++ new) you should either return the pointer to that allocated memory or release it using free / delete. It just becomes very easy to forget to do so if you use return / break somewhere halfway through your code. I mean you look through your code and see that you've written the free / delete so memory shouldn't "leak". But you miss the line where you return / break earlier from the function / loop - if that return/break is reached the memory is never de-allocated, making your function eat RAM every time it's used.
